Use PrusaSlicer with pspp, temperature management issues
Dear friends:
My E3D Toolchanger is still debugging so far. Currently my machine only has two nozzles. My slicing software is PrusaSlicer 2.3.0, used with pspp, but I encountered a problem during the debugging process:
Two print heads printing:
When the No. 0 nozzle is activated, the working temperature of No. 0 nozzle is 200 and the idle temperature of No. 1 nozzle is 170.
However, when the No. 1 nozzle is activated, the working temperature of the No. 1 nozzle is also 170. The idle temperature of the No. 0 nozzle is 170 normal.
I checked the parameter settings of my PrusaSlicer, and the working temperature of the print head is 200.
Please check my configuration parameters:
May I ask what causes this?
Looking forward to your reply. -
@charles said in Use PrusaSlicer with pspp, temperature management issues:
pspp
Sorry, what is pspp?
Can you post your config.g and tool change files? Perhaps a sample of the gcode that is being used so we can see what is happening?
What firmware version?
@phaedrux Hello Phaedrux,
Thank you for your reply.pspp is Tool Changer Prusa Slicer post process cript. Its github address is: https://github.com/mkudzia84/toolchanger-pspp/tree/master
I am currently on a business trip and do not have a configuration file in my hand. I will release it to you when I get home. The firmware version is v3.1.1.
The firmware I currently use is the configuration file of Nibbels, and the github address is: https://github.com/Nibbels/e3d-toolchanger-config/tree/master
