Fan Headers Not working
@Phaedrux , I was able to safely remove the fuse. It is in good working order, the metal on the inside looks like new and there is continuity when tested with a multimeter.
How did the config look to you?
post a picture of the wiring of the fans being connected to the duet
Here you go, I did double and triple check the polarity...I have only tried connecting the heatsink fan at this point. That fan is part of my hemera extruder/hotend and is supposed to be 24V. I have also tried connecting two other 24V fans I have that I know work in another printer and they are also not working on any of the Fan ports, including the Always On ports.
Does the fan work if connected directly to VIN and ground on the PSU?
Can you measure the voltage across the VIN pin of the VFAN jumper block and ground? Careful not to slip.
@Phaedrux , I have not tried wiring the fans directly to VIN and GND. But I know several fans that work in another printer do not work on this Duet board.
@Phaedrux said in Fan Headers Not working:
To confirm, when I do that should the jumper be in place or not in place?
Alright, just want to make sure the fan isn't the problem.
Doesn't matter if the jumper is on or not really as long as you can poke the metal. Probably easier with it off. Just want to see if there is any voltage coming to the pin.
Ok, was able to test for voltage and I am not seeing anything on the multimeter.
Weird. And you're sure the fan fuse is intact? Did you pull the one with the
1
on it? -
@Phaedrux I just double checked and you were right, I checked the Bed fuse the first time. The fuse with labeled 1 on it does not have continuity. So I assume if I replace that fuse that may solve my issues? Thoughts?
I am heading out for a drive with my wife, I will stop by an automotive supply store and see if they sell 1A mini auto blade fuses. I read on the forum somewhere that you can go up to 2 or 3 amp fuses as well for the fans. Can you confirm that in case I cannot find 1Amp fuses lcoally?
Ok, that makes more sense. Yes replacing that fuse should get you sorted. Automotive parts store is the best bet. Motorcycle shop. That kind of thing. Using a larger fuse would work, just means that it would take longer to blow if there was a short.
@Phaedrux Thanks for all of your help. I was really hoping it was not a major break in the board and I will report back to this thread once i find a new fuse for the fans.
@Phaedrux I swapped in a 2A fuse and my heat sink fan is now working. Thank you very much for all of the help. I will source the 1A fuse but at least I am running now.
Good to hear.
