Problem with rear side of Test Cube
Thank you for agreeing with me about the quality @alankilian
Here is the *.gcode file xyzCalibration_cube-brim-100%-opt-start.gcode -
I don't think you can attribute that to the slicer settings.
I think you have extruder hardware problems.
Have you calibrated the extruder multiple times to see if it remains consistent.
Have you watched the extruder temperature readout during printing to see if it is remain consistent.
The extruder temp is 235C and I have experimented with bed temps from 80C to 120C. I didn't really notice much change, except that with a bed of 80C, adhesion was deteriorating.
I haven't recalibrated the extruder, but I think my temperature is consistent. The window in the browser that shows the temp is consistent. I'm just running the cube now, so that I can post the temp readouts.
@dmbgo said in Problem with rear side of Test Cube:
I didn't see that you mentioned the kind of filament you are using.
For PLA I use 200 for the extruder and 60 for the bed but keep in mind my 200/60 may not match you 200/60 - it all depends on the thermistors and how correct the thermistor configuration values are.
For speed I use 60 mm/s to 90 mm/s depending on desired quality with the first layer at 15 mm/s.
@dmbgo Can you File->Save Factory File as... and post it?
That way I can see your slicer settings and all that. -
Thanks Fredrick, I am using ABS.
No worries @alankilian here it is:
[0_1610836772941_xyzCalibration_cube.factory](Uploading 100%) -
@dmbgo Try that upload again please.
Also, what filament are you using?
I print PLA at 60C bed and 205C extruder, so you're significantly hotter than I am.
I'll try renaming it to *.txt, you'll have to change it to *.factory:
xyzCalibration_cube.factory.txt -
I am using ABS filament.
On the filament roll, it recommends Extruder 220 to 260C Bed 100 to 110C
Do you have a heated enclosure?
I'm afraid I'm out of my experience zone with ABS.
I have read not to use fans for the first 3 layers, but that's not your problem.
Do you see filament extruding on the back cornets?
Do you hear your extruder struggling/clicking when that happens?
Can you rotate the cube 180-degrees to see if it then happens on the front?
Can you rotate the entire printer 180-degrees to see if it changes due to airflow?
Do you have an enclosure?
My only ABS experience is using a Stratasys where everything is controlled for me and it works perfectly.
Someone with more ABS experience will probably jump in next and hopefully be able to help you more than I can.
I do have, but the printer isn't in it at present while I'm working on it. I usually drop the bed temp down when the printer's in there.
From what I have read ABS really needs a heated enclosure BUT I don't know if that is related to your problem.
@alankilian said in Problem with rear side of Test Cube:
1/ Do you see filament extruding on the back cornets?
2/ Do you hear your extruder struggling/clicking when that happens?
3/ Can you rotate the cube 180-degrees to see if it then happens on the front?
4/Can you rotate the entire printer 180-degrees to see if it changes due to airflow?
5/Do you have an enclosure?1/ Back cornets?
2/No clicking, extruding nicely when I move it up and extrude some filament.
3/I should have mentioned that I had done that, it still happens on the rear (mainly)
4/The pinter is on a wheeled trolley, I have tried that. Ambient temp is 18.4C atm. -
"From what I have read ABS really needs a heated enclosure BUT I don't know if that is related to your problem. Frederick"
Yes, I found that out a while ago, which is why I made the one in the pic. It is made from 50mm expanded foam, coated with thin fiberglass panels. The material came from an old coolroom.
