No Connection to DCS After Update to 3.2beta4
check the dmesg output how it identifies the board.
but it might just be that the usb cable is not working. try a different one. -
pi@VCorePro:~ $ dmesg
[ 0.000000] Booting Linux on physical CPU 0x0
[ 0.000000] Linux version 5.4.72-v7+ (dom@buildbot) (gcc version 9.3.0 (Ubuntu 9.3.0-17ubuntu1~20.04)) #1356 SMP Thu Oct 22 13:56:54 BST 2020
[ 0.000000] CPU: ARMv7 Processor [410fd034] revision 4 (ARMv7), cr=10c5383d
[ 0.000000] CPU: div instructions available: patching division code
[ 0.000000] CPU: PIPT / VIPT nonaliasing data cache, VIPT aliasing instruction cache
[ 0.000000] OF: fdt: Machine model: Raspberry Pi 3 Model B Plus Rev 1.3
[ 0.000000] Memory policy: Data cache writealloc
[ 0.000000] Reserved memory: created CMA memory pool at 0x34000000, size 64 MiB
[ 0.000000] OF: reserved mem: initialized node linux,cma, compatible id shared-dma-pool
[ 0.000000] On node 0 totalpages: 229376
[ 0.000000] Normal zone: 2016 pages used for memmap
[ 0.000000] Normal zone: 0 pages reserved
[ 0.000000] Normal zone: 229376 pages, LIFO batch:63
[ 0.000000] percpu: Embedded 20 pages/cpu s49740 r8192 d23988 u81920
[ 0.000000] pcpu-alloc: s49740 r8192 d23988 u81920 alloc=20*4096
[ 0.000000] pcpu-alloc: [0] 0 [0] 1 [0] 2 [0] 3
[ 0.000000] Built 1 zonelists, mobility grouping on. Total pages: 227360
[ 0.000000] Kernel command line: coherent_pool=1M 8250.nr_uarts=0 snd_bcm2835.enable_compat_alsa=0 snd_bcm2835.enable_hdmi=1 snd_bcm2835.enable_headphones=1 bcm2708_fb.fbwidth=1920 bcm2708_fb.fbheight=1080 bcm2708_fb.fbswap=1 vc_mem.mem_base=0x3ec00000 vc_mem.mem_size=0x40000000 console=ttyS0,115200 console=tty1 root=PARTUUID=e3e1fb9e-02 rootfstype=ext4 elevator=deadline fsck.repair=yes rootwait plymouth.ignore-serial-consoles
[ 0.000000] Dentry cache hash table entries: 131072 (order: 7, 524288 bytes, linear)
[ 0.000000] Inode-cache hash table entries: 65536 (order: 6, 262144 bytes, linear)
[ 0.000000] mem auto-init: stack:off, heap alloc:off, heap free:off
[ 0.000000] Memory: 827688K/917504K available (9216K kernel code, 704K rwdata, 2628K rodata, 1024K init, 829K bss, 24280K reserved, 65536K cma-reserved)
[ 0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=4, Nodes=1
[ 0.000000] ftrace: allocating 29179 entries in 57 pages
[ 0.000000] rcu: Hierarchical RCU implementation.
[ 0.000000] rcu: RCU calculated value of scheduler-enlistment delay is 10 jiffies.
[ 0.000000] NR_IRQS: 16, nr_irqs: 16, preallocated irqs: 16
[ 0.000000] random: get_random_bytes called from start_kernel+0x328/0x510 with crng_init=0
[ 0.000000] arch_timer: cp15 timer(s) running at 19.20MHz (phys).
[ 0.000000] clocksource: arch_sys_counter: mask: 0xffffffffffffff max_cycles: 0x46d987e47, max_idle_ns: 440795202767 ns
[ 0.000007] sched_clock: 56 bits at 19MHz, resolution 52ns, wraps every 4398046511078ns
[ 0.000021] Switching to timer-based delay loop, resolution 52ns
[ 0.000285] Console: colour dummy device 80x30
[ 0.000885] printk: console [tty1] enabled
[ 0.000951] Calibrating delay loop (skipped), value calculated using timer frequency.. 38.40 BogoMIPS (lpj=192000)
[ 0.000999] pid_max: default: 32768 minimum: 301
[ 0.001209] LSM: Security Framework initializing
[ 0.001446] Mount-cache hash table entries: 2048 (order: 1, 8192 bytes, linear)
[ 0.001493] Mountpoint-cache hash table entries: 2048 (order: 1, 8192 bytes, linear)
[ 0.002898] Disabling memory control group subsystem
[ 0.003039] CPU: Testing write buffer coherency: ok
[ 0.003627] CPU0: thread -1, cpu 0, socket 0, mpidr 80000000
[ 0.004609] Setting up static identity map for 0x100000 - 0x10003c
[ 0.004830] rcu: Hierarchical SRCU implementation.
