Duet3D 1HCL - Closed Loop Controller Beta test
Edit: I got my .5 and .6s confused I've corrected them now
Yes, Tony is also right here:
I think you are using M569.5 instead of M569.6
What does sending
M569.6 P50.0 V31
Result in?The M569.5 command is for recording. This does let you pass in a manoeuvre (V parameter) to do. So running M569.5 as you describe would technically work to do a tuning move...
However, you'll also be making a recording each time, so you'll quickly fill up your SD card with recordings. For this reason, unless you intend to do a recording, using M569.6 is preferable to do a tuning move.For anyone curious as to why there are 2 GCODE commands to do tuning moves, the rationale is that with HTTP delays etc, it is unlikely that you'd be able to send M569.5 and M569.6 quickly enough to record a tuning move. For that reason, M569.5 allows you to specify a tuning move that gets started just before the recording is started.
@t3p3tony said in Duet3D 1HCL - Closed Loop Controller Beta test:
M569.6 P50.0 V31
9/21/2021, 7:00:28 AM M569.6 P50.0 V31
Error: M569.6: Drive is not in closed loop mode. -
@supertb1 with M569 P50.0 D4 S1 first?
@lirwin17 said in Duet3D 1HCL - Closed Loop Controller Beta test:
M569.1 P50.0 T2 C5 E5:10
the motor has a 4000 pulse per rotation that I verified
M98 P"config.g"
before change to P50.0
9/21/2021, 7:10:36 AM Error: Response timeout: CAN addr 51, req type 6045, RID=27
Pulse-type filament monitor on pin io5.in, enabled, sensitivity 7.000mm/pulse, allowed movement 55% to 150%, check every 22.0mm, no data received
Error: bad model parameters
9/21/2021, 7:10:35 AM Error: Response timeout: CAN addr 51, req type 6043, RID=25
9/21/2021, 7:10:34 AM Error: Response timeout: CAN addr 51, req type 6042, RID=23
9/21/2021, 7:10:33 AM Error: Response timeout: CAN addr 51, req type 6042, RID=21
9/21/2021, 7:10:32 AM Error: Response timeout: CAN addr 51, req type 6042, RID=19
9/21/2021, 7:10:31 AM Error: Response timeout: CAN addr 51, req type 6018, RID=17
9/21/2021, 7:10:30 AM Error: Response timeout: CAN addr 51, req type 6041, RID=15
Error: No encoder specified for closed loop drive mode
9/21/2021, 7:10:29 AM Error: Error threshold value must be greater than zero. -
@supertb1 I have P51.0 disconnected at the moment as advised
Short update:
I am on my third print with the closed loop drivers and so far they are working quite well. The axes are sticking to their position very well. I really have to apply a lot of force to push them off course, and they will snap right back.
I am printing with up to 300mm/s and was able to increase my acceleration and jerk significantly. On the downside I had to limit my max. speeds to 20000mm/min or 300mm/s.
@lirwin17 I have two motors on my Y axis. They are both wired to one 1HCL board, but only one has an encoder. It calibrates fine, and I did not spot a significant problem during printing. Only the recorded graphs were of no use on this axis (at least for me). Maybe something to keep in mind for future development.(especially for autotuning. )
Furthermore, I have the impression that the drivers run in full step without any microstepping as soon as I switch to closed loop. It sounds very much like my very first printer. The prints also show a strong stepping pattern.
Cheers Max
@lirwin17
After change to P50.0
9/21/2021, 7:14:52 AM Error: Response timeout: CAN addr 51, req type 6043, RID=25
9/21/2021, 7:14:51 AM Error: Response timeout: CAN addr 51, req type 6042, RID=23
9/21/2021, 7:14:50 AM Error: Response timeout: CAN addr 51, req type 6042, RID=21
9/21/2021, 7:14:49 AM Error: Response timeout: CAN addr 51, req type 6042, RID=19
9/21/2021, 7:14:48 AM Error: Response timeout: CAN addr 51, req type 6018, RID=17
9/21/2021, 7:14:47 AM Error: Response timeout: CAN addr 51, req type 6041, RID=15
9/21/2021, 7:14:43 AM M98 P"config.g"
HTTP is enabled on port 80
FTP is disabled
TELNET is disabled
Again channel 51 is disconnected -
@t3p3tony
G4 S3 ;wait for expansion boards to start
M569.1 P50.0 T2 C5 E5:10 ; Configure the 1HCL board at CAN address 50 with a quadrature encoder on the motor shaft that has 20 steps per motor full step.
M569.M51 P51.0 S1 T2 C20 E20 R100 I0 D0 ; Configure the 1HCL board at CAN address 51 with a quadrature encoder on the motor shaft that has 20 steps per motor full step.
M569 P50.0 D4 S1 ; Configure the motor on the 1HCL at can address 50 as being in closed-loop drive mode (D4), Open loop (D2) and not reversed (S1) X axis
M569 P51.0 D2 S1 ; Configure the motor on the 1HCL at can address 51 as being in closed-loop drive mode (D4), Open loop (D2) and not reversed (S1) Y axis
M569 P0.0 S1 ; physical drive 0.0 goes forwards Z 1-2 axis -
@supertb1 sorry I should have been clearer. After start up send the following from the console:
M569 P50.0 D4 S1 M569.6 P50.0 V31
@lirwin17
since the change on the M569.1 line to P50.0 T2 C5 E5:10
I am now getting closed loop enabled : yes
on P50 V8 it is saying that the drive has an incorrect polarity
V32 made the drive run off to the end of it's travel
M569.6 P50.0 V64
Warning: No new tuning errors have been found, but some existing tuning errors exist. The drive has not been zeroed. The drive has not had it's polarity checked. The drive has not had it's control checked. The encoder has not had it's count per revolution and V128 is the same result -
M569.6 P50.0 V31
M569.6 P50.0 V31
Warning: M569.6: One or more tuning errors occurred. The drive has been found to have an incorrect polarity. -
@t3p3tony does this mean that I need to switch the positive and negative wires?
Sorry, this error message is a bit misleading - I'll change that. The polarity should be detected automatically, so a better error message may be "encoder polarity failed to be detected"
Please could you follow the same instructions I gave to maxgyver above (here), although on the 'movement' checkboxes down the right hand side, please could you check 'polarity detection'
We should then be able to take a look at the graph and see what's going on
@lirwin17 is there another report with different variables I need to run for more information?
@lirwin17 I'm not sure how to read these... it looks like coil A is out of step phase and coil B doesn't appear to be doing anything... target motor steps says there are 4 errors
No, this is great
There's docs coming soon, but for now I'll talk you through it
The first thing to say is that the raw encoder reading is 0 on both recordings - this means it doesn't seem to register the encoder as moving at all.
This is strange because I thought that you did M122 twice after manually turning a full rotation and the encoder's reading changed... Please could you confirm this is still the case
(See this post for more detailed information)
