BLTouch won`t home
@chrabban said in BLTouch won`t home:
Error: Bad command: Z-Probe
Post your config.g. You're probably missing a
to comment out a line.@chrabban said in BLTouch won`t home:
G1 H1 Z-405 F360 ; move Z down stopping at the endstop
G90 ; absolute positioning
G92 Z1 ; set Z position to axis minimum (you may want to adjust this)This is setup to use an endstop, not the probe. Replace those lines with
G90 ; absolute position G1 X150 Y150 F6000 ; move probe to center of bed G30 ; probe the bed with the probe
And your deployprobe.g and retractprobe.g files need to be in the /sys/ folder with the correct commands in them.
EDIT: @DIY-O-Sphere has ya covered.
@phaedrux Hello, i tried it and now it will home the Z axis but when the probe have probed the middle of the bed it just starts to go up and up and up
any ideas ?
The M401 and M402 works also by the way
@chrabban
Please provide the config. g -
@diy-o-sphere
here it is; Configuration file for Duet WiFi (firmware version 3)
; generated by RepRapFirmware Configuration Tool v3.2.3 on Thu Apr 22 2021 13:01:55 GMT+0200 (centraleuropeisk sommartid); General preferences
M550 P"CR-10" ; set printer name; Network
M552 S1 ; enable network
M586 P0 S1 ; enable HTTP
M586 P1 S0 ; disable FTP
M569 P0 S0 ; physical drive 0 goes backwards
M569 P2 S0 ; physical drive 2 goes backwards
M92 X80.00 Y80.00 Z1600.00 E415.00 ; set steps per mm
M566 X900.00 Y900.00 Z120.00 E120.00 ; set maximum instantaneous speed changes (mm/min)
M84 S20 ; Set idle timeout; Axis Limits
M208 X300 Y270 Z400 S0 ; set axis maxima; Endstops
M574 Y1 S1 P"ystop" ; configure active-high endstop for low end on Y via pin ystopZ-Probe
M950 S0 C"exp.heater3" ; create servo pin 0 for BLTouch
M558 P9 C"^zprobe.in" H5 F120 T6000 ; set Z probe type to bltouch and the dive height + speeds
G31 P500 X0 Y0 Z1.842 ; set Z probe trigger value, offset and trigger height
M557 X20:280 Y75:270 S20 ; define mesh grid; Heaters
M308 S1 P"e0temp" Y"thermistor" T100000 B4725 C7.06e-8 ; configure sensor 1 as thermistor on pin e0temp
M106 P0 S0 H T45 ; set fan 0 value. Thermostatic control is turned on
M106 P1 S1 H-1 ; set fan 1 value. Thermostatic control is turned off
M950 F2 C"fan2" Q500 ; create fan 2 on pin fan2 and set its frequency
M106 P2 S1 H-1 ; set fan 2 value. Thermostatic control is turned off; Tools
M563 P0 S"Nozzle" D0 H1 F0 ; define tool 0
T0 ; select first tool -
M574 Y1 S1 P"ystop" ; configure active-high endstop for low end on Y via pin ystopAdd that at the end of the section
What does your homeall look like now?
@phaedrux it looks like this
; homeall.g
; called to home all axes
; home Z by probing the bedG91 ; relative positioning
G1 H2 Z5 F12000 ; lift Z relative to current position
G1 H1 X-305 Y-275 F1800 ; move quickly to X and Y axis endstops and stop there (first pass)
G1 H2 X5 Y5 F12000 ; go back a few mm
G1 H1 X-305 Y-275 F360 ; move slowly to X and Y axis endstops once more (second pass)
G30 ; probe the bed with the probe; Uncomment the following lines to lift Z after probing
G1 Z5 F200 ; lift Z relative to current position
G90 ; absolute positioning -
now when it tries to home Z it goes upp insted of down to check bed lvl and wont stop, this worked before but it whold run away after the bed lvl check
I don't suppose you could show a video of what it's doing?
Can't get why....
Just one point to look at later on: Bltouch offset
X0 Y0 can't be right, means Bltouch is mounted in the center of the nozzle
@phaedrux
sorry for the late awnser, sick kids has taken almost all of my time.
well it just homes y and x then goes to the center and goes of into spaceit dosent do anything els
it is a bit strange i know.
yea i know, i havent fixed that one, it sits in front of the hotend, i will put in the right numbers later
well it just homes y and x then goes to the center and goes of into space it dosent do anything elsIs the probe deployed? Does it stop moving if you hit the pin?
If you send G92 Z10 to force it into a homed position so you can jog the axis, does it move the correct direction? -z moving the print head and bed closer? +z moving them farther away.
If it's moving in the wrong direction you'll have to change the direction of rotation in the M569 command for the z driver.
That could explain why a G30 would move it in the wrong direction.