[ 0.005547] smp: Bringing up secondary CPUs ...
[ 0.006718] CPU1: thread -1, cpu 1, socket 0, mpidr 80000001
[ 0.008021] CPU2: thread -1, cpu 2, socket 0, mpidr 80000002
[ 0.009209] CPU3: thread -1, cpu 3, socket 0, mpidr 80000003
[ 0.009363] smp: Brought up 1 node, 4 CPUs
[ 0.009452] SMP: Total of 4 processors activated (153.60 BogoMIPS).
[ 0.009481] CPU: All CPU(s) started in HYP mode.
[ 0.009506] CPU: Virtualization extensions available.
[ 0.010601] devtmpfs: initialized
[ 0.027151] VFP support v0.3: implementor 41 architecture 3 part 40 variant 3 rev 4
[ 0.027458] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 19112604462750000 ns
[ 0.027515] futex hash table entries: 1024 (order: 4, 65536 bytes, linear)
[ 0.030832] pinctrl core: initialized pinctrl subsystem
[ 0.031972] NET: Registered protocol family 16
[ 0.036363] DMA: preallocated 1024 KiB pool for atomic coherent allocations
[ 0.041228] audit: initializing netlink subsys (disabled)
[ 0.041541] audit: type=2000 audit(0.040:1): state=initialized audit_enabled=0 res=1
[ 0.043046] hw-breakpoint: found 5 (+1 reserved) breakpoint and 4 watchpoint registers.
[ 0.043086] hw-breakpoint: maximum watchpoint size is 8 bytes.
[ 0.043319] Serial: AMBA PL011 UART driver
[ 0.045344] bcm2835-mbox 3f00b880.mailbox: mailbox enabled
[ 0.070092] raspberrypi-firmware soc:firmware: Attached to firmware from 2020-10-22 14:07, variant start_x
[ 0.080105] raspberrypi-firmware soc:firmware: Firmware hash is 74e754ff8947c58d2773253f77f6f68a303188f8
[ 0.131898] bcm2835-dma 3f007000.dma: DMA legacy API manager, dmachans=0x1
[ 0.134112] SCSI subsystem initialized
[ 0.134390] usbcore: registered new interface driver usbfs
[ 0.134475] usbcore: registered new interface driver hub
[ 0.134620] usbcore: registered new device driver usb
[ 0.136661] clocksource: Switched to clocksource arch_sys_counter
[ 1.298956] VFS: Disk quotas dquot_6.6.0
[ 1.299095] VFS: Dquot-cache hash table entries: 1024 (order 0, 4096 bytes)
[ 1.299312] FS-Cache: Loaded
[ 1.299607] CacheFiles: Loaded
[ 1.311013] thermal_sys: Registered thermal governor 'step_wise'
[ 1.311402] NET: Registered protocol family 2
[ 1.312469] tcp_listen_portaddr_hash hash table entries: 512 (order: 0, 6144 bytes, linear)
[ 1.312545] TCP established hash table entries: 8192 (order: 3, 32768 bytes, linear)
[ 1.312687] TCP bind hash table entries: 8192 (order: 4, 65536 bytes, linear)
[ 1.312898] TCP: Hash tables configured (established 8192 bind 8192)
[ 1.313084] UDP hash table entries: 512 (order: 2, 16384 bytes, linear)
[ 1.313158] UDP-Lite hash table entries: 512 (order: 2, 16384 bytes, linear)
[ 1.313471] NET: Registered protocol family 1
[ 1.314279] RPC: Registered named UNIX socket transport module.
[ 1.314311] RPC: Registered udp transport module.
