Sensor IR / BED
Hello, I know that surely this issue has been addressed, I cannot find the solution. I have an IR sensor, first calibrate the machine to make the 4 points where the threaded rods are, then it senses the bed, and this is the result. I need help., Thanks! I leave the configuration files and a couple of images[alt text](config.g bed.g image url)
Can you give us some more details about the printer?
Firmware version? Can you post the results of sending M122 and M98 P"config.g" in the gcode console?G31 P500 X0 Y0 Z-1.913
Your trigger height for the probe is set to nearly -2mm which means the probe is triggering when the nozzle is 2mm below the surface of the bed. That doesn't make any sense. You're also missing the X Y offset for the probe measured from the nozzle.Have you gone through this yet?
https://duet3d.dozuki.com/Wiki/Test_and_calibrate_the_Z_probePost your homeall and homez as well
@phaedrux
M98 P"config.g"
Error: in file macro line 14 column 29: M551: string too long
HTTP is enabled on port 80
FTP is disabled
TELNET is disabled
Warning: Heater 0 appears to be over-powered. If left on at full power, its temperature is predicted to reach 297C -
2.43mm sounds more reasonable. Did it have any effect?
@skafotrabo said in Sensor IR / BED:
That would be this line
M551 P"Fibertel WiFi098 2.4GHz" ; set passwordhttps://duet3d.dozuki.com/Wiki/Gcode?revisionid=HEAD#Section_M551_Set_Password
What do you have in homeall.g?
Your homeall isn't using the IR probe to home Z. This is part of your problem.
G91 ; relative positioning G1 H2 Z5 F6000 ; lift Z relative to current position G1 H1 X-305 Y305 F1800 ; move quickly to X or Y endstop and stop there (first pass) G1 H1 X-305 ; home X axis G1 H1 Y305 ; home Y axis G1 X5 Y-5 F6000 ; go back a few mm G1 H1 X-305 F360 ; move slowly to X axis endstop once more (second pass) G1 H1 Y305 ; then move slowly to Y axis endstop G90 ; absolute positioning ;G1 X40 Y40 F6000 ; go to first bed probe point and home Z ;G30 ; home Z by probing the bed ; Uncomment the following lines to lift Z after probing ;G91 ; relative positioning ;G1 Z5 F100 ; lift Z relative to current position ;G90 ; absolute positioning
You have the G30 commented out. So what do you have in homez? (which would get called next after homeall since Z axis wasn't homed)
hi this is my homez, i am using G30 here.
; homez.g ; called to home the Z axis ; ; generated by RepRapFirmware Configuration Tool v3.2.2 on Mon Jan 25 2021 21:42:05 GMT-0300 (hora estándar de Argentina) G91 ; relative positioning ; lift Z relative to current position G90 ; absolute positioning G1 X150 Y150 F3000; G30 X38 Y0 ; home Z by probing the bed ; Uncomment the following lines to lift Z after probing ;G91 ; relative positioning ;G1 Z5 F100 ; lift Z relative to current position ;G90 ; absolute positioning
And this is my start gcode
G90 ; use absolute coordinates M83 ; extruder relative mode M104 S[first_layer_temperature] ; set extruder temp M140 S[first_layer_bed_temperature] ; set bed temp M190 S[first_layer_bed_temperature] ; wait for bed temp M109 S[first_layer_temperature] ; wait for extruder temp G28 ; home all G32; G29 S1; G1 Z2 F240 G1 X-12 Y10 F3000 G1 Z0.28 F240
thanks in advance for your help.
; bed.g ; called to perform automatic bed compensation via G32 ; ; generated by RepRapFirmware Configuration Tool on Tue Oct 09 2018 13:27:56 GMT+0300 M291 P"sensando la malla" R"Probing.." S1 T2 ;M561 ; clear any bed transform G28 ; home all axis bb G30 P0 X0 Y11 Z-99999 ; probe near a leadscrew G30 P1 X255 Y11 Z-99999 ; probe near a leadscrew G30 P2 X255 Y290 Z-99999 ; G30 P3 X0 Y290 Z-99999 S4 ; G30; ;M557 X0:260 Y11:300 S80 ;M557 X0:275 Y40:300 S25 ; Define mesh grid ; Probe the bed and save height map to file M374 ; Save calibration data. Default is sys/heightmap.csv M291 P"sensado de malla finalizado !" R" S1 T2
