Duet3D 1HCL - Closed Loop Controller Beta test
@supertb1 homex.g
; called to home the X axis
; generated by RepRapFirmware Configuration Tool v3.2.3 on Mon Mar 08 2021 08:53:31 GMT-0600 (Central Standard Time)
M569 P50.0 D0 ; Turn off closed loopG91 ; relative positioning
G1 H1 X-240 F3000 ; move quickly to X axis endstop and stop there (first pass)
G1 H2 X5 F6000 ; go back a few mm
G1 H1 X-240 F240 ; move slowly to X axis endstop once more (second pass)G90 ; absolute positioning
G1 X50 F3000 ; Move to a known-safe position
M400 ; Wait for the move to complete
G4 P500 ; Wait for the motor to settle
M569 P50.0 D4 ; Turn closed loop back on
M569.6 P50.0 V31 ; Perform the tuning manoeuvres for a quadrature encoder
G1 X0 ; Move back to X0G1 H2 Z0 F6000 ; lower Z again
@t3p3tony sorry about the multiple posts but it seems the posts are limited in size to 50 or 60 lines... is there anything else I can give you to make this easier?
@t3p3tony I disconnect the motor and turn it one full revolution then M122 P50, resulting:
Diagnostics for board 50:
Duet EXP1HCL firmware version 3.4.0beta3 (2021-08-24 14:56:43)
Bootloader ID: SAME5x bootloader version 2.4beta (2021-07-23)
Never used RAM 52992, free system stack 2578 words
Tasks: Move(notifyWait,0.0%,126) HEAT(notifyWait,0.0%,108) CanAsync(notifyWait,0.0%,70) CanRecv(notifyWait,0.0%,79) CanClock(notifyWait,0.0%,72) TMC(notifyWait,15.5%,28) CLSend(notifyWait,0.0%,150) CLData(notifyWait,0.0%,142) MAIN(running,82.6%,380) IDLE(ready,0.0%,39) AIN(notifyWait,1.9%,265), total 100.0%
Last reset 00:36:45 ago, cause: software
Last software reset time unknown, reason: HardFault bfarValid precise, available RAM 51580, slot 0
Software reset code 0x0060 HFSR 0x40000000 CFSR 0x00008200 ICSR 0x00430803 BFAR 0x20030008 SP 0x2001eba8 Task MAIN Freestk 531 ok
Stack: 00000000 00000000 00000002 20030000 00030f39 0001b8f9 0001ea4c 41000000 bf800000 00000000 533c0605 04001200 a808a700 06420000 c3210828 19a21429 50708239 5d000040 2a60041c 5dd40122 4143051f 41200000 41c22c02 4142f6d6 20000010 0002699b 00000002
Closed loop enabled: yes, live status: 0x4, encoder type linearQuadrature, pre-error threshold: 20.000000, error threshold: 100.000000, coil A polarity: +, coil B polarity: -, tuning: 0, tuning error: 0x1f, position -1515866801, raw count = 4010, collecting data: no, ultimateGain=0.000000, oscillationPeriod=0.000000
Driver 0: position -50588, 106.5 steps/mm, standstill, reads 27092, writes 0 timeouts 0, SG min/max not available, steps req 0 done 0
Moves scheduled 5, completed 5, in progress 0, hiccups 0, step errors 0, maxPrep 0, maxOverdue 0, maxInc 0, mcErrs 0, gcmErrs 0
Peak sync jitter -5/4, peak Rx sync delay 182, resyncs 0/0, no step interrupt scheduled
VIN: 24.3V, V12: 12.2V
MCU temperature: min 27.4C, current 28.7C, max 28.9C
Ticks since heat task active 14, ADC conversions started 2187517, completed 2187516, timed out 0, errs 0
Last sensors broadcast 0x00000000 found 0 18 ticks ago, loop time 0
CAN messages queued 11760, send timeouts 0, received 13191, lost 0, free buffers 37, min 37, error reg 0
dup 0, oos 0/0/0/0, bm 0, wbm 0, rxMotionDelay 0 -
@lirwin17 can you have a look at this please
@supertb1 please upgrade the 1HCL firmware to the latest here:
https://www.dropbox.com/sh/qkexrvhgsebbz0g/AAD9gfyS8UIU5Sau311WS1oLa?dl=0 -
@t3p3tony I updated my firmware using the link above, E-stop, Ran
M569.6 P50.0 V31 then M122 B50:
M122 B50
Duet EXP1HCL firmware version 3.4.0beta3+1 (2021-09-14 15:07:31)
Never used RAM 51580, free system stack 2582 words
Tasks: Move(notifyWait,0.0%,160) HEAT(notifyWait,0.0%,95) CanAsync(notifyWait,0.0%,70) CanRecv(notifyWait,0.0%,81) CanClock(notifyWait,0.0%,72) TMC(notifyWait,30.6%,358) CLSend(notifyWait,0.0%,148) CLData(notifyWait,0.0%,142) MAIN(running,67.4%,410) IDLE(ready,0.0%,39) AIN(notifyWait,2.0%,265), total 100.0%
Last reset 00:02:18 ago, cause: software
Closed loop enabled: no, live status: 0, encoder type none, pre-error threshold: 0.000000, error threshold: 0.000000, reverse polarity: no, tuning: 0, tuning error: 0, collecting data: no, ultimateGain=0.000000, oscillationPeriod=0.000000, Control loop runtime (ms): min=0.000000, max=0.056000, avg=0.000000, Control loop frequency (Hz): min=5859.375000, max=18292.683594, avg=17441.861328
