Fans not working after updating to RRF3.2
@GPetropoulos said in Fans not working after updating to RRF3.2:
M950 F0 C"nil" ; disable fan 0 and free up the associated pin M950 F1 C"nil" ; disable fan 1 and free up the associated pin
Can you remove these? as they aren't needed
@jay_s_uk Yes. I added them while looking into other posts just in case..
You should not need to do this.
M950 F1 C"nil" ; disable fan 1 and free up the associated pinThis should be fine as the slicer generates the commands to set the speed.
M106 P0 S0 H-1 ; set fan 0 value. Thermostatic control is turned offOn this one you have set the max speed to be 1 out of the range 0 to 255. Change the S parameter to 255 or 1.0.
M106 P1 S1 H1 T45 ; set fan 1 value. Thermostatic control is turned onLet us know if that solves your problem.
@fcwilt said in Fans not working after updating to RRF3.2:
1 is a valid input
@fcwilt Removed the nil ones
I cannot turn on the Fan0 from the dashboard.
Changed this to 255
M950 F1 C"fan1" Q500 ; create fan 1 on pin fan1 and set its frequency M106 P1 S255 H1 T45 ; set fan 1 value. Thermostatic control is turned on
I do not see a difference. It does not turn on when printer starts/reboots like it used to.
And it does not work at 46deg either as it should. -
@jay_s_uk said in Fans not working after updating to RRF3.2:
1 is a valid input
Yes if you want the max speed to be 1 instead of 255.
I'm sorry but that is incorrect.
1 is a valid input for full speed.
It does not need to be 1.0 -
@jay_s_uk I used to have it 1 in RRF2.05 and worked.
I do not think that is the problem either, and tried the 255 too as a value.No change
It does not need to be 1.0Not according to the documentation.
These are my fully working fan settings for 3.2
M950 F0 C"fan0" Q500 ; create fan 0 on pin fan0 and set its frequency M106 P0 S0 H-1 ; set fan 0 value. Thermostatic control is turned off M950 F1 C"fan1" Q500 ; create fan 1 on pin out4 and set its frequency M106 P1 S1 H1 T45 ; set fan 1 value. Thermostatic control is turned on
Then the firmware is not processing the parameter according to the documentation.
@fcwilt
If my setting of 1 is only setting 1/255 of the fan speed, then my printer would be able to fly with a setting of 255. -
@fcwilt
If my setting of 1 is only setting 1/255 of the fan speed, then my printer would be able to fly with a setting of 255.I am simply following the documentation:
Snnn Fan speed (0 to 255 or 0.0 to 1.0)
Perhaps the firmware treats 1 as a special case - I don't know - I never tried it.
From the DWC console do this M98 P"config.g" and see if it reports any errors.
Exactly
Why would I ignore the documentation?
@fcwilt This is the reply
M98 P"config.g" HTTP is enabled on port 80 FTP is disabled TELNET is disabled Error: Heater 3 not found Error: Height map file 0:/sys/heightmap.csv not found Warning: Heater 0 appears to be over-powered. If left on at full power, its temperature is predicted to reach 255C
I don't know if this error could be related to the fan problem but it cannot hurt to fix it.
You should not be trying to load the height map in your config.g file - so remove the G29 S1 - I doubt it is related to the fan problem but you never know.
It should not matter as I did not change anything in the fans connections. But I added a BLtouch so posting a picture of the wiring just in case you see anything weird.
@fcwilt I do not think so either.
But not sure why there is an indication about heater 3
