First Layer Way Too High / Extrusion is off?
@Phaedrux here is the current "config.g" file
; generated by RepRapFirmware Configuration Tool v3.1.10 on Sun Dec 20 2020 20:13:30 GMT-0700 (MST); General preferences
M550 P"Genesis" ; set printer name; Network
M551 P"REDwagon12!!" ; set password
M586 P0 S1 ; enable HTTP
M586 P1 S0 ; disable FTP
M569 P0 S0 ; physical drive 0 goes backwards
M92 X80.00 Y80.00 Z400.00 E420.00 ; set steps per mm
M566 X600.00 Y600.00 Z60.00 E300.00 ; set maximum instantaneous speed changes (mm/min)
M203 X9000.00 Y9000.00 Z600.00 E1200.00 ; set maximum speeds (mm/min)
M201 X500.00 Y500.00 Z120.00 E250.00 ; set accelerations (mm/s^2)
M906 X800 Y800 Z800 E900 I30 ; set motor currents (mA) and motor idle factor in per cent
M208 X300 Y220 Z300 S0 ; set axis maxima; Endstops
M574 X1 S1 P"^xstop" ; configure active-high endstop for low end on X via pin ^xstop
M574 Y1 S1 P"^ystop" ; configure active-high endstop for low end on Y via pin ^ystop
M574 Z1 S1 P"^zstop" ; configure active-high endstop for low end on Z via pin ^zstop; Z-Probe
M558 P0 H5 F120 T6000 ; disable Z probe but set dive height, probe speed and travel speed
M557 X15:285 Y15:205 S20 ; define mesh grid; Heaters
M308 S0 P"bedtemp" Y"thermistor" T98801 B4185 ; configure sensor 0 as thermistor on pin bedtemp
M143 H0 S100 ; set temperature limit for heater 0 to 100C
M308 S1 P"e0temp" Y"thermistor" T98801 B4185 ; configure sensor 1 as thermistor on pin e0temp
M143 H1 S250 ; set temperature limit for heater 1 to 250C; Fans
M950 F0 C"fan0" Q20 ; create fan 0 on pin fan0 and set its frequency
M106 P0 S0.9 H-1 ; set fan 0 value. Thermostatic control is turned off
M950 F1 C"fan1" Q20 ; create fan 1 on pin fan1 and set its frequency
M106 P1 S0 H1 T45 ; set fan 1 value. Thermostatic control is turned on; Tools
M563 P0 S"HotEnd" D0 H1 F0 ; define tool 0
T0 ; select first tool -
@Phaedrux here is the "homeall.g"
; homeall.g
; called to home all axes
G91 ; relative positioning
G1 H1 X-305 Y-225 F1800 ; move quickly to X and Y axis endstops and stop there (first pass)
G1 H2 X5 Y5 F6000 ; go back a few mm
G1 H1 X-305 Y-225 F360 ; move slowly to X and Y axis endstops once more (second pass)
G1 H1 Z-305 F360 ; move Z down stopping at the endstop
G90 ; absolute positioning
G92 Z0 ; set Z position to axis minimum (you may want to adjust this); Uncomment the following lines to lift Z after probing
;G91 ; relative positioning
;G90 ; absolute positioning -
@Phaedrux M122:
M122
RepRapFirmware for Duet 2 WiFi/Ethernet version 3.1.1 running on Duet Ethernet 1.02 or later
Board ID: 08DGM-917DA-G4MSJ-6J1F4-3S06K-99PRB
Used output buffers: 3 of 24 (10 max)
Static ram: 27980
Dynamic ram: 93520 of which 24 recycled
Exception stack ram used: 256
Never used ram: 9292
Tasks: NETWORK(ready,368) HEAT(blocked,1224) MAIN(running,1880) IDLE(ready,80)
Owned mutexes:
Last reset 00:37:09 ago, cause: power up
Last software reset at 2020-12-20 17:08, reason: User, spinning module GCodes, available RAM 9084 bytes (slot 0)
Software reset code 0x0003 HFSR 0x00000000 CFSR 0x00000000 ICSR 0x0441f000 BFAR 0xe000ed38 SP 0xffffffff Task MAIN
Error status: 0
MCU temperature: min 20.3, current 26.7, max 27.1
Supply voltage: min 12.1, current 12.2, max 12.3, under voltage events: 0, over voltage events: 0, power good: yes
Date/time: 2020-12-21 12:26:23
Slowest loop: 147.19ms; fastest: 0.12ms
=== Storage ===
Free file entries: 10
SD card longest read time 2.0ms, write time 0.0ms, max retries 0
Hiccups: 0(0), FreeDm: 169, MinFreeDm: 169, MaxWait: 0ms
=== MainDDARing ===
Scheduled moves: 0, completed moves: 0, StepErrors: 0, LaErrors: 0, Underruns: 0, 0 CDDA state: -1
=== AuxDDARing ===
Heater 1 is on, I-accum = 0.0
Segments left: 0
Movement lock held by null
HTTP is idle in state(s) 0
Telnet is idle in state(s) 0
File is idle in state(s) 0
USB is idle in state(s) 0
Aux is idle in state(s) 0
Trigger is idle in state(s) 0
Queue is idle in state(s) 0
Daemon is idle in state(s) 0
Code queue is empty.
