Requirements to have a 1000x1000 aluminium build plate
@jens55 that's 11/2 hrs to gain 20 deg F. So to go from say 20 deg C to 60 deg C would take about 6 hrs assuming that heater would go that far. But then counter tops aren't normally 150mm thick like a granite surface plate so I'd say multiple that by 5 giving around 30 hours (and probably about the same amount of time to cool again).
@jens55 said in Requirements to have a 1000x1000 aluminium build plate:
I get impatient after a couple of minutes
My configs were set to F6000 [Phaedrux cringed]
@deckingman said in Requirements to have a 1000x1000 aluminium build plate:
Just out of interest, I checked the cost of granite surface plates here in the UK. 1,000mm x 1,000mm comes at a thickness of 150mm, cost is about £1,850 and it weighs in at 450 Kgs.
Maybe you can find a cheaper one at your local tombstone makers? They often have 2nd hand stones
@slimshader hey thanks for the insights. I'm not a first time builder, and all of these "safety" aspects are built into my current (pardon the pun) 525x525x8.5mm build plate.
8.5mm? Yep it was an extruded aluminium plate milled down from 10mm to until had <= 0.1mm deviation across the surface. This is kinematically mounted, so expansion is taken into account. Mains powered/SSR, of course, fuse, of course.
Weight is easy to calculate once I know a thickness that is required to reduce the bowing to an acceptable level.
Thanks again.
@theruttmeister yep much of what you've said on aluminium I've either done on previous build (525x525 + kinematic mounts). The granite is a fascinating idea too.
Here in Perth, Western Australia, we focus on getting iron ore out of the ground. So buying a tipping tray for a 250tonne capacity hail pack is easier than getting MIC6. Typically we have to wait weeks. Also shipping interstate at rates where shipping doesn't rise above material cost, can take weeks, if needed the thing you want is available in country.
So sometimes we have to get creative
@jens55 I do like the look of that. Reminds of the Jubille. Very clean build.
Cheating? Who made the rules?
@o_lampe I did contact one tombstone supplier, but they were a dead loss!
I don't know if it was CoVid invoked, but the guy couldn't stop coffin. (ouch)
I think if anybody could make a printer lift a monolithic build plate, it would be @deckingman
@jens55 we are kindred spirits.
So the best answer to the question sounds like ~22mm
@vistalert said in Requirements to have a 1000x1000 aluminium build plate:
I am glad you like that build .... alas, it isn't my build. I seem to think that @Tinken posted the picture.
Talk to a a supplier out of china. You can get just about any thickness and size. Getting something from a supplier like Starret requires you convincing them to violate all their company values.
Heck, I'd probably start by going to my local kitchen granite store with a straight edge. You'd be shocked how flat just regular granite slabs are once they polish them.
And the 305x305mm granite bed I built back in the day took 4-8 times longer to heat up and probably even longer to cool down, compared to MIC6.
we live in the most remote city in the world
I lived in the Other Perth once, long ago. Not as much sun, but much more convenient... for just about everything!
I applaud your ambitions efforts, but your expectations for a flat heated bed of this size are unreasonable withough significant expense and fabrication.
Speaking as someone who has the both the schooling, academic references and software for analysis and design this sort of thing, and the access to the tools, equipment and material suppliers for what your are asking, i would advise against it.
Look a the various videos on youtube for surface plate calibration and look the ribbing on the cast iron ones and the thickness of the granite ones.
I went to a graveyard and there were a bunch of guys walking round and round with a coffin. They'd obviously lost the plot..........
@theruttmeister - I've never been to the "real" Perth, but I'm originally from Yorkshire. But you could tell that from the accent, right?
@deckingman Gold!
@sinned6915 I'm not sure I actually stated any expectations, nor questioned anyone's credentials. I'm here to seek a simple answer. The simple answer to the question just needs to be "a plate of x and y size, needs to be z thick". Based
on many other factors then I can make a decision, with one more blank filled in.I've seen terrible warped beds work "ok" (I used to have one). So I know not to "need" perfection. I'm pragmatic.
Many times I've got through life with "good enough" solutions, by listening, learning and then acting, learning some more when I stuff up, and iterating. That's all I'm doing here. I'm not sure how the impression was gained that I'd be acquiring iron or granite plates. I just find this diverse thinking interesting and educational.
@vistalert you are missing the point. everyone is telling you its not a good idea and why.
i'm telling you that even with the 'credentials' and tools, I would not attempt it.'resonable deflection' means what exactly? 0.1mm? 0.05mm? you want to 'know' how much- look up plate deflection equations, there are plenty online, and calc it. 3 point will be worse than 4 point, so stick with 4 point.
i would not be surprised that to hold 0.1mm or less on 1m, you will end up with a Mic6 plate at least an inch in thickness. that will be on the order of 200-250 pounds.
cast iron surface plates are a corrolary as to how the world makes things so that they stay FLAT, flat as in refernce surfaces to know ant trust as flat.
@sinned6915 said in Requirements to have a 1000x1000 aluminium build plate:
'Everyone'?
Please, I can speak for myself...
A few people mentioned how to build a subframe; how to support and adjust a reasonable thick MIC6 plate.
It's not done in an evening, but doable. -
That must've been a 'Thriller' ?
i'm telling you that even with the 'credentials' and tools, I would not attempt it...............i would not be surprised that to hold 0.1mm or less on 1m, you will end up with a Mic6 plate at least an inch in thickness. that will be on the order of 200-250 pounds.
Err, the density of aluminium is around 2.7 gms/cm^3. A plate 1metre square would be 10,000 cm^2 (100 x 100). 1 inch is roughly 2.5cm so 10,000 x 2.5 = 25,000 cm^3 x 2.7 = 67500 gms = 67.5Kgs = about 148lbs. So your weight calculation of 200 - 250 lbs is out by a significant amount. But with a support frame that some of us have mentioned, the thickness could be halved bring the weight down to about 34 Kgs or around 76 lbs. I'd say it's doable without too much trouble (costly at around £600 for 12mm thick cast aluminium tooling plate but doable).
