Duet Mini not responding
Duet 3 Mini 5 + not responding to YAT commands. Terminal is closed and trying to reconnect.
Any help would be appreciated. YAT able to create terminal using Duet Com port, but does not respond to M552, M552 S0, or M552 S1. -
Give this a look and see if you can flash the firmware using the USB method shown here. It basically shows up as a USB storage device and you copy the firmware file to it.