Driver 0: pos 0, 106.5 steps/mm, standstill, reads 56348, writes 19 timeouts 0, SG min/max 0/0, steps req 0 dMoves scheduled 0, completed 0, in progress 0, hiccups 0, step errors 0, maxPrep 0, maxOverdue 0, maxInc 0, mcErrs 0, gcmErrs 0
Peak sync jitter -3/4, peak Rx sync delay 183, resyncs 0/0, no step interrupt scheduled
MCU temperature: min 28.0C, current 28.0C, max 28.4C
Ticks since heat task active 200, ADC conversions started 136156, completed 136155, timed out 0, errs 0
Last sensors broadcast 0x00000000 found 0 204 ticks ago, loop time 0
CAN messages queued 1154, send timeouts 0, received 1251, lost 0, free buffers 37, min 37, error reg 0
9/20/2021, 8:13:33 AM M569.6 P50.0 V31
Error: M569.6: Drive is not in closed loop mode.as above in my config Channel 50 is in closed loop mode
@supertb1 can you increase the G4 S1 in your config to at least S2 if not S3?
@jay_s_uk increased S1 to S3:
G4 S3 ;wait for expansion boards to start
M569.1 P50.0 S1 T2 C20 E20 R100 I0 D0 ; Configure the 1HCL board at CAN address 50 with a quadrature encoder on the motor shaft that has 20 steps per motor full step.
M569.1 P51.0 S1 T2 C20 E20 R100 I0 D0 ; Configure the 1HCL board at CAN address 51 with a quadrature encoder on the motor shaft that has 20 steps per motor full step.
M569 P50.0 D4 S1 ; Configure the motor on the 1HCL at can address 50 as being in closed-loop drive mode (D4), Open loop (D2) and not reversed (S1) X axis
M569 P51.0 D2 S1 ; Configure the motor on the 1HCL at can address 51 as being in closed-loop drive mode (D4), Open loop (D2) and not reversed (S1) Y axis
M569 P0.0 S1 ; physical drive 0.0 goes forwards Z 1-2 axis
M569 P0.4 S1 ; physical drive 0.4 goes forwards Extruder
M584 X50.0 Y51.0 Z0.0:0.1 E0.4 ; set drive mapping
M671 X-122.25:689.20 Y0:0 S3.0 ; leadscrews at left (connected to Z0) and right (connected to Z1) of X axis
M350 X32 Y32 Z32 E16 I1 ; configure microstepping with interpolation
M92 X106.5 Y257 Z795.00 E339.00 ; set steps per mm
M906 X1000 Y3000 Z3000 E800 I30 ; set motor currents (mA) and motor idle factor in per cent
M84 S30 ; Set idle timeout
M917 X0 Y0 ; Set the closed loop axes to have a holding current of zero -
@jay_s_uk M122 B50
Never used RAM 51580, free system stack 2580 words
Tasks: Move(notifyWait,0.0%,160) HEAT(notifyWait,0.0%,108) CanAsync(notifyWait,0.0%,70) CanRecv(notifyWait,0.0%,81) CanClock(notifyWait,0.0%,72) TMC(notifyWait,30.6%,358) CLSend(notifyWait,0.0%,148) CLData(notifyWait,0.0%,142) MAIN(running,67.4%,400) IDLE(ready,0.0%,39) AIN(notifyWait,2.0%,265), total 100.0%
Last reset 00:01:06 ago, cause: software
Closed loop enabled: no, live status: 0, encoder type none, pre-error threshold: 0.000000, error threshold: 0.000000, reverse polarity: no, tuning: 0, tuning error: 0, collecting data: no, ultimateGain=0.000000, oscillationPeriod=0.000000, Control loop runtime (ms): min=0.000000, max=0.057333, avg=0.001333, Control loop frequency (Hz): min=8241.758789, max=18750.000000, avg=17441.861328
Driver 0: pos 0, 106.5 steps/mm, standstill, reads 52300, writes 19 timeouts 0, SG min/max 0/0, steps req 0 dMoves scheduled 0, completed 0, in progress 0, hiccups 0, step errors 0, maxPrep 0, maxOverdue 0, maxInc 0, mcErrs 0, gcmErrs 0
Peak sync jitter -4/4, peak Rx sync delay 177, resyncs 0/0, no step interrupt scheduled
MCU temperature: min 27.8C, current 28.0C, max 28.0C
Ticks since heat task active 110, ADC conversions started 65762, completed 65761, timed out 0, errs 0
Last sensors broadcast 0x00000000 found 0 115 ticks ago, loop time 0
CAN messages queued 579, send timeouts 0, received 603, lost 0, free buffers 37, min 37, error reg 0
9/20/2021, 8:50:40 AM M569.6 P50.0 V31
Error: M569.6: Drive is not in closed loop mode. -
@jay_s_uk No change
@supertb1 worth a shot
Hi @supertb1,
Sorry, I'm not 100% clear on the actual issue here. Thanks for providing your M122 output, from
tuning error: 0x1f
, it seems like no runtime tuning has happened. Similar to when an axis is un-homed, a driver that is untuned will not move, so if the issue is that the axis isn't moving then that would be the expected behaviour in this instance.
