BOx Large Format DIY Printer
A4403GEUTR-T / A4403GEU-T is the right part and if the board works from USB odds are good replacing U3 will help yeah.
@bearer said in BOx Large Format DIY Printer:
Awesome, thanks a lot !!
Btw is it a cloned board? (lacking serial sticker on cpu)
Just wondering as a batch of genuine boards were fitted with A4403 chips that seemed to be faulty a while back; wondering the the cloned board could share the same issue or if you had a "incident" leading up to the failure?
@bearer it's very possible that this is a clone, I was hoping it to be a real one, but I live in China and getting real stuff here is always a challenge. Is there any way I can know it for sure?
It was mostly my fault, I wired the filament sensor in a wrong way, probably shorting the positive and negative. I've let it like that for 5 minutes before realizing the issue but it was already too late, the chips released the magic smoke already.
On the back of the board there may be a silk screen of text that says it's based on the Duet, yadda yadda yadda. Having blue heatsinks and no sticker is usually a good indicator. Plus I don't think there are any authorized resellers in China, so safe to say it's a clone. Don't worry, we don't hold it against you.
As you've already discovered you'll get help with pretty much anything but warranty repairs even if its not genuine so don't sweat it; I was just curious as it seemed unlikely for it to be the same issue as with that suspect batch of chips.
@Phaedrux Well it seems to be a cloned one then, I probably could have guessed it earlier if I had paid attention to the silkscreen you mentionned:
I don't think that the original ones are both assembled in the UK and assembled in China!
Sometimes we can find real/non cloned hardware even though there is no authorized resellers here, some people import them and then resell without the creator's consent or knowledge. That's how I got my BL touch for instance, some guy imported it from Korea into China. But it's always a bit of a gamble, even the price isn't always a good indicator...
Anyway, thanks a ton for the help, and sorry for not having bought the real one. Maybe you should consider having a reseller here, most people here are ok to pay a premium for quality hardware nowadays in China
@MrDui said in BOx Large Format DIY Printer:
No problem, thanks for sharing your giant cool printer with us.
your build is really something. I'm particularly impressed by the tidiness and wires routing
Good news : we can now add a label "repaired in China" to the "Assembled in China" and "assembled in the UK" on the clone board!
I am lucky to have some very skilled colleagues, this one in particular who repaired the board in less than 5 minutes without breaking a sweat. Amazing guy, really impressive to see!
The board now seem to work just fine, the 5V and 3.3V leds indicate that the voltages are back!
I'll test it later with a SD card, but I'm fairly confident there won't be any problem, it does behave exactly the same as if it were powered up from the USB port. Great success! -
Hello everyone, it's been a while!
The printer is still going strong, I printed kilos and kilos of filament already and it works really well 99.99% of the time.But there is this little 0.01% I'd like to fix. I sometimes, on very rare occasions during fast infills and high accelerations, get some layer shifts.
This is due to my print head being super heavy of course, but instead of going for the reasonable option which would be to lower accelerations and speeds, I'd like to push it even further and go for closed loop to recover from thes kind of situations and go even faster.So I got myself this weird little board:
https://www.aliexpress.com/i/4001273329739.htmlIt features regular step sticks slots, so my plan would like to use these together with some bigtreetech closed loop drivers (these kind of things: https://it.aliexpress.com/item/4000580109464.html )
I'd install those at least on X and Y, and maybe Z later.
Hopefully it shouldn't be too much of an issue for the most part, but I'm wondering about the BL touch I've installed: it is wired on that big extension connector plug on the duet board: problem is, if I plug this extension board then where am I supposed to plug the BL touch?
Did anyone had to face this problem? -
On the official expansion board the heater6 and heater7 ports are exposed which can be used for servo control of the bltouch. It looks like the clone lacks that. You might be able to extend the pins anyway though.
https://duet3d.dozuki.com/Wiki/Duet_Expansion_Breakout_Board
Lol, it seems like once again I got fooled by a clone.
So I did a continuity test and found out that the pwm pin number 7 isn't connected to anything. So it'll be easy, I'll just have to solder a wire from it.Also, while I'm at it, here are some prints I did with the printer during the past months:
Some large molds to pour silicone:
Fairings for my electric motorbike:
And also for fun a giant moai head:
Each of those prints took less than 20 hours. As you can see, the printer works very well, I havent' got any issue with it since I repaired the fried motherboard.
My next print should be much bigger and take around 36 hours, it'll be a really huge mold to make the bike's fairings out of carbon fiber. The mold should make around 3kg of PLA. Got myself a few 5Kg spools fot that job.
But before doing that, I'd like to test and possibly install the closed loop system, in order to make the printer as realiable as possible.
