Variable Enclosure Fans based on Temperature (no heater)
Hiya - I'm trying to wire up a couple fans (intake and exhaust) into a CNC enclosure so they only turn on at particular internal temperature. They are a bit noisy so this is why I'm doing it.
I defined the thermistor with:
M308 S0 P"e0temp" Y"thermistor" A"Enlosure_Temp"
M950 F0 C"fan1+fan2"
M106 P0 T50 H0Is this something possible to do without creating a heater. Plus is it possible to refer to the onboard CPU temperature?
Many thanks, Savvas
I would use daemon.g with that and conditional gcode. Already read through the Duet documentation about the topic?
@educatingsavvas you can only set one pin per M950 command
M308 S0 P"e0temp" Y"thermistor" A"Enlosure_Temp" M950 F0 C"fan1" M950 F1 C"fan2" M106 P0 T50 H0 M106 P1 T50 H0
that should do, although don't forget to add the thermistor information to the M308 (at a minimum the T and B values)
@argo it's been a little while since I played around with the conditional gcode but will give it a go when I next have time.
@jay_s_uk I pulled out the thermistor from an old 3D printer so might not know the values for those. But will tinker on the weekend.
@educatingsavvas said in Variable Enclosure Fans based on Temperature (no heater):
Yes it is.
M308 S0 P"mcu-temp" Y"mcu-temp"
I can confirm this works. My fans are still noisy when they do turn on, but they are on for small amounts of time.
M308 S0 P"mcu-temp" Y"mcu-temp" M950 F0 C"Fan1" ;Intake M106 P0 T36 H0 ; M950 F1 C"Fan2" ;Exhaust M106 P1 T36 H0 ;
Many thanks, Savvas
You might be able to experiment with the min/max speed settings as well as the PWM frequency to see if you can improve the sound.
https://duet3d.dozuki.com/Wiki/Gcode#Section_M106_Fan_On
https://duet3d.dozuki.com/Wiki/Gcode#Section_M950_Create_heater_fan_spindle_or_GPIO_servo_pin
