Using Cura - Network Error
Hello all,
I've got everything set up for my FT-6. But I am getting a network error when I try to upload gcode to it for printing. Originally I was trying to upload from Cura, but got Network Error 99. Since then I have simply saved the gcode to my computer and am trying to upload it using the web control and getting another error. I am not sure what is causing it, or how to just bypass it for now to start my first test print on this machine.
See below:
1/27/2020, 1:10:55 PM Failed to upload UMS5_xyzCalibration_cube.gcode
Network error
1/27/2020, 1:08:47 PM M122
RepRapFirmware for Duet 2 WiFi/Ethernet version 2.04 running on Duet WiFi 1.02 or later
Board ID: 08DGM-917DA-G4MSJ-6J9FG-3S46K-1SP3B
Used output buffers: 3 of 24 (8 max)
Static ram: 25680
Dynamic ram: 93136 of which 0 recycled
Exception stack ram used: 396
Never used ram: 11860
Tasks: NETWORK(ready,764) HEAT(blocked,1232) MAIN(running,3816) IDLE(ready,200)
Owned mutexes:
Last reset 00:05:14 ago, cause: power up
Last software reset at 2020-01-27 00:08, reason: User, spinning module GCodes, available RAM 11916 bytes (slot 2)
Error status: 0
Free file entries: 10
SD card longest block write time: 47.8ms, max retries 0
MCU temperature: min 31.2, current 35.1, max 35.3
Supply voltage: min 24.1, current 24.3, max 24.5, under voltage events: 0, over voltage events: 0, power good: yes
Driver 0: standstill, SG min/max 125/176
Driver 1: standstill, SG min/max 0/59
Date/time: 2020-01-27 13:08:45
Cache data hit count 1162840946
Slowest loop: 96.74ms; fastest: 0.06ms
Hiccups: 0, FreeDm: 160, MinFreeDm: 158, MaxWait: 15951ms
=== DDARing ===
Scheduled moves: 7, completed moves: 7, StepErrors: 0, LaErrors: 0, Underruns: 0, 0
Heater 0 is on, I-accum = 0.3
Heater 2 is on, I-accum = 0.3
Segments left: 0
Movement lock held by null
http is idle in state(s) 0
telnet is idle in state(s) 0
file is idle in state(s) 0
serial is idle in state(s) 0
aux is idle in state(s) 0
daemon is idle in state(s) 0
queue is idle in state(s) 0
Code queue is empty.
=== Network ===
Slowest loop: 184.47ms; fastest: 0.00ms
HTTP sessions: 1 of 8- WiFi -
Network state is running
WiFi firmware version 1.22
WiFi MAC address cc:50:e3:0d:1c:a8
WiFi Vcc 3.38, reset reason Turned on by main processor
WiFi flash size 4194304, free heap 27584
WiFi IP address 192.168.1.106
WiFi signal strength -74dBm, reconnections 0, sleep mode modem
- WiFi -
I would suggest you start by updating your firmware to 2.05 and the wifi server to 1.23. Possibly also your DWC files.
The easiest way would be to upload this single zip file to the system page. The duet should do the rest.
https://github.com/dc42/RepRapFirmware/releases/download/2.05/Duet2Firmware-2.05.zip
@Sqwuid said in Using Cura - Network Error:
Your wifi strength is also border line.
See this for possible improvement options https://duet3d.dozuki.com/Wiki/WiFi_disconnections_and_AJAX_timeout_errors
I had some power outages and now my printer won't connect via the web control. I see it on the network but I just keep getting error 99 from Cura. I want to do the update you mention, but I'm not sure A) how to connect through the USB B) Where to put the file. When you said that the Duet3d should do the rest, then all the updates should be automatic, as in there is nothing I need to do?
@hbrownell I think you should start a new thread and provide as much detail as possible about your setup and the problem.
