Duet 3 mini 5+ sensorless homing will not work
@fcwilt I will not redesign my printer setup to use endstops. The card says it support sensorless homing so that feature should work right? It has worked fine for years using duet 2 card. It took me 2 minutes to get it setup there and now it is a pain in the but.
Regarding s3 it clearly says single motor. A coreXY don’t have a single motor ️
Unless @dc42 have a suggestion it is time for me to leave rrf and move over to klipper where I know sensorless homing works with 2209 drivers. -
Did you follow @gloomyandy s suggestion to try the inverted sensitivity setting?
@oliof yes I replied to him and said it did not work using 64. At -64 it should trigger directly which it does not. It does not even trigger which means something is not working. Either it is a broken firmware or wrong code we can’t figure out.
I believe it to be firmware though since even if downloading 3.2 firmware we are stuck on beta, Wonder why they don’t fix that ️ -
I'll try a small setup tonight.unfortunately my mini beta board is on a version that doesn't support sensorless homing yet and won't be updated anymore. But downstream I see your problem with sensorless homing was fixed, so yay! -
@Alucardi said in Duet 3 mini 5+ sensorless homing will not work:
if you are on the beta, then stall detection is not implemented
to update see
https://forum.duet3d.com/topic/20382/unable-to-update-firmware-on-duet-mini-5-ethernet -
TBH, I couldn't get mine to stall with a simple movement with S set to -64 either.
@Veti why is this not fixed in the stable release?
it is. but the problem is your current programmer
@jay_s_uk which means something is not working. It should detect directly. I tried it in my old duet 2 when I was setting that up. It detected a stall as soon as it tried to move the axis.
@Veti my current programmer?
have you read the linked thread?
@Veti yes and I am no coder so I do not know what a iap file is ️ Thread is a month old.
just replace the iap file linked in the thread and update the firmware again.
@Veti I have uploaded that file to my card and managed to update I believe. But why does it have to be manually fixed? Not everyone goes to the forum and look on that thread. I downloaded 3.2 a week ago and assumed it was working fine cause I got no error. Just by luck did I see it still said beta when looking around in the menus. I then redownloaded the needed files but it was still on beta.
This might be one thing that cause my issue. Changed to X2 and Y2 and it seem to work.
; Endstops M574 X1 S3 ; configure sensorless endstop for low end on X M574 Y1 S3 ; configure sensorless endstop for low end on Y M574 Z1 S2 ; configure Z-probe endstop for low end on Z
All these posts and we forgot to verify what firmware you were using?
That's a bit embarrassing.
@fcwilt not firmware issue it was endstop issues. Card was on rc2 when it came, sensorless homing worked then.
I had this code though M574 X1 S3 but it should be M574 X2 S3. Now it homes x and y. Still get G28 homing failed though. After X and y it just sits there. Will not issue a move to center of the plate. So if you have any input on my z homing sequence that would be awesome. Z axis is reported as homed though. -
So if you have any input on my z homing sequence that would be awesome. Z axis is reported as homed though.Do you still have this line of code:
G30 P0 G1 X167.5 Y167.5
@fcwilt yes i do.
@fcwilt yes i do.
OK then that is likely the problem.
You need to use G30 by itself.
Unfortunately G30 without a P parameter does not respect the X and Y parameters.
So you have to precede the G30 with a G1 command to move the probe to the correct XY location.
For my printer X=0 and Y=0 is the center of the bed so I can simply use the following G1 command:
G1 X{-sensors.probes[0].offsets[0]}, Y{-sensors.probes[0].offsets[1]}, F6000
to move the probe to the center of the bed.
A somewhat more complicated formula can be constructed for printers where X=0 and Y=0 is NOT the center of the bed.
