BLTouch Won't deploy
@eegroeg said in BLTouch Won't deploy:
@joergs5 I got a replacement and M280 P3 S10 I1 causes it to deploy! M401 & M402 still don't do anything though is there any reason why this might be the case?
If M280 P3 S10 I1 works that would mean your firmware version is still RRF2 but your config files are for RRF3.
Please send M122 and M98 P"config.g" and post the results.
To update the firmware to RRF3 If you still have access to DWC. Upload these 3 zip files, one at a time in the system tab. Don't extract them. Reboot after each. Use M115 to verify the firmware has been applied.
https://github.com/Duet3D/RepRapFirmware/releases/download/3.0/Duet2and3Firmware-3.0.zip
https://github.com/Duet3D/RepRapFirmware/releases/download/3.3/Duet2and3Firmware-3.3.zip
That will get your firmware and DWC up to date.Then I think you'll find that your config file will work a lot better.
@phaedrux said in BLTouch Won't deploy:
M98 P"config.g"
M122 === Diagnostics === RepRapFirmware for Duet 3 MB6HC version 3.2.2 running on Duet 3 MB6HC v1.01 or later (standalone mode) Board ID: 08DJM-9P63L-DJMSS-6J9FD-3S86R-TBD39 Used output buffers: 1 of 40 (11 max) === RTOS === Static ram: 149788 Dynamic ram: 92412 of which 272 recycled Never used RAM 116360, free system stack 200 words Tasks: NETWORK(ready,183) ETHERNET(blocked,110) HEAT(blocked,300) CanReceiv(blocked,927) CanSender(blocked,371) CanClock(blocked,352) TMC(blocked,51) MAIN(running,1105) IDLE(ready,19) Owned mutexes: === Platform === Last reset 00:02:41 ago, cause: power up Last software reset at 2021-08-19 21:24, reason: User, GCodes spinning, available RAM 116360, slot 1 Software reset code 0x0003 HFSR 0x00000000 CFSR 0x00000000 ICSR 0x00400000 BFAR 0x00000000 SP 0x00000000 Task MAIN Freestk 0 n/a Error status: 0x00 Aux0 errors 0,0,0 Aux1 errors 0,0,0 MCU temperature: min 21.2, current 32.9, max 33.0 Supply voltage: min 23.9, current 23.9, max 24.0, under voltage events: 0, over voltage events: 0, power good: yes 12V rail voltage: min 12.0, current 12.1, max 12.2, under voltage events: 0 Driver 0: position 0, standstill, reads 63447, writes 14 timeouts 0, SG min/max 0/0 Driver 1: position 0, standstill, reads 63447, writes 14 timeouts 0, SG min/max 0/0 Driver 2: position 0, standstill, reads 63448, writes 14 timeouts 0, SG min/max 0/0 Driver 3: position 0, standstill, reads 63448, writes 14 timeouts 0, SG min/max 0/0 Driver 4: position 0, standstill, reads 63448, writes 14 timeouts 0, SG min/max 0/0 Driver 5: position 0, standstill, reads 63451, writes 11 timeouts 0, SG min/max 0/0 Date/time: 2021-08-19 21:38:11 Slowest loop: 7.24ms; fastest: 0.05ms === Storage === Free file entries: 10 SD card 0 detected, interface speed: 25.0MBytes/sec SD card longest read time 2.1ms, write time 0.0ms, max retries 0 === Move === DMs created 125, maxWait 0ms, bed compensation in use: none, comp offset 0.000 === MainDDARing === Scheduled moves 0, completed moves 0, hiccups 0, stepErrors 0, LaErrors 0, Underruns [0, 0, 0], CDDA state -1 === AuxDDARing === Scheduled moves 0, completed moves 0, hiccups 0, stepErrors 0, LaErrors 0, Underruns [0, 0, 0], CDDA state -1 === Heat === Bed heaters = -1 -1 -1 -1 -1 -1 -1 -1 -1 -1 -1 -1, chamberHeaters = -1 -1 -1 -1 === GCodes === Segments left: 0 Movement lock held by null HTTP is idle in state(s) 0 Telnet is idle in state(s) 0 File is idle in state(s) 0 USB is idle in state(s) 0 Aux is idle in state(s) 0 Trigger is idle in state(s) 0 Queue is idle in state(s) 0 LCD is idle in state(s) 0 SBC is idle in state(s) 0 Daemon is idle in state(s) 0 Aux2 is idle in state(s) 0 Autopause is idle in state(s) 0 Code queue is empty. === Network === Slowest loop: 13.08ms; fastest: 0.02ms Responder states: HTTP(0) HTTP(0) HTTP(0) HTTP(0) HTTP(0) HTTP(0) FTP(0) Telnet(0), 0 sessions Telnet(0), 0 sessions HTTP sessions: 1 of 8 - Ethernet - State: active Error counts: 0 0 0 0 0 Socket states: 5 2 2 2 2 0 0 0 === CAN === Messages queued 646, send timeouts 1453, received 0, lost 0, longest wait 0ms for reply type 0, free buffers 48
M98 P"config.g" HTTP is enabled on port 80 FTP is disabled TELNET is disabled Error: Invalid use of P parameter Error: Missing Z probe pin name(s) Error: Invalid Z probe index
Interesting.
