ToolChanger tool data
https://forum.duet3d.com/topic/20693/which-tool-is-enabled-after-startup
@taconite wrote earlier about this, and I started doing the same on my own printer. I had the following problem:
DIY ToolChanger with Duet 3 6HC, 3HC and Raspberry pi.
If i write to console
M560 P"0:/sys/test"
or run macro like that
M560 P"/sys/test" <!-- **EoF** -->
or whatever else, "Error: M560: Can't open file test for writing" appears...
If i write
M98 P"0:/sys/test
it will run that macro.
Is Raspberry pi somehow causing the trouble here or what?
It looks like M560 isn't implemented in DSF yet so I'll add that to the TODO list.
Nevertheless M28/29 should work. Can you use that instead?
@chrishamm i will try that. Is this correct way to do that? So it will make a file to sys directory named ToolActive.g and in this file is text T0?
toolchange macro T0
; T0 M28 /sys/ToolActive.g T0 M29
@K01571N3N Yes, exactly.
