Fan needs more power to start spinning.
Hi guys, I am new here and just got my BLV mgn cube working with Duet3 and RRF3. Very proud of this piece of equipment!
I have a little issue with parallel fans which are used for the x/y motor cooling. They do not start itself and I need to touch them to spin, then they keep on running.
I did not find any info if the frequency is related to the power? Is there any other parameter which could give it more power?
M950 F2 C"out7" Q500 M106 P2 C"Motor Fan" T50 H0
@snagit007 add a blip value to the M106. E.g. B1
@snagit007 said in Fan needs more power to start spinning.:
There should also be an S value on that line to tell it what speed to use when the temp is reached. S1 would be full power.
everything is becoming clearer with every hour I spent. Thanks so much!