Very strange that M280 P3 S10 I1 does anything at all.
Can you please post your current config.g and deployprobe.g and retractprobe.g files?
Can you also verify that those files are in the system folder and not the macros folder or elsewhere?
Can you also verify which io port you are using? For Duet 3 MB6HC, use IO_4, IO_5 or IO_7.
I'd still update the firmware to 3.3 as well.
@phaedrux Ah well now it is back to no response again... I can confirm nothing is in macros I am using IO_7
My Printer Send code... Status Idle Mode: FFF Tool Position X 0.0 Y 0.0 Z 0.00 Extruder Drives Drive 0 0.0 Speeds Requested Speed 0 mm/s Top Speed 0 mm/s Sensors Vin 23.9 V V12 12.1 V MCU Temperature 33.6 °C Tools Extra Control Heaters Tool Heater Current Active Standby Tool 0 T0 - Load Filament Heater 1 off 21.8 °C 0 0 Temperature Chart System Directory 0:/sys/config.g ; Configuration file for Duet 3 (firmware version 3) ; executed by the firmware on start-up ; ; generated by RepRapFirmware Configuration Tool v3.3.0 on Sun Aug 15 2021 14:13:39 GMT+0100 (British Summer Time) ; General preferences G90 ; send absolute coordinates... M83 ; ...but relative extruder moves M550 P"My Printer" ; set printer name ; Network M552 P0.0.0.0 S1 ; enable network and acquire dynamic address via DHCP M586 P0 S1 ; enable HTTP M586 P1 S0 ; disable FTP M586 P2 S0 ; disable Telnet ; Drives M569 P0.0 S1 ; physical drive 0.0 goes forwards M569 P0.1 S1 ; physical drive 0.1 goes forwards M569 P0.2 S1 ; physical drive 0.2 goes forwards M569 P0.4 S1 ; physical drive 0.4 goes forwards M584 X0.0 Y0.1 Z0.2:0.3 E0.4 ; set drive mapping M350 X16 Y16 Z16 E16 I1 ; configure microstepping with interpolation M92 X160.00 Y160.00 Z5120.00 E420.00 ; set steps per mm M566 X900.00 Y900.00 Z60.00 E120.00 ; set maximum instantaneous speed changes (mm/min) M203 X6000.00 Y6000.00 Z180.00 E1200.00 ; set maximum speeds (mm/min) M201 X500.00 Y500.00 Z20.00 E250.00 ; set accelerations (mm/s^2) M906 X800 Y800 Z800 E800 I30 ; set motor currents (mA) and motor idle factor in per cent M84 S30 ; Set idle timeout ; Axis Limits M208 X0 Y0 Z0 S1 ; set axis minima M208 X500 Y500 Z750 S0 ; set axis maxima ; Endstops M574 X1 S1 P"io0.in" ; configure active-high endstop for low end on X via pin io0.in M574 Y1 S1 P"io1.in" ; configure active-high endstop for low end on Y via pin io1.in M574 Z1 S2 P"io7.in" ; configure Z-probe endstop for low end on Z ; Z-Probe M950 S0 C"io7.out" ; create servo pin 0 for BLTouch M558 P9 H4 F120 T6000 ; set Z probe type to bltouch and the dive height + speeds G31 P500 X37.5 Y10 Z2.5 ; set Z probe trigger value, offset and trigger height M557 X15:215 Y15:215 S20 ; define mesh grid ; Heaters ;M308 S0 P"temp0" Y"thermistor" T100000 B4138 ; configure