Cannot Connect to Duet 3 Web Control
@phaedrux Yeah doesn't light up with either computer or router
Alright, I think we've solved the firmware problem since it's able to speak with YAT now and it is taking and executing commands.
I think we have the SD card issue solved.
Can you post your current config.g from the /sys/ folder please?
Copy and paste the text please.
@phaedrux ; Configuration file for Duet 3 (firmware version 3)
; generated by RepRapFirmware Configuration Tool v3.2.3 on Thu Jul 15 2021 14:31:46 GMT-0700 (Pacific Daylight Time); General preferences
M550 P"My Printer" ; set printer name; Network
M552 P192.168.2.2 S1 ; enable network and set IP address
M553 P255.255.255.0 ; set netmask
M554 P192.168.1.254 ; set gateway
M586 P0 S1 ; enable HTTP
M586 P1 S0 ; disable FTP
M584 X0.0 Y0.1 Z0.2 E0.3 ; set drive mapping
M92 X80.00 Y80.00 Z400.00 E420.00 ; set steps per mm
M208 X230 Y210 Z200 S0 ; set axis maxima; Endstops
; WARNING: No endstops configured; Z-Probe
M558 P0 H5 F120 T6000 ; disable Z probe but set dive height, probe speed and travel speed
M557 X15:215 Y15:195 S20 ; define mesh grid; Heaters
M308 S0 P"temp1" Y"thermistor" T100000 B4138 ; configure sensor 0 as thermistor on pin temp1
M308 S1 P"temp0" Y"thermistor" T100000 B4138 ; configure sensor 1 as thermistor on pin temp0
M950 H1 C"out2" T1 ; create nozzle heater output on out2 and map it to sensor 1
M950 F0 C"out4" Q500 ; create fan 0 on pin out4 and set its frequency
M950 F1 C"!out6" Q500 ; create fan 1 on pin !out6 and set its frequency
@frank-0 said in Cannot Connect to Duet 3 Web Control:
Does this match the gateway you have set on your PC?
On your PC open a command prompt and send ipconfig and see what it says.
@phaedrux I currently use one ethernet running to the router so my computer has wifi. Then I use another ethernet connected to the board and the desktop (via USB adapter). Only one of the ethernet cords shows information about IP/gateway. And this one does not match
One last test before we call it hardware failure.
Edit your config.g and remove these lines entirely
; Network M552 P192.168.2.2 S1 ; enable network and set IP address M553 P255.255.255.0 ; set netmask M554 P192.168.1.254 ; set gateway
Replace them with just M552 S1 and boot up with the Duet connected to your router. It should attempt to get a DHCP address. If the port LEDs light up, then we just need to query the Duet in YAT to get the IP address.. IF no lights, then the port is probably dead and we will replace the board under warranty.
@phaedrux I removed the lines and replaced it with M552 S1. I plugged in the USB on the duet and connected ethernet to router. Nothing happened. I opened YAT and tried some commands, but nothing has changed. Still no lights.
When and where did you purchase your product?
Please send an email to warranty@duet3d.com and CC your reseller. Include a link to this forum thread and the details of your original purchase. You'll receive a reply with a form to fill out.
Sorry for the inconvenience.