; Configuration file for Duet WiFi (firmware version 3) ; executed by the firmware on start-up ; ; generated by RepRapFirmware Configuration Tool v3.2.2 on Mon Jan 25 2021 21:42:04 GMT-0300 (hora estándar de Argentina) ; General preferences G90 ; send absolute coordinates... M83 ; ...but relative extruder moves M550 P"My Printer" ; set printer name M669 K1 ; select CoreXY mode ; Network M551 P"Fibertel WiFi098 2.4GHz" ; set password M552 S1 ; enable network M586 P0 S1 ; enable HTTP M586 P1 S0 ; disable FTP M586 P2 S0 ; disable Telnet ; Drives M569 P0 S1 ; physical drive 0 goes atras x driver de x M569 P1 S1 ; physical drive 1 goes forwards driver de y M569 P3 S0 ; driver del extrusor M569 P5 S0; drivers del z en la duex M569 P6 S1; M569 P7 S0; M569 P8 S0; M584 X1 Y0 Z5:6:7:8 E3 ; set drive mapping M350 X16 Y16 Z16 E16 I1 ; configure microstepping with interpolation M92 X100 Y100 Z782.651 E837.00 ; set steps per mm M566 X900.00 Y900.00 Z60.00 E120.00 ; set maximum instantaneous speed changes (mm/min) ;M203 X6000.00 Y6000.00 Z180.00 E1200.00 ; set maximum speeds (mm/min) M203 X20000 Y20000 Z600 E2000 ;M201 X500.00 Y500.00 Z20.00 E250.00 ; set accelerations (mm/s^2) M201 X3000 Y3000 Z100 E5000 M906 X800 Y800 Z800 E800 I30 ; set motor currents (mA) and motor idle factor in per cent M84 S30 ; Set idle timeout M572 D0 S0.16 ; disabled Pressure advance M671 X-42:347:347:-42 Y320:320:-52:-52 S4; coordenadas definidas ; Axis Limits M208 X-18 Y0 Z0 S1 ; set axis minima M208 X305 Y330.3 Z700 S0 ; set axis maxima ; Endstops M574 X1 S1 P"xstop" ; configure active-high endstop for low end on X via pin xstop M574 Y2 S1 P"ystop"; PARA QUE EL HOME ESTE DEL OTRO LADO ; configure active-high endstop for low end on Y via pin ystop ;M574 Z1 S2 endostop quizas ; configure Z-probe endstop for low end on Z M591 P3 C"e0stop" S1 D0 ; sensor de filamento ; Z-Probe M558 P1 C"zprobe.in" H5 F120 T6000 ; sensor ir set Z probe type to unmodulated and the dive height + speeds G31 P500 X0 Y0 Z2.43 ; set Z probe trigger value, offset and trigger height M557 X0:260 Y30:300 S80 ; define mesh grid M591 D0 P5 C"e0_stop" R10:200 E3.0 S1 ; sensor de filamento ; Heaters M308 S0 P"bedtemp" Y"thermistor" T100000 B4138 ; configure sensor 0 as thermistor on pin bedtemp M950 H0 C"bedheat" T0 ; create bed heater output on bedheat and map it to sensor 0 M307 H0 R0.837 C325.8 D7.64 S1.00 V12.3 ; disable bang-bang mode for the bed heater and set PWM limit M140 H0 ; map heated bed to heater 0 M143 H0 S150 ; set temperature limit for heater 0 to 150C M308 S1 P"spi.cs2" Y"rtd-max31865" ; configure sensor 1 as thermocouple via CS pin spi.cs1 M950 H1 C"e0heat" T1 ; create nozzle heater output on e0heat and map it to sensor 1 M307 H1 B0 S1.00 ; disable bang-bang mode for heater and set PWM limit M143 H1 S280 ; set temperature limit for heater 1 to 280C ; Fans M950 F0 C"duex.fan3" Q500 ; create fan 0 on pin fan0 and set its frequency M106 P0 S0 H-1 ; set fan 0 value. Thermostatic control is turned off M950 F1 C"fan1" Q500 ; create fan 1 on pin fan1 and set its frequency M106 P1 S1 H1 T50 ; set fan 1 value. Thermostatic control is turned on ; Tools M563 P0 D0 H1 F0 ; define tool 0 G10 P0 X0 Y0 Z0 ; set tool 0 axis offsets G10 P0 R0 S0 ; set initial tool 0 active and standby temperatures to 0C ; Custom settings are not defined ; Miscellaneous M575 P1 S1 B57600 ; enable support for PanelDue ; Automatic power saving M911 S11 R13 P"M913 X0 Y0 G91 M83 G1 Z3 E-5 F1000" ; Set voltage thresholds and actions to run on power loss ; Custom settings are not configured https://mak3r.de/2020/04/03/stepper-driver-current-and-vref-calculator/ drivercalculator M564 H0 ; Let the Jog buttons work blv: added to allow jog buttons M501;
So in your slicer start gcode you're homing with G28, which probes Z at x150 y150 (correct? Or is it taking the X Y position you have specified in homez X38 Y0?) and then it calls bed.g (G32) which homes again. Then does 4 point leveling. And then calls G30 again. But where is that G30 in XY space? Same location as the last leveling probe point?
You should tidy things up a bit so that it's always setting Z0 with G30 at the same location, ideally in the center of the bed.
Did you measure the X Y offset for the probe yet? Without that it will be applying Z correction at the wrong location for the actual nozzle position.
https://duet3d.dozuki.com/Wiki/Test_and_calibrate_the_Z_probe#Section_Measuring_Probe_X_Y_Offset
@phaedrux I personally prefer to probe Z on a point that's coinciding with one of the grid points. If I can't easily probe the center with the grid (for example due to probe offsets and probe point setup), I prefer to probe Z at the location of the first probe point since that's easily derived from the mesh definition.