[ 1.314338] RPC: Registered tcp transport module.
[ 1.314364] RPC: Registered tcp NFSv4.1 backchannel transport module.
[ 1.316194] hw perfevents: enabled with armv7_cortex_a7 PMU driver, 7 counters available
[ 1.319627] Initialise system trusted keyrings
[ 1.319918] workingset: timestamp_bits=14 max_order=18 bucket_order=4
[ 1.331592] FS-Cache: Netfs 'nfs' registered for caching
[ 1.332457] NFS: Registering the id_resolver key type
[ 1.332518] Key type id_resolver registered
[ 1.332545] Key type id_legacy registered
[ 1.332580] nfs4filelayout_init: NFSv4 File Layout Driver Registering...
[ 1.333895] Key type asymmetric registered
[ 1.333926] Asymmetric key parser 'x509' registered
[ 1.334007] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 249)
[ 1.334045] io scheduler mq-deadline registered
[ 1.334073] io scheduler kyber registered
[ 1.337604] bcm2708_fb soc:fb: FB found 1 display(s)
[ 1.413505] Console: switching to colour frame buffer device 240x67
[ 1.447309] bcm2708_fb soc:fb: Registered framebuffer for display 0, size 1920x1080
[ 1.452879] bcm2835-rng 3f104000.rng: hwrng registered
[ 1.453531] vc-mem: phys_addr:0x00000000 mem_base=0x3ec00000 mem_size:0x40000000(1024 MiB)
[ 1.454422] vc-sm: Videocore shared memory driver
[ 1.455027] gpiomem-bcm2835 3f200000.gpiomem: Initialised: Registers at 0x3f200000
[ 1.468319] brd: module loaded
[ 1.481318] loop: module loaded
[ 1.482883] Loading iSCSI transport class v2.0-870.
[ 1.484065] libphy: Fixed MDIO Bus: probed
[ 1.484317] usbcore: registered new interface driver lan78xx
[ 1.484551] usbcore: registered new interface driver smsc95xx
[ 1.484745] dwc_otg: version 3.00a 10-AUG-2012 (platform bus)
[ 2.213162] Core Release: 2.80a
[ 2.213275] Setting default values for core params
[ 2.213447] Finished setting default values for core params
[ 2.413983] Using Buffer DMA mode
[ 2.414098] Periodic Transfer Interrupt Enhancement - disabled
[ 2.414275] Multiprocessor Interrupt Enhancement - disabled
[ 2.414444] OTG VER PARAM: 0, OTG VER FLAG: 0
[ 2.414646] Dedicated Tx FIFOs mode
[ 2.415514] WARN::dwc_otg_hcd_init:1072: FIQ DMA bounce buffers: virt = b4114000 dma = 0xf4114000 len=9024
[ 2.415820] FIQ FSM acceleration enabled for :
Non-periodic Split Transactions
Periodic Split Transactions
High-Speed Isochronous Endpoints
Interrupt/Control Split Transaction hack enabled
[ 2.416431] dwc_otg: Microframe scheduler enabled
[ 2.416510] WARN::hcd_init_fiq:457: FIQ on core 1
[ 2.416658] WARN::hcd_init_fiq:458: FIQ ASM at 80716d40 length 36
[ 2.416841] WARN::hcd_init_fiq:496: MPHI regs_base at b8810000
[ 2.417028] dwc_otg 3f980000.usb: DWC OTG Controller
[ 2.417218] dwc_otg 3f980000.usb: new USB bus registered, assigned bus number 1
[ 2.417475] dwc_otg 3f980000.usb: irq 56, io mem 0x00000000
[ 2.425688] Init: Port Power? op_state=1
[ 2.433730] Init: Power Port (0)
[ 2.442053] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 5.04
[ 2.450133] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 2.458161] usb usb1: Product: DWC OTG Controller
[ 2.466058] usb usb1: Manufacturer: Linux 5.4.72-v7+ dwc_otg_hcd
[ 2.474003] usb usb1: SerialNumber: 3f980000.usb
[ 2.482646] hub 1-0:1.0: USB hub found
[ 2.490498] hub 1-0:1.0: 1 port detected
[ 2.499029] dwc_otg: FIQ enabled
[ 2.499039] dwc_otg: NAK holdoff enabled
[ 2.499048] dwc_otg: FIQ split-transaction FSM enabled
[ 2.499065] Module dwc_common_port init
[ 2.499456] usbcore: registered new interface driver usb-storage
[ 2.507538] mousedev: PS/2 mouse device common for all mice
[ 2.516748] bcm2835-wdt bcm2835-wdt: Broadcom BCM2835 watchdog timer
