Duet3 Mini 5+ - strange messages, Do I run my first print?
So I am about to perform my first test print.
I trammed my bed cold, then heated it to my working temp, every time I tram it I am getting 'Network errors' instead of reporting back the adjustments made30/03/2021, 11:03:14 M98 P"0:/macros/2_Tram_Bed.G" Error: Network error 30/03/2021, 11:01:44 M98 P"0:/macros/2_Tram_Bed.G" Error: Network error 30/03/2021, 10:44:08 Bed Traming Cycle: 1 - Difference was 0.008mm 30/03/2021, 10:44:08 Leadscrew adjustments made: 0.014 0.026 0.039, points used 3, (mean, deviation) before (0.025, 0.008) after (0.000, 0.000)
Macros.
Tram_Bed runs a G32.
Bed.g; New 2/5/2020 ;M98 P"0:/macros/Lighting/Red-On.g" if !move.axes[0].homed || !move.axes[1].homed ; If the printer hasn't been homed, home it M98 P"0:/sys/homex.g" ; home x M98 P"0:/sys/homey.g" ; home Y M98 P"0:/sys/homez.g" ; home z ; M561 ; clear any bed transform ;M558 P9 H5 F120 T24000 ; increase dive height ;M98 P"0:/sys/bed_FourScrews.g" ; perform bed tramming M98 P"0:/sys/bed_ThreeScrews.g" ; perform bed tramming ; echo "Bed Traming Cycle: 1 - Difference was " ^ move.calibration.initial.deviation ^ "mm" ; while move.calibration.initial.deviation >= 0.009 ; 0.01 perform additional tramming if previous deviation was over 0.02mm if iterations = 5 abort "Too many auto tramming attempts" M98 P"0:/sys/bed_ThreeScrews.g" echo "Bed Traming Cycle: " ^ iterations + 2 ^ " - Difference was " ^ move.calibration.initial.deviation ^ "mm" continue ; G28 Z ; home z
Config.g
; General preferences G90 ; send absolute coordinates... M83 ; ...but relative extruder moves M550 P"RailCore II" ; set printer name M669 K1 ; select CoreXY mode G4 S1 ; wait for expansion boards to start ; Drives M569 P0.0 S1 ; X Axis - physical drive 0.0 goes forwards M569 P0.1 S0 ; Y Axis - physical drive 0.1 goes backwards M569 P0.2 S1 ; Left Front physical drive 0.2 goes forwards M569 P0.3 S1 ; Left Rear physical drive 0.3 goes forwards M569 P0.4 S1 ; Right physical drive 0.4 goes forwards M569 P20.0 S0 ; Extruder - physical drive 20.0 goes forwards M584 X0.0 Y0.1 Z0.2:0.3:0.4 E20.0 ; set drive mapping ; M350 X16 Y16 Z16 E16 I1 ; configure microstepping with interpolation ; M92 X200.00 Y200.00 ; set steps per mm M92 Z1600 ; set steps per mm Z Axis M92 E412 ; set steps per mm Extruder ; M566 X600.00 Y600.00 Z200.00 E3600.00 ; set maximum instantaneous speed changes (mm/min) M203 X18000.00 Y18000.00 Z900.00 E3600.00 ; set maximum speeds (mm/min) M201 X1500.00 Y1500.00 Z250.00 E1500.00 ; set accelerations (mm/s^2) M906 X1280 Y1280 Z1220 E700 I30 ; set motor currents (mA) and motor idle factor in per cent M84 S30 ; Set idle timeout ; Leadscrew locations ;New 4-2-21 M671 X-1:-1:350 Y24:281:151 S7.5 ; Axis Limits ;M208 X0 Y0 Z0 S1 ; set axis minima ;M208 X230 Y300 Z400 S0 ; set axis maxima M208 X-10:300 Y0:300 Z-0.5:500 S0 ; Endstops M574 X1 S1 P"io5.in" ; configure active-high endstop for low end on X via pin io5.in M574 Y1 S1 P"20.io2.in" ; configure active-high endstop for low end on Y via pin 20.io1.in ; Z-Probe - ToolBoard 1LC M950 S0 C"20.io0.out" ; create servo pin 0 for BLTouch M558 P9 C"^20.io0.in" H5 F120 T6000 ; set Z probe type to bltouch and the dive height + speeds G31 P500 X-7 Y35 Z0.904 ; set Z probe trigger value, offset and trigger height ;M557 X15:215 Y15:195 S20 ; define mesh grid M557 X30:280 Y45:240 S20 ; Z-Probe - Using io_1 ;M950 S0 C"io1.out" ; create servo pin 0 for BLTouch ;M558 P9 C"^io1.in" H5 F120 T6000 ; set Z probe type to bltouch and the dive height + speeds ;G31 P500 X-7 Y35 Z2.5 ; set Z probe trigger value, offset and trigger height ;M557 X15:215 Y15:195 S20 ; define mesh grid ; Heaters M308 S0 P"temp0" Y"thermistor" A"Heated Bed" T100000 B4138 ; configure sensor 0 as thermistor on pin temp0 M950 H0 C"out0" T0 ; create bed heater output on out1 and map it to sensor 0 ;M307 H0 B0 S1.00 ; disable bang-bang mode for the bed heater and set PWM limit M307 H0 R0.853 C250.9 D5.98 