Controll loops for non temperature sensors
Hello Duet team and Co users,
I am currently building a fuildhandiling robot with a duet Wifi and a DUEX5.
There are serveral cases here where it would be nice to controll air flow and air pressure with the duet.
It should be possible to use the M308 with Y parameter Y"linear-analog" to define any kind of sensor that has a 0 to 5v output.
But is it also possible to couple an PWM output controll loop to this?
For example using a simple on/off controll to keep a pressure in a certain range.
Or using PWM on an air pump to maintain a certain flow measured form a gas flow sensor.Is this possible? And how do i set it up?
Thanks in advance for your responses!
Currently the way to do this would be to use "temperature" as a analogue for either "pressure" or "flow rate" (depending on what you were sensing/controlling) then you would set the pump control as a heater. You would then need to work out what linear analog sensor "temperature" related to what pressure/flow and then set that temperature. No doubt you would need to adjust the PID parameters so that the POID loop worked properly.
@DC42 mentioned that an additional complication is that "temperatures <40C are counted as "off" by RRF so you would need to scale your sensor to be working at a higher temperature.
I am going to move this into the firmware wishlist category as something to consider for the future.
Hello Tony, Thanks for your reponse. Any idea how the firmware would react to very high values like displaying pressure in pascal (1bar is 100000 pascal) or Kpascal. If i use absolute pressures the values that i need should be in the range of 50 to 150 kpascal. I assume that this should be fine for the firmware?