[ 2.527803] sdhci: Secure Digital Host Controller Interface driver
[ 2.535800] sdhci: Copyright(c) Pierre Ossman
[ 2.544288] mmc-bcm2835 3f300000.mmcnr: could not get clk, deferring probe
[ 2.552976] sdhost-bcm2835 3f202000.mmc: could not get clk, deferring probe
[ 2.561177] sdhci-pltfm: SDHCI platform and OF driver helper
[ 2.571008] ledtrig-cpu: registered to indicate activity on CPUs
[ 2.579402] hidraw: raw HID events driver (C) Jiri Kosina
[ 2.587607] usbcore: registered new interface driver usbhid
[ 2.595657] usbhid: USB HID core driver
[ 2.604771] vchiq: vchiq_init_state: slot_zero = (ptrval)
[ 2.614894] [vc_sm_connected_init]: start
[ 2.626860] [vc_sm_connected_init]: end - returning 0
[ 2.636884] Initializing XFRM netlink socket
[ 2.644722] NET: Registered protocol family 17
[ 2.652716] Key type dns_resolver registered
[ 2.661317] Registering SWP/SWPB emulation handler
[ 2.669558] registered taskstats version 1
[ 2.677367] Loading compiled-in X.509 certificates
[ 2.685651] Key type ._fscrypt registered
[ 2.693329] Key type .fscrypt registered
[ 2.712006] uart-pl011 3f201000.serial: cts_event_workaround enabled
[ 2.719811] 3f201000.serial: ttyAMA0 at MMIO 0x3f201000 (irq = 81, base_baud = 0) is a PL011 rev2
[ 2.728050] Indeed it is in host mode hprt0 = 00021501
[ 2.797412] bcm2835-power bcm2835-power: Broadcom BCM2835 power domains driver
[ 2.806814] mmc-bcm2835 3f300000.mmcnr: mmc_debug:0 mmc_debug2:0
[ 2.814597] mmc-bcm2835 3f300000.mmcnr: DMA channel allocated
[ 2.821453] random: fast init done
[ 2.849020] sdhost: log_buf @ (ptrval) (f4113000)
[ 2.894129] mmc1: queuing unknown CIS tuple 0x80 (2 bytes)
[ 2.903644] mmc1: queuing unknown CIS tuple 0x80 (3 bytes)
[ 2.911407] mmc0: sdhost-bcm2835 loaded - DMA enabled (>1)
[ 2.921875] of_cfs_init
[ 2.929917] of_cfs_init: OK
[ 2.938680] Waiting for root device PARTUUID=e3e1fb9e-02...
[ 2.940452] mmc1: queuing unknown CIS tuple 0x80 (3 bytes)
[ 2.959555] mmc1: queuing unknown CIS tuple 0x80 (7 bytes)
[ 2.967192] usb 1-1: new high-speed USB device number 2 using dwc_otg
[ 2.979355] Indeed it is in host mode hprt0 = 00001101
[ 3.099968] mmc0: host does not support reading read-only switch, assuming write-enable
[ 3.113716] mmc0: new high speed SDHC card at address aaaa
[ 3.122622] mmcblk0: mmc0:aaaa SC16G 14.8 GiB
[ 3.138886] mmcblk0: p1 p2
[ 3.149149] mmc1: new high speed SDIO card at address 0001
[ 3.188390] EXT4-fs (mmcblk0p2): INFO: recovery required on readonly filesystem
[ 3.196235] EXT4-fs (mmcblk0p2): write access will be enabled during recovery
[ 3.227091] usb 1-1: New USB device found, idVendor=0424, idProduct=2514, bcdDevice= b.b3
[ 3.235175] usb 1-1: New USB device strings: Mfr=0, Product=0, SerialNumber=0
[ 3.244043] hub 1-1:1.0: USB hub found
[ 3.252171] hub 1-1:1.0: 4 ports detected
[ 3.576710] usb 1-1.1: new high-speed USB device number 3 using dwc_otg
[ 3.707374] usb 1-1.1: New USB device found, idVendor=0424, idProduct=2514, bcdDevice= b.b3
[ 3.715455] usb 1-1.1: New USB device strings: Mfr=0, Product=0, SerialNumber=0
[ 3.725844] hub 1-1.1:1.0: USB hub found
[ 3.734122] hub 1-1.1:1.0: 3 ports detected
[ 3.836756] usb 1-1.2: new high-speed USB device number 4 using dwc_otg
[ 4.099654] EXT4-fs (mmcblk0p2): orphan cleanup on readonly fs
[ 4.108359] EXT4-fs (mmcblk0p2): 3 orphan inodes deleted
[ 4.116202] EXT4-fs (mmcblk0p2): recovery complete
[ 4.146925] EXT4-fs (mmcblk0p2): mounted filesystem with ordered data mode. Opts: (null)
[ 4.155017] VFS: Mounted root (ext4 filesystem) readonly on device 179:2.
