DWC 3.1.1
mi da questo errore , ma il comando viene ,fatto dalla macchina
g 30 g30
Error: Bad command: Configuration Tool v3.2.3 on Sun Mar 14 2021 01:38:34 GMT+0100 (Ora standard dell’Europa centrale) -
mi da questo errore Error: Bad command: Configuration Tool v3.2.3 on Sun Mar 14 2021 01:38:34 GMT+0100 (Ora standard dell’Europa centrale)
Ma la macchina esegue i comandi. dopo il comando g29 e salvato il risultato nel file mi da la seguente foto
non appare il grafico
@luca-Massimiliano said in DWC 3.1.1:
gives me this error Error: Bad command: Configuration Tool v3.2.3 on Sun Mar 14 2021 01:38:34 GMT + 0100 (Central European Standard Time)
It sounds like you are missing a
to commend out that line? -
H1 NON VA SI BLOCCA NON SI SINTONIZZA
COMADO M307 H 1 ECCO LETTURA
M307 H 1
Heater 1 model: heating rate 2.429, cooling time constant 140.0, dead time 5.50, max PWM 1.00, calibration voltage 0.0, mode PID
Computed PID parameters: setpoint change: P13.4, I0.482, D51.4, load change: P13.4, I0.949, D51.4ESEGUO AUTOMATICO
M303 H1 S
Auto tuning heater 1 using target temperature 0.0°C and PWM 1.00 - do not leave printer unattendedNON SI FERMA IL PROCEDIMENTO HEATER 1 OSCILLA TRA 23,4 23,8
POI M0
I'm not sure what you're saying. The translation was not very good this time.
THE PROCEDURE DOES NOT STOP HEATER 1 SWINGS BETWEEN 23.4 23.8
PID tuning can take a long time.
ESATTO , 20 30 MINUTI PER UN RISCALDATORE , H1 LAVORA PER 60 MINUTI O PIU' . IN TUTTE LE CALIBRAZIONE CHE HO FATTO, LA TEMPERATURA SALIVA AL MASSIMO .
ORA LA TEMPERATURA VA MASSIMO A 24 GRADI MI STUPISCO . ORA STA LAVORANDO -
M303 H1 S
You need to set a temperature after the S
M303 H1 S200
AVEVO CAPITO HE S NON IMPOSTATO ANDAVA ALLA MASSIMA TEMPERATURA .GRAZIE PROVO SUBITO
This post is deleted! -
@Phaedrux PERFETTO
GRAZIE -
NON HO CAPITO . HO FATTO G 29 LA MACCHINA HA LAVORATO MA NIENTE GRAFIGO RAPPRESENTATO COME SI VEDE. UNA VOLTA HA FATTO GRAFICO CON UN G 29 POI NON PIU'
It sounds like you are missing a ; to commend out that line?
NON COMPRENDO SCUSA
MI HA MANDATO QUI NON SO SE HA IMPORTANA PENSO RIGUARDI LO SPESSORE E IL MATERIALE, DEVO CREARE UN FILE
Create a folder on your SD card called
menu
and another calledfilaments
Check your config files for that line. Some where there is a file that has that line and it's missing a
at the start to mark it as a comment. -
; generated by RepRapFirmware Configuration Tool v3.2.3 on Sun Mar 14 2021 01:38:34 GMT+0100 (Ora standard dell’Europa centrale)
; IN GONFIG.G OK
Check your config files for that line. Some where there is a file that has that line and it's missing a ; at the start to mark it as a comment.
What are you doing when that error message shows up?
HO FATTO MENU FILAMENT IN SD CARD