S0.60 ; tuned to 50degrees - 28/3/21 M140 H0 ; map heated bed to heater 0 M143 H0 S120 ; set temperature limit for heater 0 to 120C M308 S1 P"20.temp0" Y"thermistor" A"Mosquito" T500000 B3950 ; configure sensor 1 as thermistor on pin 20.temp0 M950 H1 C"20.out0" T1 ; create nozzle heater output on 20.out0 and map it to sensor 1 ;M307 H1 B0 S1.00 ; disable bang-bang mode for heater and set PWM limit M143 H1 S280 ; set temperature limit for heater 1 to 280C M307 H1 R1.632 C237.7 D6.86 S1.00 V24.2 ; Other Thermistors M308 S2 P"temp1" Y"thermistor" A"Bed-Top" T100000 B4138 ; configure sensor 0 as thermistor on pin temp0 ; Fans M950 F0 C"20.out1+out1.tach" Q500 ; create fan 0 on pin 20.out1 and set its frequency M106 P0 S0 H-1 ; set fan 0 value. Thermostatic control is turned off M950 F1 C"20.out2" Q500 ; create fan 1 on pin 20.out2 and set its frequency M106 P1 S1 H1 T50 ; set fan 1 value. Thermostatic control is turned on ; Tools M563 P0 D0 H1 F0 ; define tool 0 G10 P0 X0 Y0 Z0 ; set tool 0 axis offsets G10 P0 R0 S0 ; set initial tool 0 active and standby temperatures to 0C ; Custom settings are not defined ; Miscellaneous M575 P1 S1 B57600 ; enable support for PanelDue T0 ; select first hot end
It makes me nervous about running a print, especially if it is not reporting back simple things like tramming info.
Paul.
@paulhew Does it do the bed tramming and fail to report, or does it not do the bed tramming? Does it make a difference if you turn off the bed just while conducting the tramming (possible interference from bed SSR)? Anything in the other macros that are called in bed.g that could possibly cause it?
@droftarts Hi Ian, thank you for your prompt assistance.
I have had it report network errors even with the bed not heated or any heaters running at all.
The only other macro that is contained within bed.g is the screw positioning routine, bed_ThreeScrews.gG30 P0 X0 Y35 Z-99999 G30 P1 X0 Y275 Z-99999 G30 P2 X280 Y150 Z-99999 S3
I even rebooted and this is from the console.
30/03/2021, 11:29:26 Height map loaded from file heightmap.csv 30/03/2021, 11:29:13 Bed Traming Cycle: 1 - Difference was 0.003mm 30/03/2021, 11:29:13 Leadscrew adjustments made: 0.010 0.013 0.005, points used 3, (mean, deviation) before (0.010, 0.003) after (0.000, 0.000) 30/03/2021, 11:17:45 G29 Error: Network error 30/03/2021, 11:17:01 M98 P"0:/macros/2_Tram_Bed.G" Leadscrew adjustments made: 0.011 0.023 0.015, points used 3, (mean, deviation) before (0.017, 0.005) after (-0.000, 0.000) Bed Traming Cycle: 1 - Difference was 0.005mm 30/03/2021, 11:15:44 M98 P"0:/macros/2_Tram_Bed.G" Leadscrew adjustments made: 0.026 0.016 0.019, points used 3, (mean, deviation) before (0.021, 0.004) after (-0.000, 0.000) Bed Traming Cycle: 1 - Difference was 0.004mm 30/03/2021, 11:12:42 G28 Error: Network error 30/03/2021, 11:12:21 Connection established
Regards,
Paul
1LC has Y endstop, BLTouch, Stepper, hotend heater, hotend temp.
Could it be a CANBus issue? It is terminated. -
@paulhew There's also the homex, y and z.g files called in bed.g.
But does it actually do the tramming, despite the error message and no response? Or does it stop part way through? Does it home x, y and z, then fail, or not start at all? As it's doing it after the first time, presumably the axes are homed already, so is it something as simple as the check whether it's homed not working properly? What version of DSF are you running (check in DWC > Settings > Machine-specific > General)?
@paulhew Sounds odd to me that you are getting network errors. Do you get any more details? It sounds like the commands are terminated which is why it outputs those messages. To be clear: You are using DSF+DWC+RRF 3.2.2, aren't you?
If yes, please open a terminal on the SBC and start looking for potential error messages in the DCS log via
journalctl -u duetcontrolserver -f
. Then run G28/G29 and see what happens. -
@droftarts It completes the tasks, homing or tramming but pops these messages up.