sensor 0 as thermistor on pin temp0 ;M950 H0 C"out0" T0 ; create bed heater output on out0 and map it to sensor 0 ;M307 H0 B1 S1.00 ; enable bang-bang mode for the bed heater and set PWM limit ;M140 H0 ; map heated bed to heater 0 ;M143 H0 S120 ; set temperature limit for heater 0 to 120C M308 S1 P"temp1" Y"thermistor" T100000 B4725 C7.06e-8 ; configure sensor 1 as thermistor on pin temp1 M950 H1 C"out1" T1 ; create nozzle heater output on out1 and map it to sensor 1 M307 H1 B0 S1.00 ; disable bang-bang mode for heater and set PWM limit M143 H1 S280 ; set temperature limit for heater 1 to 280C ; Fans M950 F0 C"out4" Q500 ; create fan 0 on pin out4 and set its frequency M106 P0 S0 H-1 ; set fan 0 value. Thermostatic control is turned off M950 F1 C"out5" Q500 ; create fan 1 on pin out5 and set its frequency M106 P1 S1 H1 T45 ; set fan 1 value. Thermostatic control is turned on ; Tools M563 P0 D0 H1 F0 ; define tool 0 G10 P0 X0 Y0 Z0 ; set tool 0 axis offsets G10 P0 R0 S0 ; set initial tool 0 active and standby temperatures to 0C ; Custom settings are not defined ; Miscellaneous M911 S10 R11 P"M913 X0 Y0 G91 M83 G1 Z3 E-5 F1000" ; set voltage thresholds and actions to run on power loss
; deployprobe.g ; called to deploy a physical Z probe ; ; generated by RepRapFirmware Configuration Tool v3.3.0 on Sun Aug 15 2021 14:13:39 GMT+0100 (British Summer Time) M280 P0 S10 ; deploy BLTouch
; retractprobe.g ; called to retract a physical Z probe ; ; generated by RepRapFirmware Configuration Tool v3.3.0 on Sun Aug 15 2021 14:13:39 GMT+0100 (British Summer Time) M280 P0 S90 ; retract BLTouch
@Phaedrux I also am struggling to update it, when I upload the ZIP then run the M115 command after reboot I get...
M115 FIRMWARE_NAME: RepRapFirmware for Duet 3 MB6HC FIRMWARE_VERSION: 3.2.2 ELECTRONICS: Duet 3 MB6HC v1.01 or later FIRMWARE_DATE: 2021-02-11
@eegroeg I can confirm BLTouch is now Probing with M280 P0 S10/M280 P0 S90
Your command isn't correct. You're missing the pin name. You need:
M558 P9 C"^io7.in" H4 F120 T6000
Change that and send M98 P"config.g" again.
Where are you uploading it to? Should be the system tab.
@phaedrux That's great now M401 and M402 work! Thank you
@phaedrux Yeah I am in system tab and hit "upload system files then select the zip files which uploads them but when rebooting and running M115 no change.
Are you uploading the zip file as is? Don't extract it first.
@phaedrux Yeah I upload the zip as it is from my downloads and it uploads a load of items then restarts and M115 gives me the same output that it is still on M115
Try sending m997 in the console
m997
That's done it. Thank you for all your help BLTouch is working now and printer is updated
Can you post the results of M122?
