Help me get connected to my Duet2Wifi
@Phaedrux Ok thanks for you help and patience. The printer was designed to use senseless homing so I will have to read the documentation on it and update the homex and home y files to get that working correct. I also had a question about how the mesh leveling works. Will the parts of the bed where the probe cant reach be estimated based on the mesh or does it revert to no compensation in these areas?
@Kwad3d said in Help me get connected to my Duet2Wifi:
You can choose sensorless as an endstop option in the configurator, but you will likely need to do some tuning.
https://duet3d.dozuki.com/Wiki/Stall_detection_and_sensorless_homing
Yes it will extrapolate to the areas it can't reach, but it's not perfect. If there is a unexpected peak or valley it won't know about it.
https://duet3d.dozuki.com/Wiki/Using_mesh_bed_compensation
You're welcome.
@Phaedrux Ok I will more than likely need some assistance fine tuning the mesh leveling to match my probe locating and the areas where the print head can move off the bed. I did find this post in the forums where you made some good references that I think will get me there though.
https://forum.duet3d.com/topic/18185/possible-pwm-port-issue-rrf3-question/18
@Phaedrux Ok I came across a bug or something. When testing my heated bed I got error message after 15-30 seconds saying it is heating up too slow. However I can see the temp rising in a acceptable manor. How can I correct this issue?
It's not a bug. It's the thermal runaway protection kicking in because it doesn't have an accurate model of your heater yet so it thinks something is wrong.
The solution is to PID tune your heaters.
https://duet3d.dozuki.com/Guide/Ender+3+Pro+and+Duet+Maestro+Guide+Part+4:+Calibration/40#s161
@Phaedrux LOL.. total DUH moment. Guess I assumed that "Bang Bang" didn't require it
This post is deleted! -
@Phaedrux Ok I have made some progress but having inconsistent results with senseless homing and not sure how to adjust the settings. This is on a CoreXY for reference so both motors have to move in tandem to home x and y. It will home some times and then sometimes it will move a little in the opposite diagonal direction ( one motor not turning with the other). Here is my HomeX code. My guess is its slightly too sensitive. Im gussing I need to increase the motor current a few percent but want to check
M400
M913 X70 Y70 ; drop motor current to 70%
M400 G91; relative positioning
G1 H2 Z10 F12000 ; lift Z relative to current position
G1 H1 X-320.5 F10000 ; move quickly to X axis endstop and stop there (first pass)
G1 H2 X20 F12000 ; go back a few mm
G1 H1 X-320.5 F7000 ; move slowly to X axis endstop once more (second pass)
G1 H2 Z-10 F9000 ; lower Z again
G90 ; absolute positioning
M400
M913 X100 Y100 ; return current to 100%
M400 -
What does your M915 command look like?
https://duet3d.dozuki.com/Wiki/Stall_detection_and_sensorless_homing#Section_Sensorless_Homing
Have you calculated what your M915 H value should be and your minimum homing speed?
In your example, remove the entire second homing move. With stall detection you need a short sharp shock during a steady state move. Backing off and slowly approaching from close up isn't going to generate a stall reliably. Since you're stalling the motor to a full step anyway, backing off and rehoming for more accuracy doesn't make sense here like it does when using an endstop switch.
So try this
M400 M913 X70 Y70 ; drop motor current to 70% M400 G91; relative positioning G1 H2 Z10 F12000 ; lift Z relative to current position G1 H1 X-320.5 F10000 ; move quickly to X axis endstop and stop there (first pass) G1 H2 Z-10 F9000 ; lower Z again G90 ; absolute positioning M400 M913 X100 Y100 ; return current to 100% M400
Start with as low a motor current as you can still reliably move with and set the sensitivity to default. Then slowly increase (or decrease) sensitivity from there.
@Phaedrux So lower the full current setting that was set in the confit tool or the "drop motor" current in the M913 line? If im changing the full current that was set in the config (800) I can do that with a g code command in the console right? what is the code please if so
I mean lower the dropped current in the M913 command in your homing file.
M906 sets the full current in config.g. That one should be set at ~80% of your motors max current.
@Phaedrux Ok currently my M913 line is set to %70 for x and Y. lower to %60-65 and retest?
You can send M913 in the console to lower the current in steps. Send your homing move command each time. When the move doesn't work anymore, you've found the lower limit.