[ 4.167076] devtmpfs: mounted
[ 4.182104] Freeing unused kernel memory: 1024K
[ 4.190411] Run /sbin/init as init process
[ 4.376741] usb 1-1.2: device not accepting address 4, error -71
[ 4.476752] usb 1-1.1.2: new low-speed USB device number 5 using dwc_otg
[ 4.611133] usb 1-1.1.2: New USB device found, idVendor=17ef, idProduct=6019, bcdDevice= 1.00
[ 4.619252] usb 1-1.1.2: New USB device strings: Mfr=0, Product=2, SerialNumber=0
[ 4.627155] usb 1-1.1.2: Product: Lenovo Optical USB Mouse
[ 4.646553] input: Lenovo Optical USB Mouse as /devices/platform/soc/3f980000.usb/usb1/1-1/1-1.1/1-1.1.2/1-1.1.2:1.0/0003:17EF:6019.0001/input/input0
[ 4.655718] hid-generic 0003:17EF:6019.0001: input,hidraw0: USB HID v1.11 Mouse [Lenovo Optical USB Mouse] on usb-3f980000.usb-1.1.2/input0
[ 4.706730] usb 1-1.2: new high-speed USB device number 6 using dwc_otg
[ 4.831182] systemd[1]: System time before build time, advancing clock.
[ 4.982563] NET: Registered protocol family 10
[ 4.992662] Segment Routing with IPv6
[ 5.040050] systemd[1]: systemd 241 running in system mode. (+PAM +AUDIT +SELINUX +IMA +APPARMOR +SMACK +SYSVINIT +UTMP +LIBCRYPTSETUP +GCRYPT +GNUTLS +ACL +XZ +LZ4 +SECCOMP +BLKID +ELFUTILS +KMOD -IDN2 +IDN -PCRE2 default-hierarchy=hybrid)
[ 5.073497] systemd[1]: Detected architecture arm.
[ 5.186972] systemd[1]: Set hostname to <VCorePro>.
[ 6.172245] random: systemd: uninitialized urandom read (16 bytes read)
[ 6.199427] random: systemd: uninitialized urandom read (16 bytes read)
[ 6.209447] systemd[1]: Listening on initctl Compatibility Named Pipe.
[ 6.231478] random: systemd: uninitialized urandom read (16 bytes read)
[ 6.241753] systemd[1]: Set up automount Arbitrary Executable File Formats File System Automount Point.
[ 6.263083] systemd[1]: Reached target Swap.
[ 6.285392] systemd[1]: Listening on Journal Socket.
[ 6.307904] systemd[1]: Condition check resulted in Huge Pages File System being skipped.
[ 6.318731] systemd[1]: Listening on Syslog Socket.
[ 6.341599] systemd[1]: Listening on udev Control Socket.
[ 6.535966] i2c /dev entries driver
[ 7.426144] EXT4-fs (mmcblk0p2): re-mounted. Opts: (null)
[ 7.577462] systemd-journald[112]: Received request to flush runtime journal from PID 1
[ 8.314626] vc_sm_cma: module is from the staging directory, the quality is unknown, you have been warned.