Sometimes it completes and gives me the correct feedback.M122 on Board and 1LC
30/03/2021, 12:19:58 m122 b20 Diagnostics for board 20: Duet TOOL1LC firmware version 3.2.2 (2021-02-11) Bootloader ID: SAMC21 bootloader version 2.3 (2021-01-26b1) Never used RAM 4000, free system stack 48 words HEAT 90 CanAsync 89 CanRecv 83 TMC 56 MAIN 218 AIN 64 Last reset 01:07:40 ago, cause: software Last software reset data not available Driver 0: position 271609, 412.0 steps/mm, standstill, SG min/max 0/18, read errors 0, write errors 1, ifcnt 31, reads 63919, writes 15, timeouts 0, DMA errors 0 Moves scheduled 1583, completed 1583, in progress 0, hiccups 0 No step interrupt scheduled VIN: 24.3V MCU temperature: min 40.2C, current 40.3C, max 61.1C Ticks since heat task active 65, ADC conversions started 4043854, completed 4043853, timed out 0 Last sensors broadcast 0x00000002 found 1 69 ticks ago, loop time 0 CAN messages queued 49844, send timeouts 0, received 39096, lost 0, free buffers 36 30/03/2021, 12:19:51 m122 === Diagnostics === RepRapFirmware for Duet 3 Mini 5+ version 3.2.2 running on Duet 3 Mini5plus Ethernet (SBC mode) Board ID: A45XG-F396U-D65J0-40KML-1F03Z-H03XP Used output buffers: 1 of 40 (18 max) === RTOS === Static ram: 98732 Dynamic ram: 94964 of which 120 recycled Never used RAM 51400, free system stack 122 words Tasks: Linux(ready,99) HEAT(blocked,291) CanReceiv(blocked,807) CanSender(blocked,366) CanClock(blocked,370) TMC(blocked,97) MAIN(running,386) IDLE(ready,20) AIN(blocked,260) Owned mutexes: HTTP(MAIN) === Platform === Last reset 01:07:31 ago, cause: software Last software reset at 2021-03-30 11:12, reason: User, none spinning, available RAM 51428, slot 0 Software reset code 0x0012 HFSR 0x00000000 CFSR 0x00000000 ICSR 0x00000000 BFAR 0xe000ed38 SP 0x00000000 Task Linu Freestk 0 n/a Error status: 0x00 Aux0 errors 0,0,0 Aux1 errors 0,0,0 Supply voltage: min 0.0, current 23.9, max 24.2, under voltage events: 0, over voltage events: 0, power good: yes Driver 0: position 58000, standstill, SG min/max 0/478, read errors 0, write errors 1, ifcnt 54, reads 51641, writes 21, timeouts 564, DMA errors 0, failedOp 0x72 Driver 1: position -54000, standstill, SG min/max 0/494, read errors 0, write errors 1, ifcnt 54, reads 51570, writes 21, timeouts 635, DMA errors 0, failedOp 0x71 Driver 2: position 55982, standstill, SG min/max 0/240, read errors 0, write errors 1, ifcnt 56, reads 49281, writes 21, timeouts 2924, DMA errors 0, failedOp 0x6f Driver 3: position 0, standstill, SG min/max 0/260, read errors 0, write errors 1, ifcnt 56, reads 51410, writes 21, timeouts 795, DMA errors 0, failedOp 0x6a Driver 4: position 0, standstill, SG min/max 0/266, read errors 0, write errors 1, ifcnt 56, reads 52205, writes 21, timeouts 0, DMA errors 0 Driver 5: position 0, assumed not present Driver 6: position 0, assumed not present Date/time: 2021-03-30 12:19:50 Cache data hit count 4294967295 Slowest loop: 201.31ms; fastest: 0.07ms === Storage === Free file entries: 10 SD card 0 not detected, interface speed: 0.0MBytes/sec SD card longest read time 0.0ms, write time 0.0ms, max retries 0 === Move === DMs created 83, maxWait 124236ms, bed compensation in use: none, comp offset 0.000 === MainDDARing === Scheduled moves 2001, completed moves 2001, hiccups 0, stepErrors 0, LaErrors 0, Underruns [0, 0, 3], CDDA state -1 === AuxDDARing === Scheduled moves 0, completed moves 0, hiccups 0, stepErrors 0, LaErrors 0, Underruns [0, 0, 0], CDDA state -1 === Heat === Bed heaters = 0 -1, chamberHeaters = -1 -1 Heater 0 is on, I-accum = 0.1 Heater 1 is on, I-accum = 0.0 === GCodes === Segments left: 0 Movement lock held by null HTTP* is doing "M122" in state(s) 0 Telnet is idle in state(s) 0 File* is idle in state(s) 0 USB is idle in state(s) 0 Aux is idle in state(s) 0 Trigger* is idle in state(s) 0 Queue* is idle in state(s) 0 LCD is idle in state(s) 0 SBC is idle in state(s) 0 Daemon is idle in state(s) 0 Aux2 is idle in state(s) 0 Autopause is idle in state(s) 0 Code queue is empty. === CAN === Messages queued 39020, send timeouts 0, received 49736, lost 0, longest wait 2ms for reply type 6031, free buffers 16 === SBC interface === State: 4, failed transfers: 0 Last transfer: 4ms ago RX/TX seq numbers: 13708/13708 SPI underruns 0, overruns 0 Number of disconnects: 0, IAP RAM available 0x113bc Buffer RX/TX: 0/0-0 === Duet Control Server === Duet Control Server v3.2.2 Code buffer space: 4096 Configured SPI speed: 8000000 Hz Full transfers per second: 35.74 Maximum length of RX/TX data transfers: 2960/676
@chrishamm Current journal, no errors.
