ONE PING ONLY --- M42
@tecno what do you mean its still continuous?
Are you using M42 in your config.g? -
No M42 in config.g
M950 in config.g
M5000.g in sysConsole command M5000
It triggers but does it coninously instead of one shot
@tecno maybe 0.5s is too long, try reducing to P100
Otherwise it sounds like you might need to add something to pull it back down to ground once released? -
@jay_s_uk
Tested that still same issue -
@jay_s_uk said in ONE PING ONLY --- M42:
Otherwise it sounds like you might need to add something to pull it back down to ground once released?Take away the 1K serial resistor on output?
@tecno dunno, i'm not really an electronics guy
Tested = same issue
Hopefully sombody else chimes in ta advice what to try next.
Thanks !
What are the specs on the device you have connected to that output?
What does it expect to see in the way of signal voltage and duration?
@fcwilt said in ONE PING ONLY --- M42:
The IO output goes go GND to trigger camera ( switch is NO and swithes to ground )
https://forum.duet3d.com/topic/23976/mini5-bt-dongle-for-transmit/19
@tecno can you change the M950 to
M950 P0 C"^io1.out" Q1
Tried that still same issue with serial 1K, will test with no serial 1K
@tecno said in ONE PING ONLY --- M42:
IT WORKS NOW !!!
;Camera trigger
M950 P0 C"!io1.out" Q1Thank you guys, this forum is so helpful !
Glad to hear you got it working.
Do you understand why you needed that ! character?
Excellent.
I did say:
I would put a series resistor inline. Maybe 100 Ohms to 1,000 Ohms and try it.
So I was already thinking 1,000 Ohms might be too large.
I'm glad you stuck with the experiments and got it working!
IT WORKS NOW !!!
;Camera trigger
This inverts the signal and by that the level rises above the trigg point in the BT circuit, right?
@alankilian said in ONE PING ONLY --- M42:
Excellent.
I did say:
Experiments are always good as long one tries to follow good practis, in my case ask questions frequently.
Thanks for guidance!
IT WORKS NOW !!!
;Camera trigger
Correct.
Without that ! character the normal state of the output is low which is the state that triggers the camera. Adding that ! character makes the normal state of the output high.
