Switch to unstable and back to stable
I use a Duet3 + SBC and I'am realy not good with linux things.
But at one moment in the past I switched to the unstable branch.
Now I whant to come back to the stable one but can't find how to do this.I didn't even remember how I did this the first time.
I'am crawling the wiki without success.
Can anyone help.
Thank you
This tool might help you automate the process. Even if you're not good with linux things you should be able to follow along with the instructions.
https://github.com/DanalEstes/DuetVersions
Or you can use Bossa to flash your Duet board back to whatever version you choose and reflash the Pi SD card back to the latest DuetPi version. Backup your config set first.
There's also some discussion here: https://forum.duet3d.com/topic/19257/downgrade-from-3-2beta2-to-3-1-1
