bl touch
@bks31 said in bl touch:
M307 H7 A-1 C-1 D-1 ; Disable Heater 7 for use with BLTouch
this is not valid in rrf3
B4138 is incorrect. find the correct value in your thermistor documentation.
one is zprobe won't deploy
you did not post your deploy script.
other is driver disconnected
what does that mean?
mesh leveling carriage goes violently to side than front etc
does normal movement work ok?
did you acutally update to rrf3 ?
@Phaedrux yes that makes sense and sorry for the ill-informed post I was at work and trying to remember what errors I was getting last night what info do you need
@Veti yeah the true value is actually in my config.override the only two things in there is the PID tuned for h1 and h2 didn't seem the need to post that since I was at inquiring about the BL touch and z homing
@Veti my bad sorry I was working and confused but somehow when I got home i must of switched my config file or something but everything was off got everythimg homing right and got bed heater and sensor working but heater is showing -273 °c I changed the thermistor checking for a short but that's the the case I ran a m98 and says missing p paramater not sure where tho but what should my h1 look like ; Configuration file for Duet WiFi (firmware version 3)
; generated by RepRapFirmware Configuration Tool v3.2.2 on Fri Feb 12 2021 23:35:01 GMT-0800 (Pacific Standard Time); General preferences
M550 P"My Printer" ; set printer name
M669 K1 ; select CoreXY mode; Network
M552 S1 ; enable network
M586 P0 S1 ; enable HTTP
M586 P1 S1 ; enable FTP
M586 P2 S1 ; enable Telnet; Drives
M569 P2 S0 ; physical drive 2 goes backwards
M92 X80.00 Y80.00 Z415.00 E420.00 ; set steps per mm
M566 X18000.00 Y9000.00 Z300.00 E120.00 ; set maximum instantaneous speed changes (mm/min)
M203 X36000.00 Y36000.00 Z600.00 E1200.00 ; set maximum speeds (mm/min)
M201 X5000.00 Y5000.00 Z250.00 E10000.00 ; set accelerations (mm/s^2)
M906 X1200 Y1200 Z1200 E1200 I30 ; set motor currents (mA) and motor idle factor in per cent
M208 X300 Y300 Z350 S0 ; set axis maxima; Endstops
M574 Z1 S1 P"zstop" ; configure active-high endstop for low end on Z via pin zstop; Z-Probe
M950 S0 C"exp.heater3" ; create servo pin 0 for BLTouch
M558 P9 C"^zprobe.in" H5 F120 T6000 ; set Z probe type to bltouch and the dive height + speeds
G31 P500 X0 Y40 Z2.5 ; set Z probe trigger value, offset and trigger height
M556 S50 X0 Y0 Z0 ; set orthogonal axis compensation parameters
M557 X15:300 Y15:215 S20 ; define mesh grid; Heaters
M308 S0 P"bedtemp" Y"thermistor" T100000 B3950 ; configure sensor 0 as thermistor on pin bedtemp
M308 S1 P"e1temp" Y"thermistor" T100000 B4092 C220 ; configure sensor 1 as thermistor on pin e1temp
M143 H1 S325 ; set temperature limit for heater 1 to 325C; Fans
M106 P0 S1 H-1 ; set fan 0 value. Thermostatic control is turned off
M106 P1 S1 H-1 ; set fan 1 value. Thermostatic control is turned off; Tools
M563 P0 S"Dragon " D0 H1 F0:1 ; define tool 0
G10 P0 R0 S0 ; set initial tool 0 active and standby temperatures to 0C; Custom settings
m552 s1; Miscellaneous
M911 S10 R11 P"M913 X0 Y0 G91 M83 G1 Z3 E-5 F1000" ; set voltage thresholds and actions to run on power loss -
m98
M98 P"config.g"
i dont know what you are referring to.
@Veti my heater config you said earlier b value doesn't belong trying to get my heater #1 for hotend not to fault
i said the beta value is incorrect.
that is not for the heater but for the thermistor. the temperature measuring device.
the beta values is used to determine the actual temperature.
if you have a wrong value, the actual temperature will differ from the one displayed -
@Veti yea I get that but wouldn't that cause for my heater to throw error code sorry let me clarify what would be the correct parameter for my hot end thermistor because temp shows -273
find the correct value in the thermistor documentation
@Veti I couldn't find it I have this one
https://drive.google.com/file/d/1CHXDbUG8WG3f8CZNC7Jd5tqt5fijnu20/view?usp=drivesdkrl) -
that file is protected
please link to the actual amazon page.
maybe its in the description -
its written in the details
Negative Temperature Coefficient (NTC) Thermistor Model: B3950
