Webcontrol and filament sensor
The machine properties tab has been moved to a plugin and I think will be included with the 3.3 release. Otherwise it can be found here: https://github.com/Duet3D/DSF-Plugins/tree/master/EndstopsMonitor
In the meantime you can still check endstop status with M119.
For a filament sensor you'd want to use M591 instead of M581.
https://duet3d.dozuki.com/Wiki/Gcode#Section_M591_Configure_filament_sensing
@phaedrux Thank you for the reply.
But so far i was unsucesful.
I have tried to install the plugin but for some reason it does not want to work.
I have exported the "Monitor Plugin" to the src/plugin folder and even modified "Index.js" as instructed, but it still doesnt show up in the "plugins" folder in webcontroll.
Meanwhile i also tried to setup the fil sensor but that too didnt manage to get it working i will send the config file also if you could please take a look if i have it setup corectly.
Thank you very much.; Drives
M350 Z8 X16 Y16 I1 ; Configure microstepping with interpolation
M350 E32 I0 ; Configure microstepping without interpolation
M92 X50 Y50 Z400 E280 ; Set steps per mm
M566 X480 Y480 Z2 E270 ; Set maximum instantaneous speed changes (mm/min)
M203 X12000 Y12000 Z720 E7200 ; Set maximum speeds (mm/min)
M201 X1000 Y1000 Z125 E5000 ; Set accelerations (mm/s^2)
M906 X1500 Y1500 Z2000 E700 I1 ; Set motor currents (mA) and motor idle factor in per cent
M84 S5 ; Set idle timeout; Axis Limits
M208 X0 Y0 Z0 S0 ; Set axis minima
M208 X545 Y545 Z700 S0 ; Set axis maxima; Endstops
M574 X1 S1 P"!xstop" ; configure active-high endstop for low end on X via pin xstop
M574 Y2 S1 P"!ystop" ; configure active-high endstop for low end on Y via pin ystop
;M574 Z1 S2 ; configure Z-probe endstop for low end on Z; Z-Probe
M950 S0 C"exp.heater3" ; create servo pin 0 for BLTouch
M558 P9 C"^zprobe.in" A5 H4 F100 T6000 ; set Z probe type to bltouch and the dive height + speeds
G31 X0 Y0 Z0.9 ; set Z probe trigger value, offset and trigger height
M557 X0:500 Y40:500 S100:100 ; define mesh grid;Filament Runout Sensor
M950 J0 C"!e0stop" ; create switch pin
M591 P2 C"e0stop" S1 D0 ; filament monitor connected to E0 endstop; Heaters
M143 H0 S100 ; set temperature limit for heater 0 to 100C
M307 H1 B0 S1.00 ; disable bang-bang mode for heater and set PWM limit; Fans
M106 P0 S1 H-1 ; set fan 0 value. Thermostatic control is turned off
M106 P1 S0.5 H1 T60 ; set fan 1 value. Thermostatic control is turned on
M950 F2 C"fan2" Q500 ; create fan 2 (bed) on pin fan2 and set its frequency
M106 P2 S1 H0 T50; Tools
M563 P0 D0 H1 ; Define tool 0
G10 P0 R20 S0 ; Set initial tool 0 active and standby temperatures to 0C;LED control
M950 P5 C"e1heat" ;set e1heat as a GPIO output pin
M501
M107 -
@deluxe-600 said in Webcontrol and filament sensor:
M591 P2 C"e0stop" S1 D0 ; filament monitor connected to E0 endstopI don't think you need the M950 here and that may be your problem.
Can you send M98 P"config.g" and see if it shows any syntax errors.
@deluxe-600 I maybe wrong, but I get the impression from your post that you did not compile the endstops plugin before you attempted to install it. Copying the files as you describe will not typically work. Unless you have a dev environment already setup / or are willing to set one up, then I think you have 2 options:
1: Enable the object model browser built-in plugin and use it to check if the sensor is working as expected (you will have to refresh it each time you want to check status).
2: Use BtnCmd to make your own endstops monitor in the browser.Option 1 would be the easiest as its already available with no additional work, and unless you want a permanent endstop monitor, it will probably work OK.
You could also be cheeky and ask if anyone on the forum has a pre-compiled zip of the endstops monitor @Phaedrux linked to. Or just install the pre-compiled version I completely missed as @jay_s_uk says below. (even better!!) -
There is a release available here https://github.com/Duet3D/DSF-Plugins/releases
@jay_s_uk Thanks. I should be using that link instead.
@phaedrux And it works
. Thank you guys. Now only to solve the filament sensor, working on it right now. Im trying to use the sensor from Prusa MINI but it seems to need 5V power. So i conected the power pin one the sensor to the always on FAN that has 5V.
@jay_s_uk It works! Thank you
. But the filament sensor doesnt show up, thats strange isnt it? I just have X,Y,Z endstops in the "ENDSTOPS" page
@deluxe-600 filament sensors are different to endstops and that's why they don't show up
@phaedrux Never mind i figured it out.
For anyone wondering the gcode that worked is M591 P1 C"e0stop" S1 D0Thank you all for the help, you are the best
Sending M591 by itself will report info on the sensor.
