3 mm (2.85) vs 1.75 mm filament
@arhi thanks for the info. I’m using the Titan aqua which has a 3:1 gear reduction and a nema 17 motor. I do find that I don’t get the best details on small prints using a 0.4mm nozzle but it’s not awful. I’m torn as I would like to print larger thing faster so using the 1mm and 1.2mm nozzle. And that sounds like I’m not even close to what you are extruding.
Should I try the super volcano? Or just change to 1.75mm filament and keep the volcano hot end? I see dyze makes the typhoon which looks like the cats meow of extruders but at 2600USD it a tad expensive For my current needs.
@baird1fa said in 3 mm (2.85) vs 1.75 mm filament:
details are related to extruder precision and nozzle size, assuming you are not skipping any steps, 1:3 with 400step/rev motor on titan should be enough wrt precision, but I doubt it's enough wrt torque if you are not using the heavy 60mm long motor there.
Dunno really. I think you should ping E3D support and ask them why what you already have don't work as they designed the 3mm heatbreak for 3mm filament so it should work, they maybe have idea how to make it work.
I never tried those long melt zone hotends as I never believed that possible and with big nozzles oozing is a serious problem. I'm more for powerful heater on the short melt zone. It is not safe (as it can melt the aluminium if something goes terribly wrong) but works for me. I don't know if there's a commercial system that work like this. I know some PRC manufacturers sell barrel type ceramic heaters that are very close to what I design for myself.
I'm not 100% sure but I think 1.75 and 3mm heatbreak for titan are not the same on the heatsink size so to get 1.74mm titan you need a whole new thing, not just a new heatbreak, but I might be wrong.
Should you move to 1.75 from 3mm ... when I started 3mm was the norm so I became used to it and that's the only real reason I still have 3mm hotends. I use the 3mm only for nozzle size 1.5mm and bigger as with 1.75mm filament you can't do 1.5+ really as the filament don't melt, it just go trough so you really need a 3mm filament and you need to crank up the heat. I have 2 zones on these nozzles, basically 2 heaters next to each other, first is wound longer and is set to temp you would normally use to print with that plastic, second is closer to the orifice, 2 coils of khantal only, set 20-30C over the printing temperature, everything coated in fire-cement. TBH I never tried this e3d combination with heatblock and nozzle crewing from one side, heatbreak from other side for 3mm that I liked the performance, the only commectially awailable hotend for 3mm that I tried and that worked ok were 1730 and hexagon and the "wound" stuff still work better. I stil have makergear hotend (like this one https://youtu.be/OgvX7L2bGCw not the v2/v4 stuff original v0
) that works awesome
there's probbly a reason why they make it and why it cost that much but if you ask you don't need it
that's my take on it.
looking at typhoon
4.6:1 transmission and NEMA23 motor
dual melt zone, 400W heater
this is where filament enter
this is where it exit
notice the mesh between melt zone and the nozzle
This is some seriously engineered and not easy to manufacture device so it is priced accordingly
... but you can take a lot of info from it
@arhi thanks for the info. I got frustrated today and swapped in my 1.75mm Titan aqua. I kept the volcano block as that is the same. But I changed out the whole extruder, heat break, and nozzle as those are all specific to the filament diameter in the Titan aqua.
So far I’m much happier with it. I’m now printing at 120mm/s with a 0.4mm nozzle and 0.2mm layer height and 0.48mm width. With 3mm I was barely able to get printing at 40-60mm/s with the same setup.
I don’t think torque was a problem nor precision (837steps/mm) as there was plenty of power to just shred the filament. I think the other part of the equation is the ability to grip the filament and transfer the power to it. The Titan seems to lack that ability.
I don’t intend to go over 1.2mm nozzles so I think I’ll be happier with the 1.75mm filament. The only downside I see is I’m going to be stuck with lots of 3mm filament for a while. My secondary extruder is still 3mm for now so I can still use it, but that will also change eventually.
The typhoon uses a quad drive similar to some wire feed welders.
Yes, I think titan uses same hobbed gear for 3 and 1.75 so might not be optimal for 3mm.
