DWC 3.1.1
GRAZIE VERAMENTE PRECISO E PREPARATISSIMO FUNZIONA , (NON HO PROVATO L ESTRUSIONE PER ORA)
HO UN PROBLEMA INVECIE PanelDue Firmware. CON QUALE Firmware DIVENTA COMPATIBILE? -
What version of firmware is on the PanelDue? Check in the Setup page on the Panel.
It should be at least 1.24
https://duet3d.dozuki.com/Wiki/PanelDue_Firmware_update
What baud rate is it set to? It should be 57600 to match what you have set in config.g
3.28
Your baud rate doesn't match. In PanelDue it shows 115200 baud. Press that button until it shows 57600.
GRANDIOSO I BAUD GRAZIE MILLE . SONO A BUON PUNTO DIREI COME POSSO RICAMBIARE IL TUO ENORME AIUTO
NON HO FATTO CON A NUOVA CONFIGURAZIONE SONDAGGIO AUTOMATICO . IO HO UNA DELTA KOSSEL CIRCOLARE E RIPORTA I VALORI APPROSIMATICI E NORMALE CHE USI UNA BASE QUADRATA? SCUSA NON VORREI AVER DIMETICATO DELLE CONFIGURAZIONI.
CIAO
non ho mai capito una cosa :
perche' se MODIFICO IL VALORE NEL CONFIG .G DI H506.5 NON CAMBIA MAI E DEVO CAMBIARLO SU RepRapFirmware Configuration Tool ?
M665 R165.29 L334 B130 H506.5 ; Set delta radius, diagonal rod length, printable radius and homed height -
I think that would be handled with delta calibration. I'm not very savvy with deltas, but those two links to configure and calibrate should get you going.
SI HAI RAGIONE POSSO CAMBIARLO SOLO CON Configuration Tool MA LO CALCOLCO PRIMA MEDIANTE I SOLITI SISEMI , MA SOLO Configuration Tool RIESCE A SALVARE IL VALORE ,IL CHE RENDE TUTTO MOLTO PIU' LABORIOSO, GRAZIE
Just edit the config.g file in the web interface. It's in the system tab. You do not need to go back to the configuration tool every time.
I DO NOT UNDERSTAND n the web interface.
Plugins tab (built-in) HEIGHT MAP = START OK CAMBIA H TOTAL DOPO RIAVVIO MA USANDO M665 H565.85 NON CONFIG.G TUTTO BENE . UNA COSA CHE NON CAPISCO E' PERCHE' L ALTEZZA IMPOSTATA NON E' UGUALE ALLA HOM HO PENSATO AL DISTIAMENTO IMPOSTATO SUI FINE CORSA ALTI . TI RINGRAZIO ANCORA HO RISOLTO UN SACCO DI PROBLEMI GRAZIE A TE
mi da questo errore , ma il comando viene ,fatto dalla macchina
g 30 g30
Error: Bad command: Configuration Tool v3.2.3 on Sun Mar 14 2021 01:38:34 GMT+0100 (Ora standard dell’Europa centrale) -
mi da questo errore Error: Bad command: Configuration Tool v3.2.3 on Sun Mar 14 2021 01:38:34 GMT+0100 (Ora standard dell’Europa centrale)
Ma la macchina esegue i comandi. dopo il comando g29 e salvato il risultato nel file mi da la seguente foto
non appare il grafico
@luca-Massimiliano said in DWC 3.1.1:
gives me this error Error: Bad command: Configuration Tool v3.2.3 on Sun Mar 14 2021 01:38:34 GMT + 0100 (Central European Standard Time)
It sounds like you are missing a
to commend out that line?