Can you check the version of DWC as well? -
M122
Sorry for the delay please see my M122 results below. I am on DWC version 3.3.0M122 === Diagnostics === RepRapFirmware for Duet 3 MB6HC version 3.3 (2021-06-15 21:45:47) running on Duet 3 MB6HC v1.01 or later (standalone mode) Board ID: 08DJM-9P63L-DJMSS-6J9FD-3S86R-TBD39 Used output buffers: 3 of 40 (13 max) === RTOS === Static ram: 150904 Dynamic ram: 91676 of which 0 recycled Never used RAM 111612, free system stack 206 words Tasks: NETWORK(ready,30.3%,212) ETHERNET(notifyWait,0.2%,117) HEAT(notifyWait,0.0%,331) Move(notifyWait,0.0%,352) CanReceiv(notifyWait,0.0%,944) CanSender(notifyWait,0.0%,374) CanClock(delaying,0.0%,333) TMC(notifyWait,7.5%,93) MAIN(running,61.5%,1092) IDLE(ready,0.4%,29), total 100.0% Owned mutexes: === Platform === Last reset 00:00:28 ago, cause: power up Last software reset at 2021-08-31 21:43, reason: User, GCodes spinning, available RAM 108404, slot 0 Software reset code 0x0003 HFSR 0x00000000 CFSR 0x00000000 ICSR 0x00400000 BFAR 0x00000000 SP 0x00000000 Task MAIN Freestk 0 n/a Error status: 0x00 Step timer max interval 140 MCU temperature: min 19.1, current 27.7, max 27.9 Supply voltage: min 23.9, current 23.9, max 24.0, under voltage events: 0, over voltage events: 0, power good: yes 12V rail voltage: min 12.0, current 12.1, max 12.1, under voltage events: 0 Heap OK, handles allocated/used 0/0, heap memory allocated/used/recyclable 0/0/0, gc cycles 0 Driver 0: position 0, standstill, reads 25303, writes 14 timeouts 0, SG min/max 0/0 Driver 1: position 0, standstill, reads 25303, writes 14 timeouts 0, SG min/max 0/0 Driver 2: position 0, standstill, reads 25303, writes 14 timeouts 0, SG min/max 0/0 Driver 3: position 0, standstill, reads 25303, writes 14 timeouts 0, SG min/max 0/0 Driver 4: position 0, standstill, reads 25303, writes 14 timeouts 0, SG min/max 0/0 Driver 5: position 0, standstill, reads 25307, writes 11 timeouts 0, SG min/max 0/0 Date/time: 2021-08-31 21:48:07 Slowest loop: 7.54ms; fastest: 0.05ms === Storage === Free file entries: 10 SD card 0 detected, interface speed: 25.0MBytes/sec SD card longest read time 2.1ms, write time 0.0ms, max retries 0 === Move === DMs created 125, maxWait 0ms, bed compensation in use: none, comp offset 0.000 === MainDDARing === Scheduled moves 0, completed moves 0, hiccups 0, stepErrors 0, LaErrors 0, Underruns [0, 0, 0], CDDA state -1 === AuxDDARing === Scheduled moves 0, completed moves 0, hiccups 0, stepErrors 0, LaErrors 0, Underruns [0, 0, 0], CDDA state -1 === Heat === Bed heaters = -1 -1 -1 -1 -1 -1 -1 -1 -1 -1 -1 -1, chamberHeaters = -1 -1 -1 -1 === GCodes === Segments left: 0 Movement lock held by null HTTP is idle in state(s) 0 Telnet is idle in state(s) 0 File is idle in state(s) 0 USB is idle in state(s) 0 Aux is idle in state(s) 0 Trigger is idle in state(s) 0 Queue is idle in state(s) 0 LCD is idle in state(s) 0 SBC is idle in state(s) 0 Daemon is idle in state(s) 0 Aux2 is idle in state(s) 0 Autopause is idle in state(s) 0 Code queue is empty. === CAN === Messages queued 254, received 0, lost 0, longest wait 0ms for reply type 0, peak Tx sync delay 0, free buffers 49 (min 49), ts 142/0/0 Tx timeouts 0,0,141,0,0,111 last cancelled message type 30 dest 127 === Network === Slowest loop: 15.23ms; fastest: 0.02ms Responder states: HTTP(0) HTTP(0) HTTP(0) HTTP(0) HTTP(0) HTTP(0) FTP(0) Telnet(0), 0 sessions Telnet(0), 0 sessions HTTP sessions: 2 of 8 - Ethernet - State: active Error counts: 0 0 1 0 0 Socket states: 5 2 2 2 2 0 0 0
