Duet 3 Mini + 12864 Display not working
i connected my BTT 12864 Mini 1.0 to my duet 3 mini and the display seems not powered at all.
I connected it using EXP1 and EXP2 connectors.A friend of mine has same behaviour with duet 3 mini and same kind of display.
we tested and noticed that on 5v pin of EXP1 there is no voltage
Thanks for any help
@loris https://wiki.fysetc.com/BIQU12864_On_Spider/
rotate both connector 180 degrees and swap them if this not works...
