Printing
I am sure that I am missing something! My setup with Duet 2 wifi seems to be working ok. With pronterface I can get all the necessary movements, heating, and extrusions. However thing go wrong when I try to print using the reprap snowman. It appears to home all axes but does not heat up and the x axis creeps
post your config.
any errors in the console?
why are you using proterface? are you aware of https://duet3d.dozuki.com/Wiki/USB_ground_loops ?
This is driving me mad!
Attached my config file
Why am I using pronterface
a) Because I have always used it since my first printer (an Ormerod 2) bits of which were used to build My Grandfathers 3D Printer
b)I cannot get the web controller. With USB only connected (no power) and the printer connected both blue lights are on the duet. but try as I may I cannot open the web pageconfConfiguration file for Duet 0.6 (firmware version 1.21)
; generated by RepRapFirmware Configuration Tool v3.1.10 on Sun Dec 20 2020 16:32:00 GMT+0000 (Greenwich Mean Time); General preferences
M550 P"Mad Grandfathers 3d Printer" ; set printer name; Network
M540 PBE:EF:DE:AD:FE:ED ; set custom MAC address
M586 P0 S1 ; enable HTTP
M586 P1 S0 ; disable FTP
M586 P2 S0 ; disable Telnet
M552 S1
G92 X100 Y100 Z100
M569 P3 S0 ; physical drive 3 goes forwards
M92 X87.49 Y87.49 Z4000.00 E420.00 ; set steps per mm
M201 X500.00 Y500.00 Z250.00 E250.00 ; set accelerations (mm/s^2)
M906 X800 Y1000 Z800 E800 I30 ; set motor currents (mA) and motor idle factor in per cent
M208 X200 Y200 Z200 S0 ; set axis maxima; Endstops
M574 Y1 X1 S1 ; set active high endstops
M574 Z1 S2 ; set endstops controlled by probe; Z-Probe
M558 P1 H5 F120 T6000 ; set Z probe type to unmodulated and the dive height + speeds
G31 P500 X0 Y0 Z3 ; set Z probe trigger value, offset and trigger height
M557 X15:195 Y15:195 S20 ; define mesh grid; Heaters
M305 P0 T10000 B3988 R4700
M143 H0 S100
M106 P0 S0 I0 F500 H-1 ; set fan 0 value, PWM signal inversion and frequency. Thermostatic control is turned offT0 ; Tools
M575 P1 S1 B57600 ; enable support for PanelDueig.g
what duet do you have?
apparently you selected duet 1 in the config tool, yet you write you have a duet 2.what firmware version are you running?
if you are starting new and you have a duet 2 you should update to firmware 3.11.
see https://duet3d.dozuki.com/Wiki/Installing_and_Updating_Firmware
do not forget to update the wifi firmware and the duet web control.easiest is to update using bossa if you have a very old version.
then go through these steps.
https://duet3d.dozuki.com/Guide/1.)+Getting+Connected+to+your+Duet/7 -
@Veti the config may say it is for a duet o.6 but has been heavily modified. My firmware is 2.05
@Phaedrux Long, rather weary, story. I thought I had fried my ethernet duet 2 so bought a wifi one. After a while I got a config file that appeared to do what it should so put it back in the ethernet board. I connected through YAT and for the first time got an IP address, I have now connected direct to my router and the USB cable and the web console actually opens but there is an error message. "Failed to get file list"" directory 0:/macros not found
directory 0:/macros
just create that folder on the sd card
see
https://duet3d.dozuki.com/Wiki/SD_Card -
When you have a USB terminal up please send M122 and M98 P"config.g" and post the results.
What do you have on your SD card? It sounds like you're missing the directory structure. Are you perhaps also missing the web interface files as well?
https://duet3d.dozuki.com/Wiki/SD_Card#Section_Creating_the_file_structure
@Phaedrux Yes I am probably missing something . I have inputted 'Duet2CombinedFirmware.bin' and confirmed that I have 2.05.1 entered. I have also loaded 'iap4e.bin'but I think need a web control input.
I suspect that my sys file is in a bit of a mess so will start from the beginning
@Veti OK so I create a folder but where do the files for that folder come from,?
thats where your macros go
@Veti thanks that seems to have done it