[ 8.319998] bcm2835_vc_sm_cma_probe: Videocore shared memory driver
[ 8.320071] [vc_sm_connected_init]: start
[ 8.327723] [vc_sm_connected_init]: installed successfully
[ 8.332761] mc: Linux media interface: v0.10
[ 8.425609] videodev: Linux video capture interface: v2.00
[ 8.466083] bcm2835_mmal_vchiq: module is from the staging directory, the quality is unknown, you have been warned.
[ 8.467342] bcm2835_mmal_vchiq: module is from the staging directory, the quality is unknown, you have been warned.
[ 8.469227] snd_bcm2835: module is from the staging directory, the quality is unknown, you have been warned.
[ 8.481384] bcm2835_v4l2: module is from the staging directory, the quality is unknown, you have been warned.
[ 8.483268] bcm2835_isp: module is from the staging directory, the quality is unknown, you have been warned.
[ 8.489272] bcm2835_codec: module is from the staging directory, the quality is unknown, you have been warned.
[ 8.500514] bcm2835_audio bcm2835_audio: card created with 4 channels
[ 8.513179] bcm2835-isp bcm2835-isp: Device node output[0] registered as /dev/video13
[ 8.514526] bcm2835-isp bcm2835-isp: Device node capture[0] registered as /dev/video14
[ 8.515435] bcm2835-isp bcm2835-isp: Device node capture[1] registered as /dev/video15
[ 8.515981] bcm2835-isp bcm2835-isp: Device node stats[2] registered as /dev/video16
[ 8.516012] bcm2835-isp bcm2835-isp: Register output node 0 with media controller
[ 8.516034] bcm2835-isp bcm2835-isp: Register capture node 1 with media controller
[ 8.516053] bcm2835-isp bcm2835-isp: Register capture node 2 with media controller
[ 8.516071] bcm2835-isp bcm2835-isp: Register capture node 3 with media controller
[ 8.516411] bcm2835-isp bcm2835-isp: Loaded V4L2 bcm2835-isp
[ 8.522960] bcm2835_audio bcm2835_audio: card created with 4 channels
[ 8.526911] bcm2835-codec bcm2835-codec: Device registered as /dev/video10
[ 8.526971] bcm2835-codec bcm2835-codec: Loaded V4L2 decode
[ 8.811375] cfg80211: Loading compiled-in X.509 certificates for regulatory database
[ 8.959695] cfg80211: Loaded X.509 cert 'sforshee: 00b28ddf47aef9cea7'
[ 9.059962] brcmfmac: F1 signature read @0x18000000=0x15264345
[ 9.074493] brcmfmac: brcmf_fw_alloc_request: using brcm/brcmfmac43455-sdio for chip BCM4345/6
[ 9.075716] usbcore: registered new interface driver brcmfmac
[ 9.112549] brcmfmac mmc1:0001:1: Direct firmware load for brcm/brcmfmac43455-sdio.raspberrypi,3-model-b-plus.txt failed with error -2
[ 9.165886] bcm2835-codec bcm2835-codec: Device registered as /dev/video11
[ 9.165946] bcm2835-codec bcm2835-codec: Loaded V4L2 encode
[ 9.185081] bcm2835-codec bcm2835-codec: Device registered as /dev/video12
[ 9.185139] bcm2835-codec bcm2835-codec: Loaded V4L2 isp
[ 9.198687] bcm2835-v4l2: scene mode selected 0, was 0
[ 9.199547] bcm2835-v4l2: V4L2 device registered as video0 - stills mode > 1280x720
[ 9.205789] bcm2835-v4l2: Broadcom 2835 MMAL video capture ver 0.0.2 loaded.