=== Network ===
Slowest loop: 155.28ms; fastest: 0.02ms
HTTP sessions: 1 of 8
Interface state active, link 100Mbps full duplex -
@Phaedrux here is that M98 result
M98 P"config.g"
HTTP is enabled on port 80
FTP is disabled
TELNET is disabled
Warning: Heater 0 appears to be over-powered. If left on at full power, its temperature is predicted to reach 365C
Warning: Heater 1 appears to be over-powered. If left on at full power, its temperature is predicted to reach 413C -
So after deleting M201, M203, M204, M205, M220, M221 from the "Start G-Code" section of the printer settings within Cura, the status quo has changed a little bit.
I also manually leveled the bed with the bed heater set at 50 C and 200 C for the nozzle.
@tmeryhew said in First Layer Way Too High:
Would it be pulling the Start / Stop gcode from this Preferences menu for what I have called "New Style" printer?
Yes.
If you're still printing too high, you need to change either the position of the Z axis endstop switch so that the nozzle is just touching the bed when it stops, or set the actual distance between the nozzle and the bed in the homeall.g file.
G1 H1 Z-305 F360 ; move Z down stopping at the endstop G90 ; absolute positioning G92 Z0 ; set Z position to axis minimum (you may want to adjust this)
G92 Z0 could be changed to whatever the gap is between the bed and the nozzle. So if the nozzle is 1mm above the bed when the endstop switch is triggered, you'd use G92 Z1.
Getting the bed nice and level will be the first thing. Beyond that you would need to use mesh compensation with a Z probe to measure multiple points on the surface of the bed to be able to adjust for a curved bed or other imperfections.
So I believe I may have solved the issue of the extruder being too high off the bed, maybe. As soon as I can I will instal a Z probe as it seems that’s the best way to go.
But check out my pictures below, what would cause my test prints to come out like this?
If that's the bottom layer, likely over extrusion, either from being too close to the bed or extruding too much plastic.
Maybe give this a read.
https://duet3d.dozuki.com/Guide/Ender+3+Pro+and+Duet+Maestro+Guide+Part+4:+Calibration/40
I added some more pictures to that post. I didn’t think you’d get to a response so quick!
So are you saying I should go through and calibrate extruder steps per mm? Step 5 on that link you sent me?
Also, since you seem to have so many answers to my questions, what do I need to do to turn on the part cooling fan (fan 0)? That seems to not be turning on automatically, even though I can go in and turn it on with the G-code commands.
Holy crap, I did that test and this sucker pumped out 395mm of filament when I ran the "G1 E100 F60" code in the console....
@tmeryhew said in First Layer Way Too High / Extrusion is off?:
Sounds about right based on those photos.
M106 P1 S0 H1 T45 ; set fan 1 value. Thermostatic control is turned onFor the fan problem, are you use 20Hz works for the fans you have?
@Phaedrux I honestly have no idea if 20 hz works for them or not. I was afraid of blowing them up, so I went on the super low end for that.
I went with the default number on the mA for the motors also. I believe each of my four steppers are rated at 1.5A. And I kept it at the default 800mA that was auto populated by the config tool.
As for the fans, both are set to 20 hz and the extruder fan comes on no problem so far. But the part cooling fan hasn't come on at all yet.
Try 500Hz for the fans. That's the default. Valid values go up beyond 30000, so you'll be fine.
For the motors, the ideal current is ~60 to 85% of the rated current for the motor.