There's no need to use 3mm then, except if you have bunch on stock so want to use it up.
use the 3mm with huge nozzle for the infill and you will use it up quickly
@arhi I’m rather old school, and have a pretty slow bed slinger with Prusa i2 style horizontal X axis, with Greg’s extruder and X carriage, using direct extruded 3mm filament. Hot end is a genuine J head With 0,4 nozzle. I print up to 60mm/s usually 0.2mm layer height, and this works well for functional prints with not too obvious layers.
However, the hobbed bolt on my Greg’s extruder has been a weak point for a long time. Having fitted a (cloned) BMG for 1.75mm filament on my Delta, I really liked the dual hobbed bolts, and it always has good grip, with no noticeable drop in extrusion as speed increases. I looked for a similar direct drive replacement for the 3mm Greg’s, but there’s only the Bontech QR (with stepper driver gearbox) or DDG (Ultimaker upgrade) 3mm extruders, neither suitable for mounting direct drive.
So I’m currently hacking on the OpenSCAD code to put Bondtech gears from the QR in the Greg’s extruder. 3mm filament may be passé in the 3D printing world, but those of us who still use it deserve better gripping extruders!
I’m trying to do 2 versions, one using the Greg’s layout, and one using the Ultimaker geared setup, which would be closer in size and layout to the BMG and Titan, hopefully. I’ll let you know how I get on!
PS if anyone in the UK wants to donate their old, unused 3mm filament to me, I’m more than happy to take it off your hands!
@droftarts said in 3 mm (2.85) vs 1.75 mm filament:
I was pushing 80mm/sec .5mm "line" .35mm layer with .4mm jhead and wade's extruder so it should work ok
IIRC Greg's extruder is slightly modified Wade's right, uses same hobbed bolt? I think I have one of the Arcol.hu hobbed bolts for Wade's extruder cnc'ed and quenched lying around unused, lemme check if I can find it and if you want it I can ship it for free :), They have awesome grip. I used it 99.9999% with ABS but Arcol was using them on PLA so both should work ok.
I ordered some original gears from Bondtech while back in order to design extruder similar to wade/greg that uses Bondtech drive gears. The gears are in the original packaging for over two years
I never found time/inspiration to even start that project
so if you do it, please share
@arhi said in 3 mm (2.85) vs 1.75 mm filament:
Yes, Greg's extruder is a modified Wade's. I'm actually using this one which is further refined: https://www.thingiverse.com/thing:18379 and there's a lovely history article about extruder development here: https://reprap.org/wiki/Genealogy_/_Archeology_of_the_Greg's_Wade's_Geared_Extruder
My hobbed bolts are all home made, which probably explains the slipping! Thank you very much for the offer, but generally my extruder is reliable so long as I don't print too fast and there is no inconsistency in the filament. My J Head is the other weak point, as it has the original 5.6ohm heater resistor (at 12V = 25W!). I think I'll only want to rebuild it again with the Bondtech gears and one of the 3mm E3D v6 hot ends I have kicking around.
...so if you do it, please share
Will do!
I was also making them myself with M3 and M4 thread cutter. Arcol was doing some testing with both what I and he made manually and with some of the one sold commercially (makergear and some others) and shown that they do not properly grab filament so he worked with his local machinist and they made a rig that was cutting them "straight" and not under angle (what thread cutter does) and the teeth were shaped differently too - dunno how the tool looked exactly never seen it myself. But the difference in "grabbing" is huge
If you change your mind ping me via IM .. I believe the "screw" can go into a simple envelope and will cost nothing to ship so ..
After a long time not managing to finish off my version of a 3mm extruder using Bondtech gears, I ended up buying a Orbiter v1.5 and modifying it for 2.85/3mm filament. This was pretty easy, just drilled out the filament path to 3.5mm and fitted the hobbed gears from a Bondtech DDG (available separately, too). Works well and is tiny! Here it is printing a Benchy on my old-school bed-slinger.
And yes, I should probably clean up the rusty rails and bearings...