pi@RailCoreII:~ $ journalctl -u duetcontrolserver -f -- Logs begin at Mon 2021-03-29 21:18:43 BST. -- Mar 30 11:29:13 RailCoreII DuetControlServer[4869]: [info] Bed Traming Cycle: 1 - Difference was 0.003mm Mar 30 11:29:13 RailCoreII DuetControlServer[4869]: [info] Starting macro file homez.g on channel File Mar 30 11:29:13 RailCoreII DuetControlServer[4869]: [info] Starting macro file deployprobe.g on channel File Mar 30 11:29:14 RailCoreII DuetControlServer[4869]: [info] Finished macro file deployprobe.g Mar 30 11:29:21 RailCoreII DuetControlServer[4869]: [info] Starting macro file retractprobe.g on channel File Mar 30 11:29:21 RailCoreII DuetControlServer[4869]: [info] Finished macro file retractprobe.g Mar 30 11:29:22 RailCoreII DuetControlServer[4869]: [info] Finished macro file homez.g Mar 30 11:29:26 RailCoreII DuetControlServer[4869]: [info] Height map loaded from file heightmap.csv Mar 30 11:53:39 RailCoreII DuetControlServer[4869]: [info] Finished job file Mar 30 11:53:39 RailCoreII DuetControlServer[4869]: [info] Finished printing file 0:/gcodes/ABS Shape-Box-1.61566g-22m.gcode, print time was 0h 27m
Regards,
Paul.
considering the logs begin at 21:18 last night, there have not been many entries..
I have been testing tramming, homing, bed mesh multiple times this morning.
P. -
@paulhew Thanks, so nothing is wrong there. Perhaps G28 and G29 just take too long and time out and/or the connection is interrupted while the web interface is waiting for a response. In SBC mode a code HTTP request remains active as long as the code hasn't finished.
@chrishamm Since running that command on the Pi no issues with network errors etc.
I spoke too soon!Console
30/03/2021, 12:37:45 G32 Error: Network error 30/03/2021, 12:36:33 g32 Leadscrew adjustments made: 0.051 0.042 0.038, points used 3, (mean, deviation) before (0.044, 0.005) after (-0.000, 0.000) Bed Traming Cycle: 1 - Difference was 0.005mm 30/03/2021, 12:35:24 g28
Mar 30 12:37:04 RailCoreII DuetControlServer[4869]: [info] Starting macro file homeall.g on channel HTTP Mar 30 12:37:19 RailCoreII DuetControlServer[4869]: [info] Starting macro file deployprobe.g on channel HTTP Mar 30 12:37:19 RailCoreII DuetControlServer[4869]: [info] Finished macro file deployprobe.g Mar 30 12:37:27 RailCoreII DuetControlServer[4869]: [info] Starting macro file retractprobe.g on channel HTTP Mar 30 12:37:27 RailCoreII DuetControlServer[4869]: [info] Finished macro file retractprobe.g Mar 30 12:37:27 RailCoreII DuetControlServer[4869]: [info] Finished macro file homeall.g Mar 30 12:37:39 RailCoreII DuetControlServer[4869]: [info] Starting macro file bed.g on channel HTTP Mar 30 12:37:39 RailCoreII DuetControlServer[4869]: [info] Starting macro file 0:/sys/homex.g on channel HTTP Mar 30 12:37:46 RailCoreII DuetControlServer[4869]: [info] Finished macro file 0:/sys/homex.g Mar 30 12:37:46 RailCoreII DuetControlServer[4869]: [info] Starting macro file 0:/sys/homey.g on channel HTTP Mar 30 12:37:53 RailCoreII DuetControlServer[4869]: [info] Finished macro file 0:/sys/homey.g Mar 30 12:37:53 RailCoreII DuetControlServer[4869]: [info] Starting macro file 0:/sys/homez.g on channel HTTP Mar 30 12:37:56 RailCoreII DuetControlServer[4869]: [info] Starting macro file deployprobe.g on channel HTTP Mar 30 12:37:56 RailCoreII DuetControlServer[4869]: [info] Finished macro file deployprobe.g Mar 30 12:38:04 RailCoreII DuetControlServer[4869]: [info] Starting macro file retractprobe.g