[ 9.206442] random: crng init done
[ 9.206457] random: 7 urandom warning(s) missed due to ratelimiting
[ 9.396794] brcmfmac: brcmf_fw_alloc_request: using brcm/brcmfmac43455-sdio for chip BCM4345/6
[ 9.447122] brcmfmac: brcmf_c_preinit_dcmds: Firmware: BCM4345/6 wl0: Mar 23 2020 02:19:54 version 7.45.206 (r725000 CY) FWID 01-88ee44ea
[ 9.856751] usb 1-1.2: device descriptor read/64, error -110
[ 11.327971] 8021q: 802.1Q VLAN Support v1.8
[ 11.664692] uart-pl011 3f201000.serial: no DMA platform data
[ 11.920530] brcmfmac: brcmf_cfg80211_set_power_mgmt: power save enabled
[ 12.007895] Adding 102396k swap on /var/swap. Priority:-2 extents:1 across:102396k SSFS
[ 17.730065] IPv6: ADDRCONF(NETDEV_CHANGE): wlan0: link becomes ready
[ 18.543579] Bluetooth: Core ver 2.22
[ 18.543819] NET: Registered protocol family 31
[ 18.543827] Bluetooth: HCI device and connection manager initialized
[ 18.543921] Bluetooth: HCI socket layer initialized
[ 18.543936] Bluetooth: L2CAP socket layer initialized
[ 18.543969] Bluetooth: SCO socket layer initialized
[ 18.563964] Bluetooth: HCI UART driver ver 2.3
[ 18.563979] Bluetooth: HCI UART protocol H4 registered
[ 18.564033] Bluetooth: HCI UART protocol Three-wire (H5) registered
[ 18.564212] Bluetooth: HCI UART protocol Broadcom registered
[ 19.132246] Bluetooth: BNEP (Ethernet Emulation) ver 1.3
[ 19.132266] Bluetooth: BNEP filters: protocol multicast
[ 19.132305] Bluetooth: BNEP socket layer initialized
[ 19.203665] Bluetooth: RFCOMM TTY layer initialized
[ 19.203712] Bluetooth: RFCOMM socket layer initialized
[ 19.203746] Bluetooth: RFCOMM ver 1.11
[ 19.444977] ICMPv6: process `dhcpcd' is using deprecated sysctl (syscall) net.ipv6.neigh.wlan0.retrans_time - use net.ipv6.neigh.wlan0.retrans_time_ms instead
[ 19.606888] fuse: init (API version 7.31)
[ 25.217241] usb 1-1.2: device descriptor read/64, error -110
[ 25.337424] usb 1-1-port2: attempt power cycle
[ 25.936739] usb 1-1.1.3: new low-speed USB device number 7 using dwc_otg
[ 26.103444] usb 1-1.1.3: New USB device found, idVendor=03f0, idProduct=2b4a, bcdDevice= 2.48
[ 26.103479] usb 1-1.1.3: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[ 26.103488] usb 1-1.1.3: Product: HP USB Slim Keyboard - Skylab EU
[ 26.103501] usb 1-1.1.3: Manufacturer: Lite-On Technology Corp
[ 26.121085] input: Lite-On Technology Corp HP USB Slim Keyboard - Skylab EU as /devices/platform/soc/3f980000.usb/usb1/1-1/1-1.1/1-1.1.3/1-1.1.3:1.0/0003:03F0:2B4A.0002/input/input1
[ 26.187607] hid-generic 0003:03F0:2B4A.0002: input,hidraw1: USB HID v1.10 Keyboard [Lite-On Technology Corp HP USB Slim Keyboard - Skylab EU] on usb-3f980000.usb-1.1.3/input0
[ 26.208820] input: Lite-On Technology Corp HP USB Slim Keyboard - Skylab EU Consumer Control as /devices/platform/soc/3f980000.usb/usb1/1-1/1-1.1/1-1.1.3/1-1.1.3:1.1/0003:03F0:2B4A.0003/input/input2
[ 26.277370] input: Lite-On Technology Corp HP USB Slim Keyboard - Skylab EU System Control as /devices/platform/soc/3f980000.usb/usb1/1-1/1-1.1/1-1.1.3/1-1.1.3:1.1/0003:03F0:2B4A.0003/input/input3
[ 26.279702] input: Lite-On Technology Corp HP USB Slim Keyboard - Skylab EU as /devices/platform/soc/3f980000.usb/usb1/1-1/1-1.1/1-1.1.3/1-1.1.3:1.1/0003:03F0:2B4A.0003/input/input4
[ 26.284425] hid-generic 0003:03F0:2B4A.0003: input,hiddev96,hidraw2: USB HID v1.10 Device [Lite-On Technology Corp HP USB Slim Keyboard - Skylab EU] on usb-3f980000.usb-1.1.3/input1
[ 26.576745] usb 1-1.1.2: reset low-speed USB device number 5 using dwc_otg
[ 27.216964] usb 1-1.2: new high-speed USB device number 8 using dwc_otg
[ 27.656971] usb 1-1.2: device not accepting address 8, error -71
[ 27.756804] usb 1-1.2: new high-speed USB device number 10 using dwc_otg
