Need help with Ender-6 core xy motor movement
My guess is try :
M569 P0.0 S1
M569 P0.1 S1then
M569 P0.0 S0
M569 P0.1 S0then is trial and error until you find it turning in the right direction .
Just make sure that
G91
G1 H2 X10 F3000 ; goes right
G1 H2 Y10 F3000 : goes towards the back -
@peter247
Thanks for the response.I've tried these configs.
M569 P0.0 S0 ; physical drive 0.0 goes backwards
Y homes correctlyM569 P0.0 S1 ; physical drive 0.0 goes forwards
X homes towards Y frontM569 P0.0 S0 ; physical drive 0.0 goes backwards
M569 P0.1 S0 ; physical drive 0.1 goes backwards
X homes towards Y endstop in rearM569 P0.0 S1 ; physical drive 0.0 goes forwards
X homes correctlyDavid
@davidewen said in [Need help with Ender-6 core xy motor movement]
Just make sure it is moving correct .
You may have problem with the homing files or other configs .
post homeall.g
; homeall.g ; called to home all axes ; ; generated by RepRapFirmware Configuration Tool v3.2.3 on Fri Jul 23 2021 13:25:10 GMT-0700 (Pacific Daylight Time) G91 ; relative positioning G1 H2 Z5 F12000 ; lift Z relative to current position G1 H1 X255 Y255 F900 ; move quickly to X or Y endstop and stop there (first pass) G1 H1 X255 ; home X axis G1 H1 Y255 ; home Y axis G1 X-5 Y-5 F12000 ; go back a few mm G1 H1 X255 F450 ; move slowly to X axis endstop once more (second pass) G1 H1 Y255 ; then move slowly to Y axis endstop G90 ; absolute positioning G1 X47 Y15 F12000 ; go to first bed probe point and home Z G30 ; home Z by probing the bed ; Uncomment the following lines to lift Z after probing ;G91 ; relative positioning ;G1 Z5 F200 ; lift Z relative to current position ;G90 ; absolute positioning
Confused , why are you lift the tool head , homing twice , lower the tool head and homing again .
M913 X50 Y50 Z50 ; set X Y Z motors to 50% of their normal current G91 ; relative positioning G1 H2 Z5 F6000 ; lift Z relative to current position G1 H1 X 330 F3000 ; move quickly to X axis endstop and stop there (first pass) G1 H1 Y 330 F3000 ; move quickly to Y axis endstop and stop there (first pass) ;G1 H2 Z-5 F6000 ; lower Z again G90 ; absolute positioning M913 X100 Y100 Z100 ;
This is my X Y part of homeall.g
Peter,
This is all from the RRF Config Tool. https://configtool.reprapfirmware.orgI have not written any of the code.
I'm guessing that is for the EZAble Z-probe. Similar to the Prusa z-probe.
@davidewen Homeall.g is crazy but it still should home in the right direction .
Have you tried swapping the x , y stepper motors wires and tried the 4 motor possibilities ?
I have not swapped wires.
Correct me if I'm wrong, but isn't changing motor direction the same as changing the wires? So that would be redundant. -
@davidewen True , but you are also changing X , Y to Y , X
I don't mean change the wires of each motor , but swap left to right motor. -
Again, that would give me the same results, but with added effort of changing code.
I've done a little more testing. This time by phyiscal force.
I manually moved the X / Y axis and watched the motor directions.X - both motors move in the same direction
Y - motors move opposite of each otherSo, somehow I need to figure out how to make Duet do the same.
@davidewen Yes , mine is in the same direction on both motors .
But you still may need to swap motors . -
Check out these two posts they might help you get things straightened out.
https://forum.duet3d.com/topic/14971/vcore-pro-core-xy-the-x-and-y-axis-home-issue/4
https://forum.duet3d.com/topic/12676/mirrored-x-axis/9
The gist of it is to choose where the front of your printer is when looking at it straight on. 0,0 is the front left corner. X+ moves to the right, X- moved to the left, Y+ moves to the back, Y- moves to the front. That is the way it should be. If it's not like that yet, don't worry, we will make it that way. this is to match the slicer and CAD coordinate systems.
Then your endstop location is fixed either at the low end or high end of travel. That determines your M574 commands.
Then your homing directions will be positive or negative o move the head towards the endstops.
Now with all that fixed you can do the motor direction test in the corexy setup guide to determine what to do next.
@phaedrux
Thank you for your help.
Sorry for my delayed response. I was on vacation last week.Ender 6 physical setup
X & Y motors @ rear
X & Y stops @ maxNOTE: I had to swap X & Y at the Duet board to get the correct movement.
I have the X & Y axis moving correctly per your referenced link
https://duet3d.dozuki.com/Wiki/ConfiguringRepRapFirmwareCoreXYPrinterX homes correctly.
Y homes correctly.Thanks again!
David
Just to double check, try printing some text to see if anything is mirrored.
@phaedrux
I'm not to the point of printing yet. I don't even know how to load a file yet.I'm still trying to figure out the rest of the config.
I'm currently working on the Extruder.
I installed a Bondtech extruder. So far it's working, but not loading filament all the way, so I must have some parameters incorrectly set.So far I have the X, Y & Z axis moving in the correct directions and the endstops working.
The EZAble seems to be around 15mm off to the + side even though I have it set to +2mm.
First print completed.
I printed text to confirm no mirroring was happening.I had 2 problems.
1: 1st layer was crushed against the build plate. I had to babystep by 2.8 mm to get filament to come out. Homing Z works everytime. I used Cura to slice.2: print was horribly slow. It took 38m 27s to print "Duet 3 mini 5+" @ 0.6mm thickness.
I'm using mesh compensation, and it maps out the surface.
Printer is capable of moving 200mm/s.
Any suggestions for solving these 2 problems?
@davidewen said in Need help with Ender-6 core xy motor movement:
Calibrate your probe offsets.
Check your cura start gcode section for any speed commands that may be there overriding your config.g settings. Also make sure you're set to use RepRap Gcode flavour.
Post a sliced gcode file here if you're unsure.
Thanks. I'll calibrate the probe offsets.
I'm not sure about the RepRap flavor.
Here's the gcode that I ran.
Duet 3 mini 5.gcode -
;FLAVOR:RepRap ;TIME:388 ;Filament used: 0.145903m ;Layer height: 0.2 ;MINX:67.247 ;MINY:108.91 ;MINZ:0.2 ;MAXX:182.753 ;MAXY:141.085 ;MAXZ:0.8 ;Generated with Cura_SteamEngine 4.10.0 T0 M190 S50 M104 S200 M109 S200 M82 ;absolute extrusion mode M201 X500.00 Y500.00 Z100.00 E5000.00 ;Setup machine max acceleration M203 X500.00 Y500.00 Z10.00 E50.00 ;Setup machine max feedrate M204 P500.00 R1000.00 T500.00 ;Setup Print/Retract/Travel acceleration M205 X8.00 Y8.00 Z0.40 E5.00 ;Setup Jerk M220 S100 ;Reset Feedrate M221 S100 ;Reset Flowrate
You're ok for reprap flavor.
And as expected, these lines are causing the speeds to be slow.
Delete them from your start gcode.
