Update CR-10+Duet wifi from 2.05.1 to 3.0 firmware
Could be anything in the new config i uploaded?
@Hélder-Rocha said in Update CR-10+Duet wifi from 2.05.1 to 3.0 firmware:
@Phaedrux yap....is the same
that is not the exact error message
Try clearing your browser cache.
And if that doesn't work, I would check the /www folder on the SD card and replace the files there with a fresh copy of DWC.
https://github.com/Duet3D/RepRapFirmware/releases/download/3.2/DuetWebControl-SD.zip
at the momment on YAT, it is sayng that the wifi module is connected to my home network! Do you know ohow to disable it, and reeturn to Duet access point?
Send M552 S2 to start up in access point mode (if it is already running in station mode then you need to send M552 S0 first).
@Veti keeps saying "Enable to connect after i digit the IP on adress bar. I can stablish the access point, but cant access the DWC.
The blue signal on the board is lit
Are you wanting to run in access point mode where you connect to the Duet directly with your PC/phone? Or normal mode where the Duet connects to your home wifi network?
In access point mode you need to connect to the Duet SSID with your PC.
@Phaedrux yes i know. After i upload my new config, i stoped having accesse to my DWC pannel. Because of that, i used M587 to privid me a different door to the DWC. Now i have a mess in my hands!!! I still can create a wifi signal from the Duet, the access point, but i cant open the DWC pannel. Says "Enable to connect".
It would help to see exactly what gcodes you are sending and what the responses are.
I still don't know if you're trying to use access point mode or not.
@Phaedrux i send the M552 S2 and i recieve the message:
"ok<LF> wifi module is providing access point DuetCr10, IP address 192.168.1.1<LF>
192.168.1.1
and you are connecting to the access point and goint to http://192.168.1.1 ?
To access that IP address you must connect your PC to the wifi network
DuetCr10
first. You won't have internet access when connected to that access point. -
@Phaedrux im confuse. How do i connect to DuetCr10?
Ah...ok...i know that
im confuse.
Agreed.
M552 S2 turns the Duet into it's own WIFI network.
You need to connect to that network on your PC or phone or whatever device that has wifi. From that device you will then be able to reach 192.168.1.1 for the DWC.
If that is not what you want, then you should use M552 S1 and connect your Duet to the WIFI network in your home using M587 to add the SSID name and password.
Then you would be able to reach the DWC from the IP of the Duet, which you would find by sending just M552.
i select on my PC that wifi connection... only after i have that wifi signal on my PC, o open the browser and try to connect to the IP. But never opens the DWC panel
@Phaedrux said in Update CR-10+Duet wifi from 2.05.1 to 3.0 firmware:
im confuse.
Agreed.
thats what i am doing
Ok, when you try to reach the IP of the DWC, what exactly does the error message say?
When you send M552 by itself at this point, what does it say?
Can you post M122 from this state as well please? -
@Phaedrux the message i get is "Enable to connect" .
im using a different PC to talk t you. Difficult to post anything. Im going to send the M122 now