However, if you have run tuning, there is a deeper issue here.Details of tuning can be found on this page. Specifically, the two 'what do I need to do?' sections (1, 2) are compulsory before the system will move (eventually these should be part of the online config tool, but not just yet for the beta test)
If you weren't aware of this page in the docs, that's really useful for us to know because it tells us we need to draw more attention to that page
Thanks!
Louis -
@lirwin17 When I manually try to tune the X axis which is on closed loop mode on my config with everything selected it gives this error:
M569.5 P50.0 S500 A0 R0 D8191 V71
Error: M569.5: Drive is not in closed loop mode
M569.5 P50.0 S500 A0 R0 D8191 V71Here is my config:
@lirwin17 and it fails to manually tune
@lirwin17 with just raw encoder reading and step maneuver it throws fault: M569.5 P50.0 S500 A0 R0 D1 V64 and maintains that the motor is not in closed loop mode
@lirwin17 with just current motor steps and target motor steps selected performing the step maneuver yields: M569.5 P50.0 S500 A0 R0 D6 V64 and maintains that the drive is not in closed loop mode
@supertb1 i think you first need to tune the motors
M569.6
as outlined here:
https://duet3d.dozuki.com/Wiki/Tuning_the_Duet_3_Expansion_1HCL#Section_TuningIf you are using a quadrature encoder (i.e. your M569.1 command includes T1 or T2), then from the table above, manoeuvres 1, 2, 4, 8 and 16 are required - this means that they must be run every time the printer is powered on. This can be achieved by using the following command:
M569.6 P##.# V31 ; Where P##.# is the driver address to tune -
@supertb1
Hmm there are are a few M122 outputs so I've lost track a little...The first ones show
, but then some later ones showno
.The problem seems to be that when you come to run the tuning move, that
yes
has flipped to ano
...Please could you run through the following:
- power up (so config.g runs)
- run a manoeuvre command - it might be best to start with the simplest one V1
And at each point check M122 to see when yes flipps to no. Is it showing yes after config.g has run, or is it only when the move is run that it flips to no?
@lirwin17 That yes to the closed loop enable was there before I updated the 1HCL board to the latest firmware and now at power up it reports "no" to the close loop enable
@lirwin17 9/20/2021, 4:20:18 PM M122 B50
Never used RAM 51580, free system stack 2594 words
Tasks: Move(notifyWait,0.0%,160) HEAT(notifyWait,0.0%,108) CanAsync(notifyWait,0.0%,70) CanRecv(notifyWait,0.0%,81) CanClock(notifyWait,0.0%,72) TMC(notifyWait,30.6%,358) CLSend(notifyWait,0.0%,148) CLData(notifyWait,0.0%,142) MAIN(running,67.4%,414) IDLE(ready,0.0%,39) AIN(notifyWait,2.0%,265), total 100.0%
Last reset 00:02:47 ago, cause: power up
Closed loop enabled: no, live status: 0, encoder type none, pre-error threshold: 0.000000, error threshold: 0.000000, reverse polarity: no, tuning: 0, tuning error: 0, collecting data: no, ultimateGain=0.000000, oscillationPeriod=0.000000, Control loop runtime (ms): min=0.000000, max=0.058667, avg=0.000000, Control loop frequency (Hz): min=7281.553223, max=18292.683594, avg=17441.861328
Driver 0: pos 0, 106.5 steps/mm, standstill, reads 42667, writes 19 timeouts 0, SG min/max 0/0, steps req 0 dMoves scheduled 0, completed 0, in progress 0, hiccups 0, step errors 0, maxPrep 0, maxOverdue 0, maxInc 0, mcErrs 0, gcmErrs 0
Peak sync jitter -5/4, peak Rx sync delay 181, resyncs 0/0, no step interrupt scheduled
MCU temperature: min 27.4C, current 29.5C, max 29.5C
Ticks since heat task active 230, ADC conversions started 164966, completed 164965, timed out 0, errs 0
Last sensors broadcast 0x00000000 found 0 235 ticks ago, loop time 0
CAN messages queued 1384, send timeouts 0, received 1509, lost 0, free buffers 37, min 37, error reg 0
