BLtoch trigger event for sanity check
@engikeneer Thanks for your comment, sry I did not mention that I’ve already setup the BLtouch as Z-probe.
I've tested your recommendation.
First, I’ve tested the code for the "zProbeAsEndstop" object model:This is my test macro:
G91 ;relative positioning M564 H0 ;allow movement without homing G1 H2 Y-15 X15 F10000 ;lift y relative to current position M401 ;deploy probe G1 H1 Y-285 F2400 ;move Y down until BLTouch is triggered ;check status of Bltouch if sensors.endstops[1].triggered == true M291 P{" Probe triggered"} S1 G1 Y4 F30000 ;Backoff 3mm else M291 P{" Not recognized"} S1 G1 Y4 F30000 ;Backoff 3mm
Second test was the probe value itself:
This is the second test macro:
G91 ;relative positioning M564 H0 ;allow movement without homing G1 H2 Y-15 X15 F10000 ;lift y relative to current position M401 ;deploy probe G1 H1 Y-285 F2400 ;move Y down until BLTouch is triggered ;check status of Bltouch if sensors.probes[0].value[0] > 0 M291 P{" Probe triggered"} S1 G1 Y4 F30000 ;Backoff 3mm else M291 P{" Not recognized"} S1 G1 Y4 F30000 ;Backoff 3mm
Unfortunately, I always get "Not recognized" as message
@fcwilt because I use the BLtouch also for leveling purposes and I want to make use of this sensor as it is already mounted on the tool.
@semi55 said in BLtoch trigger event for sanity check:
If you are using it for leveling purposes how will it trigger when moving the Y axis?
@fcwilt I am using it on a belt printer with a tilted 45 degree axis, so the leveling happens on the Y-Axis
Interesting.
@semi55 I'm having the same problem with the probe value. After a major crash, putting together a BlTouch self-check macro. No matter what, I can't get the value to change unless the BlTouch is in the alarm mode.
@brainiac27 said in BLtoch trigger event for sanity check:
The value is changing but you are likely not going to be able to catch that change as it is quickly cleared.
@brainiac27 That is exactly what I've done right now as a work around. I let the BLtouch enter the alarm mode and use that as a trigger event for further commands.
@fcwilt Thanks for pointing that out, I now see how the probe value blips during a mesh level. Now I just check that the value is 0 before and after running a BlTouch self test for a couple seconds. Already saved my hide once while I figure out my intermittent issue.
