Input field for nozzel height of the extruder
@jnb said in Input field for nozzel height of the extruder:
So it would be very helpful to have a input field in the settings to set the actual nozzle height for the extruders without touching the config each time.
What setting in config.g are you changing when you change the nozzle?
Oh, sorry that was imprecise by me...
I'm using a BLTouch, so I have to readjust the offset of the sensor so the nozzel touches the bed when at Z0
An for the second extruder the Tool-offset
So you mean the Z probe Z Trigger Height - the Z parameter of G31?
@fcwilt correct, and (as I just edited
) the tool-offset of the second extruder
Which tool offsets are you setting?
Do you have a multi-tool printer?
I'm using a Tenlog Hands 2 which I modified with a Duet3 MB 6HC and a EB 3HC.
So it's a IDEX with two tools on one X-rail.
So you need to modify the Z offset setting of the tool using G10?
@fcwilt exactly
The two marked lines
; Z-Probe M950 S0 C"1.io4.out" ; create servo pin 0 for BLTouch M558 P9 C"1.io4.in" H5 F500 T6000 ; set Z probe type to bltouch and the dive height + speeds ----> G31 P500 X0 Y-65.5 Z2.594 ; set Z probe trigger value, offset and trigger height (Default with 0.1mm h8mm nozzle = Z2.594) M556 S50 X0 Y0 Z0 ; set orthogonal axis compensation parameters M557 X10:201.2 Y10:159.5 S20 ; define mesh grid [...] ; Tools M563 P0 D0 H1 F2 S"Extruder 1" ; define tool 0 G10 P0 X0 Y0 Z0 ; set tool 0 axis offsets G10 P0 R0 S0 ; set initial tool 0 active and standby temperatures to 0C M563 P1 D1 H2 X3 F4 S"Extruder 2" ; define tool 1 ;G10 P1 U262.2 Y0 Z0 ; set tool 1 axis offsets ---> G10 P1 U3 Y-2.8 Z0 G10 P1 R0 S0
@fcwilt Well, I would say for normal quality nozzles the tolerances are trivial, so it could be seen as the same for the particular manufacturer and nozzle type
Well a fairly simple way would be to create a set of Macros with each macro containing the commands needed for a specific type/size of nozzle.
