3.3.0 upgrade !!!!
Well it upgraded without a problem which is more than I could say about the change from 3.1.1 to 3.2.2.
one little problem is if I go into object model I get a : Documentation is not available (/www/DuetAPI.xml not found)
@peter247 Thanks for the note, it looks like that file wasn't included in the ZIP files. I've updated the DWC and Duet2and3Firmware archives. You can upload that particular file from the DuetWebControl-SD.zip file on the System Files page, then you should be able to view the object model documentation when you select a node in the OM browser.
@chrishamm Next little error : the endstop plug in is found [here]https://github.com/Duet3D/DSF-Plugins/releases/tag/v3.3.0() , 404 error .
@peter247 Thanks, now released.
@peter247 shouldn't have the brackets on the end: https://github.com/Duet3D/DSF-Plugins/releases/tag/v3.3.0
