Help me get connected to my Duet2Wifi
Can you try access the DWC ip address from an incognito chrome window?
@Phaedrux Ok for some reason it connected to the board with the incognito window
I think you have a browser extension blocking the connection or somehow modifying it.
@Phaedrux yea has to be something like that. At least now I have the URL reserved on the router. I can get by on the incognito window until I figure out what is interrupting the connection
So I ended up moving my operation into a commercial building and I need assistance getting the Duet connected to the new network. I installed YAT but M552 came back with "BAD Command"
screen shot?
Think I got passed the Bad command but still not sure how to proceed.
Here's a step by step guide with pictures
https://duet3d.dozuki.com/Guide/1.)+Getting+Connected+to+your+Duet/7
@Phaedrux I'm Following that right now but M552 commands are not providing the desired result for me to proceed to the next step
Please change your line endings in YAT to make it readable.
Set YAT to use <LF> as the end of line character. This will improve the readability of the messages coming from the Duet. Click "Text Settings" in the "Terminal Settings" and change "EOL sequence:" to <LF>. Click "OK" to close Text Settings. Click "OK" again to close Terminal Settings.
@Kwad3d said in Help me get connected to my Duet2Wifi:
It's hard to tell with the wonky line endings splitting up the responses.
@Phaedrux Ok give me a sec. I noticed I forgot the - in M552 S-1 command and Im making some headway
@Kwad3d Ok Im Good. Sorry for the false alarm. It was all just a Typo error on my part holding me back