on channel HTTP Mar 30 12:38:04 RailCoreII DuetControlServer[4869]: [info] Finished macro file retractprobe.g Mar 30 12:38:05 RailCoreII DuetControlServer[4869]: [info] Finished macro file 0:/sys/homez.g Mar 30 12:38:08 RailCoreII DuetControlServer[4869]: [info] Starting macro file 0:/sys/bed_ThreeScrews.g on channel HTTP Mar 30 12:38:11 RailCoreII DuetControlServer[4869]: [info] Starting macro file deployprobe.g on channel HTTP Mar 30 12:38:11 RailCoreII DuetControlServer[4869]: [info] Finished macro file deployprobe.g Mar 30 12:38:13 RailCoreII DuetControlServer[4869]: [info] Starting macro file retractprobe.g on channel HTTP Mar 30 12:38:13 RailCoreII DuetControlServer[4869]: [info] Finished macro file retractprobe.g Mar 30 12:38:17 RailCoreII DuetControlServer[4869]: [info] Starting macro file deployprobe.g on channel HTTP Mar 30 12:38:17 RailCoreII DuetControlServer[4869]: [info] Finished macro file deployprobe.g Mar 30 12:38:19 RailCoreII DuetControlServer[4869]: [info] Starting macro file retractprobe.g on channel HTTP Mar 30 12:38:19 RailCoreII DuetControlServer[4869]: [info] Finished macro file retractprobe.g Mar 30 12:38:23 RailCoreII DuetControlServer[4869]: [info] Starting macro file deployprobe.g on channel HTTP Mar 30 12:38:23 RailCoreII DuetControlServer[4869]: [info] Finished macro file deployprobe.g Mar 30 12:38:26 RailCoreII DuetControlServer[4869]: [info] Starting macro file retractprobe.g on channel HTTP Mar 30 12:38:26 RailCoreII DuetControlServer[4869]: [info] Finished macro file retractprobe.g Mar 30 12:38:26 RailCoreII DuetControlServer[4869]: [info] Finished macro file 0:/sys/bed_ThreeScrews.g Mar 30 12:38:27 RailCoreII DuetControlServer[4869]: [info] Starting macro file homez.g on channel HTTP Mar 30 12:38:29 RailCoreII DuetControlServer[4869]: [info] Starting macro file deployprobe.g on channel HTTP Mar 30 12:38:29 RailCoreII DuetControlServer[4869]: [info] Finished macro file deployprobe.g Mar 30 12:38:34 RailCoreII DuetControlServer[4869]: [info] Starting macro file retractprobe.g on channel HTTP Mar 30 12:38:34 RailCoreII DuetControlServer[4869]: [info] Finished macro file retractprobe.g Mar 30 12:38:35 RailCoreII DuetControlServer[4869]: [info] Finished macro file homez.g Mar 30 12:38:38 RailCoreII DuetControlServer[4869]: [info] Finished macro file bed.g
@paulhew If the timing is right, you got the error when it ran homex.g. Can you post that?
@droftarts Homex.g as requested.
G91 ; relative positioning G1 H2 Z5 F3000 ; lift Z relative to current position G1 H1 X-340 F1800 ; move quickly to X axis endstop and stop there (first pass) G1 X5 F6000 ; go back a few mm G1 H1 X-15 F360 ; move slowly to X axis endstop once more (second pass) G1 H2 Z-5 F6000 ; lower Z again G90 ; absolute positioning
@paulhew Looks unequivocally correct!
@droftarts
Just popped up with a network error whilst running a G32, continued to run the g32.30/03/2021, 12:53:44 g32 Error: Network error 30/03/2021, 12:53:19 g32 Leadscrew adjustments made: 0.013 0.020 0.027, points used 3, (mean, deviation) before (0.019, 0.005) after (0.000, 0.000) Bed Traming Cycle: 1 - Difference was 0.005mm 30/03/2021, 12:52:16 g32 Leadscrew adjustments made: 0.026 0.023 0.017, points used 3, (mean, deviation) before (0.022, 0.003) after (0.000, 0.000) Bed Traming Cycle: 1 - Difference was 0.003mm 30/03/2021, 12:51:12 g28 30/03/2021, 12:50:42 g28 30/03/2021, 12:50:11 g28
pi log - note the bottom line, issue possibly?
