JSON Error and Connection Drops
Hello together!
have a Duet 2 Wifi in my Sapphire Pro and Updated yesterday to the latest RFF Version!
since that i always get Errors in DWC:
Unexpected token < in JSON at position 0And then the Connection losts and come back again?
Did somebody know what this is?
This Happens every time if i click on the "jobs" tab in the DWC.
I already have deleted all gcodes files, but it is the same error again -
Did you also update DWC to the latest version?
For some possible next steps.
i Uplaoded the hole ZIP file from github!
M115 says:
FIRMWARE_NAME: RepRapFirmware for Duet 2 WiFi/Ethernet FIRMWARE_VERSION: 3.2 ELECTRONICS: Duet WiFi 1.02 or later FIRMWARE_DATE: 2021-01-05 -
Now i uplaoded the whole ZIP File again, but nothing, error exists still
There's also this recent thread that I think may be related:
https://forum.duet3d.com/topic/20764/3-2-json-parse-error-unrecognized-token?_=1610948929338
Can you open the developer console of chrome when you get the error and share what it shows?
Can you check that DWC has also been updated to version 3.2?
It may be worth deleting the entire /www folder and replacing it with the contents of the DWC 3.2 zip file.
https://github.com/Duet3D/RepRapFirmware/releases/download/3.2/DuetWebControl-SD.zip
