[Video] Adding a USB Webcam to DWC with a Raspberry Pi
I've tried a few different packages that present the Pi camera as a web cam. The simplest I have found (and one I currently use) is here:
http://picamera.readthedocs.io/en/latest/recipes2.html#web-streaming
I have used it in the past with DWC but do not normally. I use it daily as a web cam for general monitoring of my printer http://<ip address:port> and as a feed to timelapse software.
Having said that I just tried with DWC. There does seem to be a problem with DWC in the version I have (1.23). It does not "like" the URL. It sometimes even adds irrelevant paths to the url for the camera. For example I put in http://<ip address:port> and it changes it to http://<ip address:port>/Job. So there may be an issue there - or I simply am not doing something right.
EDIT: Solved the issue - entirely my error. Needs to be in an iframe
@stuartofmt said in [Video] Adding a USB Webcam to DWC with a Raspberry Pi:
That's a quite old version of DWC now as well. Things are a bit different in DWC3.x
Sorry - I have DWiFi Server 1.23 and DWC 3.1.1 -- looked but didn't look
brilliant, thank you. I never knew how to make it work but that step by step guide is of great help.
I seem to be stuck halfway though; I installed snapd and mjpg streamer and everything seems to be running well (see the snapd process)
pi@duet3:~ $ ps -A PID TTY TIME CMD 1 ? 00:00:06 systemd 2 ? 00:00:00 kthreadd 3 ? 00:00:00 rcu_gp 4 ? 00:00:00 rcu_par_gp 7 ? 00:00:00 kworker/u8:0-events_unbound 8 ? 00:00:00 mm_percpu_wq 9 ? 00:00:00 ksoftirqd/0 10 ? 00:00:00 rcu_sched 11 ? 00:00:00 migration/0 12 ? 00:00:00 cpuhp/0 13 ? 00:00:00 cpuhp/1 14 ? 00:00:00 migration/1 15 ? 00:00:00 ksoftirqd/1 18 ? 00:00:00 cpuhp/2 19 ? 00:00:00 migration/2 20 ? 00:00:00 ksoftirqd/2 23 ? 00:00:00 cpuhp/3 24 ? 00:00:00 migration/3 25 ? 00:00:00 ksoftirqd/3 28 ? 00:00:00 kdevtmpfs 29 ? 00:00:00 netns 30 ? 00:00:00 kworker/0:1-events 32 ? 00:00:00 kauditd 33 ? 00:00:00 khungtaskd 34 ? 00:00:00 oom_reaper 35 ? 00:00:00 writeback 36 ? 00:00:00 kcompactd0 54 ? 00:00:00 kblockd 55 ? 00:00:00 blkcg_punt_bio 56 ? 00:00:00 watchdogd 58 ? 00:00:00 rpciod 59 ? 00:00:00 kworker/u9:0-hci0 60 ? 00:00:00 xprtiod 61 ? 00:00:00 kswapd0 62 ? 00:00:00 nfsiod 64 ? 00:00:00 iscsi_eh 65 ? 00:00:00 dwc_otg 66 ? 00:00:00 DWC Notificatio 67 ? 00:00:00 kworker/1:2-events 68 ? 00:00:00 vchiq-slot/0 69 ? 00:00:00 vchiq-recy/0 70 ? 00:00:00 vchiq-sync/0 71 ? 00:00:00 vchiq-keep/0 72 ? 00:00:00 SMIO 73 ? 00:00:00 kworker/1:3-events_freezable 74 ? 00:00:00 mmc_complete 75 ? 00:00:00 kworker/1:1H-kblockd 76 ? 00:00:00 kworker/0:1H-mmc_complete 77 ? 00:00:00 jbd2/mmcblk0p2- 78 ? 00:00:00 ext4-rsv-conver 79 ? 00:00:00 kworker/0:2H-kblockd 80 ? 00:00:00 ipv6_addrconf 84 ? 00:00:00 kworker/2:1H-kblockd 86 ? 00:00:00 kworker/3:1H-kblockd 101 ? 00:00:00 kworker/1:2H 102 ? 00:00:00 kworker/3:2H-kblockd 108 ? 00:00:00 irq/166-usb-001 111 ? 00:00:00 kworker/2:2H-kblockd 123 ? 00:00:03 systemd-journal 144 ? 00:00:01 kworker/u8:2-events_unbound 148 ? 00:00:01 systemd-udevd 149 ? 00:00:00 loop0 150 ? 00:00:00 loop1 172 ? 00:00:00 SMIO 179 ? 00:00:00 mmal-vchiq 180 ? 00:00:01 spi0 183 ? 