Cannot initialise SD card 0: Card is unusable (DuetWifi)
Just discovered, after relaunching my BigBox3D after quite some time, that I'm having an issue with reading my SD card.
Might it be a bad soldering issue?What to do?
Regards
Tim -
Your link doesn't work.
Can you post the results of sending M122?
Does the SD card show up in your PC? -
Link fixed
SD card works just fine on the PC
Really looks like this : https://duet3d.dozuki.com/Wiki/SD_Card#Section_SD_Card_Socket -
Do you happen to have another SD card to test with just in case?
Where and when was the Duet purchased?
I'll try later today tomorrow with another sd card
M122 shows there is an sd card
M20 shows an empty list.
Bought here, 2 years ago -
Same result.
Might it help if I heat the 3 last pins? (With a good soldering iron) -
Yes if you think you have a good soldering tip for the job you may be able to reflow it in case that is the issue. The entire slow can be replaced as well but likely will require hot air.
Hi
Update:
Reheating the pins seems to have doe the trick for now.
Will need to keep a close watch on this, that the issue doesn't reappear.
Thx in advance
T.
