Very Slow movement
I just updated my Duet2 Wifi to the newest firmware (it was on 1.21) and set it up on my Ender 5. I am having a strange issue though. The printer moves very slowly. I have the maximum feed rates set to 6000 mm/min, but whenever I have it move it maxes out at 3mm/sec. (It shows that rate in webcontrol.) It doesn't matter what I put in to M0 for the feed rate, it always moves at 3mm/sec. Anyone have any ideas?
Here is my config:
; generated by RepRapFirmware Configuration Tool v3.2.3 on Sun Jul 04 2021 15:43:12 GMT-0600 (Mountain Daylight Time); General preferences
M550 P"Ender5" ; set printer name; Network
M552 S1 ; enable network
M586 P0 S1 ; enable HTTP
M586 P1 S0 ; disable FTP
M569 P2 S0 ; physical drive 2 goes backwards
M92 X80.00 Y80.00 Z800.00 E420.00 ; set steps per mm
M208 X220 Y220 Z300 S0 ; set axis maxima; Endstops
M574 Z1 S1 P"zstop" ; configure active-high endstop for low end on Z via pin zstop; Z-Probe
M558 P0 H5 F120 T6000 ; disable Z probe but set dive height, probe speed and travel speed
M557 X15:215 Y15:195 S20 ; define mesh grid; Heaters
M307 H0 B0 R0.309 C430.5 D2.68 S1.00 V24.1 ; disable bang-bang mode for the bed heater and set PWM limit
M307 H1 B0 R2.770 C126.2:126.1 D5.69 S1.00 V24.2 ; disable bang-bang mode for heater and set PWM limit
M143 H1 S250 ; set temperature limit for heater 1 to 280C; Fans
;M950 F1 C"fan1" Q500 ; create fan 1 on pin fan1 and set its frequency
;M106 P1 S1 H1 T45 ; set fan 1 value. Thermostatic control is turned on; Tools
During a print, or when jogging after homing? Is homing the correct speed?
@phaedrux It is slow during a print and while homing and doing M0 moves. The steps per mm seem right, since it goes to the correct locations, just very slowly.
Actually, I restarted the printer and it seems to be working better now. I'll see if it happens again.
@fredjikrang probably the start gcode in your slicer changing the print speed
@jay_s_uk Yup, that's what it was. My slicer was still set to Marlin style g-code, so it was outputting speeds in mm/s instead of mm/min. I cleaned it up. Thanks!