00:00:00 mmal-vchiq 186 ? 00:00:00 mmal-vchiq 189 ? 00:00:00 mmal-vchiq 233 ? 00:00:00 cfg80211 241 ? 00:00:00 brcmf_wq/mmc1:0 244 ? 00:00:00 brcmf_wdog/mmc1 321 ? 00:00:00 systemd-timesyn 358 ? 00:00:00 cron 359 ? 00:00:00 rsyslogd 360 ? 00:00:00 dbus-daemon 362 ? 00:01:25 DuetControlServ 363 ? 00:00:00 thd 366 ? 00:00:00 wpa_supplicant 368 ? 00:00:00 rngd 373 ? 00:00:00 avahi-daemon 374 ? 00:00:00 alsactl 377 ? 00:00:00 systemd-logind 397 ? 00:00:02 snapd 425 ? 00:00:00 avahi-daemon 471 ? 00:00:00 wpa_supplicant 479 ? 00:00:00 kworker/3:4-events_power_efficient 534 ? 00:00:02 irq/167-dcs-trp 549 ? 00:00:00 kworker/2:2-events 553 ? 00:00:00 hciattach 555 ? 00:00:00 kworker/u9:1-hci0 557 ? 00:00:00 bluetoothd 558 ? 00:00:00 bluealsa 573 ? 00:00:00 krfcommd 628 ? 00:00:00 dhcpcd 633 ? 00:00:21 DuetWebServer 645 tty1 00:00:00 agetty 654 ? 00:00:00 sshd 666 ? 00:00:00 sshd 795 ? 00:00:00 systemd 796 ? 00:00:00 (sd-pam) 810 ? 00:00:00 sshd 811 pts/0 00:00:00 bash 834 pts/0 00:00:00 sudo 835 pts/0 00:00:00 nano 984 ? 00:00:00 kworker/0:0-events 985 ? 00:00:00 kworker/3:1-cgroup_destroy 988 ? 00:00:00 kworker/2:0-mm_percpu_wq 994 ? 00:00:00 kworker/0:0H 995 ? 00:00:00 kworker/3:0H 996 ? 00:00:00 kworker/1:0-events 1005 ? 00:00:00 kworker/u8:1-events_unbound 1053 ? 00:00:00 kworker/3:0-events_power_efficient 1154 ? 00:00:00 kworker/0:2-events 1157 ? 00:00:00 kworker/2:1-events 1159 pts/0 00:00:00 ps
mjpg is well installed
pi@duet3:~ $ sudo snap install mjpg-streamer snap "mjpg-streamer" is already installed, see 'snap help refresh'
And I've copied exactly the same config file as yours
pi@duet3:~ $ sudo nano /var/snap/mjpg-streamer/current/config GNU nano 3.2 /var/snap/mjpg-streamer/current/config INPUTOPTS="input_uvc.so -y -r 640x480 -d /dev/video0" PORT="-p 8080" DAEMON="true"
And yet when I enter my duet IP :8080, I get no response.
Any hint on what could be the issue?
Using a RPi 3B+ on Duet3
Thanks!
Which USB Camera are you using?
@PCR well I'm not; I got a raspi cam.
My first attempt was with the line
INPUTOPTS="input_raspi.so"
as described in the guide but that didn't work out either.I thought I would try with your config that seemed to be working as it seems the issue is with the interface not loading; I would assume if the camera was setup wrong the GUI would still load, just show no image.
Sorry. Raspi Cam is Not working with the SNAP. Interface will only be loade when camera is working.
I saw on github a new plugin for raspi cams for DWC
Best
@PCR Thanks, I did manage to get it working just for a few moments before it froze and I can't get it to run again lol (the interface load, not the cam)
But I'll keep trying and keep you posted
Installed on rasp pi3 with octoprint and activated on DWC with Logitech C270 webcam. It works.
Now I have to fix the Timelapse. -
@gdefranc with duetlapse easy. But use the snapshot Screen of Mjpg
And the DuetAPI from @jay_s_uk
You can turn a Pi zero+ cam as a usb webcam, using https://github.com/showmewebcam/showmewebcam
I use a PizeroW with the Pi cam module and MotionOS to turn it into a webcam. It works very well with DWC and makes for a very small and very functional cam.
