Duet 2 Wifi - VIN led only
@oliof unfortunately not.. I've got everything disconnected from the board besides the power.
For my own sanity... if PSU powers up, mosfett works, and VIN LED comes on... can I safely assume all the wiring, crimps, and ferrules are done correctly?
5V and 3.3V LEDs should also light up.
@oliof so as I search here and Google more, lots of posts around the 'fuse', so while I think the Fuse is ok... I am no expert and Googled how to check if a Fuse is blown and I think maybe my 7.5 fuse is?
Here's some photos of the fuses.
Labelled 15 (looks OK):
Labelled 7.5 (looks disconnected, blown?):
Grey Fuse, not labelled (can't tell if blown or not):
@infidelprops said in Duet 2 Wifi - VIN led only:
Here's some photos of the fuses.The red Fuse seems as it's blown
@siam Thanks mate, I got some different photos and I agree, both the red and grey seem blown
There's a local electrical store, but when I search 7.5 fuse, I get this: https://www.jaycar.com.au/search?text=7.5+fuse&CSRFToken=46ea0ec5-643e-47f9-8b01-1b49191b44f4
Is there specific fuses I should be looking for?
@infidelprops Yes both fuses are dead
These are the right one
normally you will get this fuses in a car equipment shop
UPDATE: Before you insert the new fuses check every Connection it seems you have somewhere a Problem with your wiring
If you have a multimeter you should check the fuses for continuity. I can be difficult to determine if they are for sure blown visually.
If you don't have a multimeter... how did you get this far building a printer?!
@phaedrux haha, I do have a multimeter and will check those now as well.
@siam Agreed mate, I'm going to re-cut and crimp all my power cables this morning.
Just picked up new fuses and put them in... she's alive!
Now to re-do all my cables