Example
M913 X30
G1 H1 X-300 F10000
M913 X40
G1 H1 X-300 F10000etc
If it still moves reliably sat 30% then maybe stick with that because I don't think you'd get much lower.
@Phaedrux Today im getting zero movement on homing x. The bed drops then X is just set to 0 while the nozzle is in the center of the bed. I can manually move left and right after the failed homing move. Here is my code for home X at the moment. anything wrong with it? I repeated testing with M913 increments up to 100% I would occasionally get it to home but fails %90 of the time. How do I get it to grind the x axis into the home location? where I want to be is obviously somewhere between there and where Im at now.
M400
M913 X80 Y80 ; drop motor current to 80%
M400
M400
M400 -
I still haven't seen your m915 command. Can you post your config.g file?
M550 P"SK GO" ; set printer name
M669 K1 ; select CoreXY mode; Network
M551 P"SK GO" ; set password
M552 S1 ; enable network
M586 P0 S1 ; enable HTTP
M586 P1 S0 ; disable FTP
M569 P2 S0 ; physical drive 2 goes backwards
M92 X200.00 Y200.00 Z400.00 E420.00 ; set steps per mm
M566 X600.00 Y600.00 Z12.00 E120.00 ; set maximum instantaneous speed changes (mm/min)
M201 X3000.00 Y3000.00 Z100.00 E10000.00 ; set accelerations (mm/s^2)
M208 X10 Y36 Z0 S1 ; set axis minima
M208 X310 Y336 Z320 S0 ; set axis maxima; Endstops
M574 X1 S3 ; configure sensorless endstop for low end on X
M574 Y1 S3 ; configure sensorless endstop for low end on Y; Z-Probe
M950 S0 C"exp.heater3" ; create servo pin 0 for BLTouch
M558 P9 C"^zprobe.in" H5 F120 T6000 ; set Z probe type to bltouch and the dive height + speeds
G31 P500 X-26 Y0 Z2.5 ; set Z probe trigger value, offset and trigger height
M557 X36:290 Y46:290 S48 ; define mesh grid; Heaters
M143 H0 S90 ; set temperature limit for heater 0 to 90C
M911 S10 R11 P"M913 X0 Y0 G91 M83 G1 Z3 E-5 F1000" ; set voltage thresholds and actions to run on power loss -
May want to increase your max speed and decrease your acceleration.
M203 X6000.00 Y6000.00 Z180.00 E1200.00 ; set maximum speeds (mm/min) M201 X3000.00 Y3000.00 Z100.00 E10000.00 ; set accelerations (mm/s^2)
Try
M203 X12000.00 Y12000.00 Z180.00 E1200.00 ; set maximum speeds (mm/min) M201 X1500.00 Y1500.00 Z100.00 E10000.00 ; set accelerations (mm/s^2)
It sounds like it's detecting a stall immediately, possibly due to the high acceleration.
Doing this calculation for minimum stall speed would help as well so we know how fast it needs to be going to stall, but not so fast that it stalls prematurely.
Hmin = full_steps_per_rev * rated_current * actual_current/(sqrt(2) * pi * rated_holding_torque)
@Phaedrux Im confused by the equation.
What is sqrt? and this is in algebraic format correct. So I would calculate full steps x rated current x actual current (A) and calculate sqrt x2 then x pi x rated holding (B). then divide a with b right?
I have never had any luck with stall guard in general. Is there a way to turn it off but have senseless homing like on a prusa? Since this is on a coreXY that I will want to print at speeds above 100mm/s It could become a problem could it not?
Yes, that's exactly what you're doing now. You don't have to use both. You can use either or.
It would help me to know what your motor model is. Do you know the rated current? If it's detecting a stall already at M913 80% perhaps your M906 current in config.g is set too low.
If you tell me the rated current and whether they are 0.9 or 1.8 degree motors I can calculate the value using my spread sheet.
No, no problem at all. Your max speed was limited to 100mm/s in your config.g and I suggested increasing it to 200mm/s, but you could raise that even more if you want.
@Phaedrux there LDO brand motors on X and Y at 0.9 deg. Model 42STh47 1684MAC Standard size motor. no other information about the motors was provided by the retailer of the machine and I could not find the required info on the LDO site.