Mar 30 12:49:44 RailCoreII DuetControlServer[4869]: [info] Starting macro file homeall.g on channel HTTP Mar 30 12:49:59 RailCoreII DuetControlServer[4869]: [info] Starting macro file deployprobe.g on channel HTTP Mar 30 12:49:59 RailCoreII DuetControlServer[4869]: [info] Finished macro file deployprobe.g Mar 30 12:50:07 RailCoreII DuetControlServer[4869]: [info] Starting macro file retractprobe.g on channel HTTP Mar 30 12:50:07 RailCoreII DuetControlServer[4869]: [info] Finished macro file retractprobe.g Mar 30 12:50:08 RailCoreII DuetControlServer[4869]: [info] Finished macro file homeall.g Mar 30 12:50:16 RailCoreII DuetControlServer[4869]: [info] Starting macro file homeall.g on channel HTTP Mar 30 12:50:31 RailCoreII DuetControlServer[4869]: [info] Starting macro file deployprobe.g on channel HTTP Mar 30 12:50:31 RailCoreII DuetControlServer[4869]: [info] Finished macro file deployprobe.g Mar 30 12:50:39 RailCoreII DuetControlServer[4869]: [info] Starting macro file retractprobe.g on channel HTTP Mar 30 12:50:39 RailCoreII DuetControlServer[4869]: [info] Finished macro file retractprobe.g Mar 30 12:50:39 RailCoreII DuetControlServer[4869]: [info] Finished macro file homeall.g Mar 30 12:50:45 RailCoreII DuetControlServer[4869]: [info] Starting macro file homeall.g on channel HTTP Mar 30 12:51:00 RailCoreII DuetControlServer[4869]: [info] Starting macro file deployprobe.g on channel HTTP Mar 30 12:51:00 RailCoreII DuetControlServer[4869]: [info] Finished macro file deployprobe.g Mar 30 12:51:08 RailCoreII DuetControlServer[4869]: [info] Starting macro file retractprobe.g on channel HTTP Mar 30 12:51:08 RailCoreII DuetControlServer[4869]: [info] Finished macro file retractprobe.g Mar 30 12:51:09 RailCoreII DuetControlServer[4869]: [info] Finished macro file homeall.g Mar 30 12:51:17 RailCoreII DuetControlServer[4869]: [info] Starting macro file bed.g on channel HTTP Mar 30 12:51:17 RailCoreII DuetControlServer[4869]: [info] Starting macro file 0:/sys/homex.g on channel HTTP Mar 30 12:51:25 RailCoreII DuetControlServer[4869]: [info] Finished macro file 0:/sys/homex.g Mar 30 12:51:25 RailCoreII DuetControlServer[4869]: [info] Starting macro file 0:/sys/homey.g on channel HTTP Mar 30 12:51:32 RailCoreII DuetControlServer[4869]: [info] Finished macro file 0:/sys/homey.g Mar 30 12:51:32 RailCoreII DuetControlServer[4869]: [info] Starting macro file 0:/sys/homez.g on channel HTTP Mar 30 12:51:35 RailCoreII DuetControlServer[4869]: [info] Starting macro file deployprobe.g on channel HTTP Mar 30 12:51:35 RailCoreII DuetControlServer[4869]: [info] Finished macro file deployprobe.g Mar 30 12:51:42 RailCoreII DuetControlServer[4869]: [info] Starting macro file retractprobe.g on channel HTTP Mar 30 12:51:43 RailCoreII DuetControlServer[4869]: [info] Finished macro file retractprobe.g Mar 30 12:51:43 RailCoreII DuetControlServer[4869]: [info] Finished macro file 0:/sys/homez.g Mar 30 12:51:46 RailCoreII DuetControlServer[4869]: [info] Starting macro file 0:/sys/bed_ThreeScrews.g on channel HTTP Mar 30 12:51:49 RailCoreII DuetControlServer[4869]: [info] Starting macro file deployprobe.g on channel HTTP Mar 30 12:51:49 RailCoreII DuetControlServer[4869]: [info] Finished macro file deployprobe.g Mar 30 12:51:52 RailCoreII DuetControlServer[4869]: [info] Starting macro file retractprobe.g on channel HTTP Mar 30 12:51:52 RailCoreII DuetControlServer[4869]: [info] Finished macro file retractprobe.g Mar 30 12:51:55 RailCoreII DuetControlServer[4869]: [info] Starting macro file deployprobe.g on channel HTTP Mar 30 12:51:55 RailCoreII DuetControlServer[4869]: [info] Finished macro file deployprobe.g Mar 30 12:51:58 RailCoreII DuetControlServer[4869]: [info] Starting macro file retractprobe.g on channel HTTP Mar 30 12:51:58 RailCoreII DuetControlServer[4869]: [info] Finished macro file retractprobe.g Mar 30 12:52:01 RailCoreII DuetControlServer[4869]: [info] Starting macro file deployprobe.g on channel HTTP Mar 30 12:52:01 RailCoreII DuetControlServer[4869]: [info] Finished macro file deployprobe.g Mar 30 12:52:04 RailCoreII DuetControlServer[4869]: [info] Starting macro file retractprobe.g on channel HTTP Mar 30 12:52:04 RailCoreII DuetControlServer[4869]: [info] Finished macro file retractprobe.g Mar 30 12:52:05 RailCoreII DuetControlServer[4869]: [info] Finished macro file 0:/sys/bed_ThreeScrews.g Mar 30 12:52:05 RailCoreII DuetControlServer[4869]: [info] Starting macro file homez.g on channel HTTP Mar 30 12:52:07 RailCoreII DuetControlServer[4869]: [info] Starting macro file deployprobe.g on channel HTTP Mar 30 12:52:07 RailCoreII DuetControlServer[4869]: [info] Finished macro file deployprobe.g Mar 30 12:52:12 RailCoreII DuetControlServer[4869]: [info] Starting macro file retractprobe.g on channel HTTP Mar 30 12:52:12 RailCoreII DuetControlServer[4869]: [info] Finished macro file retractprobe.g Mar 30 12:52:13 RailCoreII DuetControlServer[4869]: [info] Finished macro file homez.g Mar 30 12:52:16 RailCoreII DuetControlServer[4869]: [info] Finished macro file bed.g Mar 30 12:52:20 RailCoreII DuetControlServer[4869]: [info] Starting macro file bed.g on channel HTTP Mar 30 12:52:20 RailCoreII DuetControlServer[4869]: [info] Starting macro file 0:/sys/homex.g on channel HTTP Mar 30 12:52:28 RailCoreII DuetControlServer[4869]: [info] Finished macro file 0:/sys/homex.g Mar 30 12:52:28 RailCoreII DuetControlServer[4869]: [info] Starting macro file 0:/sys/homey.g on channel HTTP Mar 30 12:52:35 RailCoreII DuetControlServer[4869]: [info] Finished macro file 0:/sys/homey.g Mar 30 12:52:35 RailCoreII DuetControlServer[4869]: [info] Starting macro file 0:/sys/homez.g on channel HTTP Mar 30 12:52:38 RailCoreII DuetControlServer[4869]: [info] Starting macro file deployprobe.g on channel HTTP Mar 30 12:52:38 RailCoreII DuetControlServer[4869]: [info] Finished macro file deployprobe.g Mar 30 12:52:45 RailCoreII DuetControlServer[4869]: [info] Starting macro file retractprobe.g on channel HTTP Mar 30 12:52:45 RailCoreII DuetControlServer[4869]: [info] Finished macro file retractprobe.g Mar 30 12:52:46 RailCoreII DuetControlServer[4869]: [info] Finished macro file 0:/sys/homez.g Mar 30 12:52:49 RailCoreII DuetControlServer[4869]: [info] Starting macro file 0:/sys/bed_ThreeScrews.g on channel HTTP Mar 30 12:52:52 RailCoreII DuetControlServer[4869]: [info] Starting macro file deployprobe.g on channel HTTP Mar 30 12:52:52 RailCoreII DuetControlServer[4869]: [info] Finished macro file deployprobe.g Mar 30 12:52:54 RailCoreII DuetControlServer[4869]: [info] Starting macro file retractprobe.g on channel HTTP Mar 30 12:52:55 RailCoreII DuetControlServer[4869]: [info] Finished macro file retractprobe.g Mar 30 12:52:58 RailCoreII DuetControlServer[4869]: [info] Starting macro file deployprobe.g on channel HTTP Mar 30 12:52:58 RailCoreII DuetControlServer[4869]: [info] Finished macro file deployprobe.g Mar 30 12:53:00 RailCoreII DuetControlServer[4869]: [info] Starting macro file retractprobe.g on channel HTTP Mar 30 12:53:00 RailCoreII DuetControlServer[4869]: [info] Finished macro file retractprobe.g Mar 30 12:53:04 RailCoreII DuetControlServer[4869]: [info] Starting macro file deployprobe.g on channel HTTP Mar 30 12:53:04 RailCoreII DuetControlServer[4869]: [info] Finished macro file deployprobe.g Mar 30 12:53:07 RailCoreII DuetControlServer[4869]: [info] Starting macro file retractprobe.g on channel HTTP Mar 30 12:53:07 RailCoreII DuetControlServer[4869]: [info] Finished macro file retractprobe.g Mar 30 12:53:08 RailCoreII DuetControlServer[4869]: [info] Finished macro file 0:/sys/bed_ThreeScrews.g Mar 30 12:53:08 RailCoreII DuetControlServer[4869]: [info] Starting macro file homez.g on channel HTTP Mar 30 12:53:10 RailCoreII DuetControlServer[4869]: [info] Starting macro file deployprobe.g on channel HTTP Mar 30 12:53:10 RailCoreII DuetControlServer[4869]: [info] Finished macro file deployprobe.g Mar 30 12:53:15 RailCoreII DuetControlServer[4869]: [info] Starting macro file retractprobe.g on channel HTTP Mar 