[ 32.797137] WARN::dwc_otg_hcd_urb_dequeue:638: Timed out waiting for FSM NP transfer to complete on 3
[ 38.077139] WARN::dwc_otg_hcd_urb_dequeue:638: Timed out waiting for FSM NP transfer to complete on 6
[ 38.296761] usb 1-1.2: device not accepting address 10, error -110
[ 38.296928] usb 1-1-port2: unable to enumerate USB device
[ 38.396765] usb 1-1.1.1: new high-speed USB device number 9 using dwc_otg
[ 38.527342] usb 1-1.1.1: New USB device found, idVendor=0424, idProduct=7800, bcdDevice= 3.00
[ 38.527360] usb 1-1.1.1: New USB device strings: Mfr=0, Product=0, SerialNumber=0
[ 38.791992] lan78xx 1-1.1.1:1.0 (unnamed net_device) (uninitialized): No External EEPROM. Setting MAC Speed
[ 38.792835] libphy: lan78xx-mdiobus: probed
[ 38.808968] lan78xx 1-1.1.1:1.0 (unnamed net_device) (uninitialized): int urb period 64
[ 39.243110] 8021q: adding VLAN 0 to HW filter on device eth0
pi@ -
try reseting the board again.
@Veti how long do i have to press the reset button when i power it up ? in the meanwhile , i flashed a complete new image on a other (fresh) sd card with 8Gb. The same Problem. After the first start when the welcome window appears , the DWC Window is opening and imideatly i get the error message Failed to connect to duet3
normally not at all since you place a jumper across the ERASE pins on the Duet 3.
see
https://duet3d.dozuki.com/Wiki/Getting_Started_With_Duet_3#Section_Updating_Duet_3_main_board_firmware -
@Veti i did that too several times. when im verifying the image, bossa stops at ~line 1051. if i try to flash with the 3 options aktivatet, bossa crashes 1 second after the write window appears
can you try a different usb cable?
@Veti yes
@Veti the diag led is shining when i connect the board without sbc and vin over usb. ThE Light is not blinking. its static
yes if the firmware is erased, the diag led should be on constant
some people have had to use up to 18 different cable until they found one that worked.
@Veti you are joking, right ?!? 18 Cables....holy...i cant find what the meaning of the static diage led is ?
see
https://duet3d.dozuki.com/Wiki/What_to_do_if_your_Duet_won't_respondIf the firmware has been erased the DIAG LED will be on permanently.
@Veti Thank You SOooooooOO much for your tip with the usb cable....i tried a 10 year old usb2 dvd cable (with dual A Plugs on one side). After connecting the second the firmware flashed perfektly on the first try ;).
I would be so lost without you guys and this forum
Have a nice Day !
@Frederikfor information purposes:
The cable that did NOT work: brand new Ugreen with 3Meters in lenght.
The cable THAT worked: 10 Year old usb2.0 with dual USB-A Plug on one side.
Like the on the external dvd or harddrives. Lenght ~ 40cm -
So, the cable worked. The firmware flash over bossa worked. Also verifying. I did 2 times exact what's mentioned in the getti g startet wiki. I loaded the additional files, flashed a new copy of duet pi desktop on the 16gb card. After that I copied my .g files in the /sys folder on the boot partition together with the 3.1.1 firmware .bin.
After that, I Did all the steps like network, keyboard layout etc. Without any errors.
Even the update at the end + restart showed no errors. Only in the dcs log is constantly starting and stoping with the meassage:
No connection to duet3
Should I do a standalone firmware reset and after that reconnecting the pi?
It seems that the reset button did not reset the board, even if I hold it like 10 seconds
I do all the actual test without Vin.
Only connection over usb and wlan -
@Frederik said in No Connection to DCS After Update to 3.2beta4:
Yes I would set it up in standalone to confirm that the Duet is working correctly otherwise and see what firmware version is flashed.
@Phaedrux Thanks. I will test that later.