30 12:53:15 RailCoreII DuetControlServer[4869]: [info] Finished macro file retractprobe.g Mar 30 12:53:16 RailCoreII DuetControlServer[4869]: [info] Finished macro file homez.g Mar 30 12:53:19 RailCoreII DuetControlServer[4869]: [info] Finished macro file bed.g Mar 30 12:53:24 RailCoreII DuetControlServer[4869]: [info] Starting macro file bed.g on channel HTTP Mar 30 12:53:24 RailCoreII DuetControlServer[4869]: [info] Starting macro file 0:/sys/homex.g on channel HTTP Mar 30 12:53:32 RailCoreII DuetControlServer[4869]: [info] Finished macro file 0:/sys/homex.g Mar 30 12:53:32 RailCoreII DuetControlServer[4869]: [info] Starting macro file 0:/sys/homey.g on channel HTTP Mar 30 12:53:39 RailCoreII DuetControlServer[4869]: [info] Finished macro file 0:/sys/homey.g Mar 30 12:53:39 RailCoreII DuetControlServer[4869]: [info] Starting macro file 0:/sys/homez.g on channel HTTP Mar 30 12:53:42 RailCoreII DuetControlServer[4869]: [info] Starting macro file deployprobe.g on channel HTTP Mar 30 12:53:42 RailCoreII DuetControlServer[4869]: [info] Finished macro file deployprobe.g Mar 30 12:53:50 RailCoreII DuetControlServer[4869]: [info] Starting macro file retractprobe.g on channel HTTP Mar 30 12:53:50 RailCoreII DuetControlServer[4869]: [info] Finished macro file retractprobe.g Mar 30 12:53:50 RailCoreII DuetControlServer[4869]: [info] Finished macro file 0:/sys/homez.g Mar 30 12:53:53 RailCoreII DuetControlServer[4869]: [info] Starting macro file 0:/sys/bed_ThreeScrews.g on channel HTTP Mar 30 12:53:56 RailCoreII DuetControlServer[4869]: [info] Starting macro file deployprobe.g on channel HTTP Mar 30 12:53:56 RailCoreII DuetControlServer[4869]: [info] Finished macro file deployprobe.g Mar 30 12:53:59 RailCoreII DuetControlServer[4869]: [info] Starting macro file retractprobe.g on channel HTTP Mar 30 12:53:59 RailCoreII DuetControlServer[4869]: [info] Finished macro file retractprobe.g Mar 30 12:54:02 RailCoreII DuetControlServer[4869]: [info] Starting macro file deployprobe.g on channel HTTP Mar 30 12:54:02 RailCoreII DuetControlServer[4869]: [info] Finished macro file deployprobe.g Mar 30 12:54:05 RailCoreII DuetControlServer[4869]: [info] Starting macro file retractprobe.g on channel HTTP Mar 30 12:54:05 RailCoreII DuetControlServer[4869]: [info] Finished macro file retractprobe.g Mar 30 12:54:08 RailCoreII DuetControlServer[4869]: [info] Starting macro file deployprobe.g on channel HTTP Mar 30 12:54:09 RailCoreII DuetControlServer[4869]: [info] Finished macro file deployprobe.g Mar 30 12:54:11 RailCoreII DuetControlServer[4869]: [info] Starting macro file retractprobe.g on channel HTTP Mar 30 12:54:11 RailCoreII DuetControlServer[4869]: [info] Finished macro file retractprobe.g Mar 30 12:54:12 RailCoreII DuetControlServer[4869]: [info] Finished macro file 0:/sys/bed_ThreeScrews.g Mar 30 12:54:12 RailCoreII DuetControlServer[4869]: [info] Starting macro file homez.g on channel HTTP Mar 30 12:54:14 RailCoreII DuetControlServer[4869]: [info] Starting macro file deployprobe.g on channel HTTP Mar 30 12:54:14 RailCoreII DuetControlServer[4869]: [info] Finished macro file deployprobe.g Mar 30 12:54:20 RailCoreII DuetControlServer[4869]: [info] Starting macro file retractprobe.g on channel HTTP Mar 30 12:54:20 RailCoreII DuetControlServer[4869]: [info] Finished macro file retractprobe.g Mar 30 12:54:20 RailCoreII DuetControlServer[4869]: [info] Finished macro file homez.g Mar 30 12:54:23 RailCoreII DuetControlServer[4869]: [info] Finished macro file bed.g Mar 30 12:55:51 RailCoreII DuetControlServer[4869]: [warn] RepRapFirmware got a bad header checksum
random! Throws error but completes task
30/03/2021, 13:02:29 g28 Error: Network error 30/03/2021, 13:02:21 g28
@paulhew Yes, started codes always complete, even if the underlying connection is terminated. I suggest you press F12 to open the dev tools, go to Network, and check the cause for interrupted connections. It sounds like either the browser or OS kills the HTTP connection(s) after a brief moment.
