How to use a LED Strip with Duet 2 WiFI?
@Phaedrux said in How to use a LED Strip with Duet 2 WiFI?:
I think you're overthinking it. The fan ports use PWM by switching the negative side and don't require the 4 pin that a true 4 wire PWM fan does (though that is an option, it's not what you need for a simple LED strip).
Just connect your LED string to Fan2 and control it like a regular part cooling fan.
M950 F2 C"Fan2" Q500
M106 P2 S255thanks soooooo much
I have a 24v psu so I use a 24v led strip. I first used a fan output, however the voltage drop caused an issue with my other fans. I switch to using heater output 2 and it works flawlessly.
In config. g
;LED Strip
M950 P2 C"e1heat"
M307 P2 A-1 C-1 D-1Then add the following to change power output
M42 P2 Sxxx -
@ericlmccormick said in How to use a LED Strip with Duet 2 WiFI?:
M307 P2 A-1 C-1 D-1
No longer used in RRF3.
I have a question here too.
I use that code to configure my LED strip:
M950 F3 C"0.out6" Q500 M106 P3 S0
(And I have two macros to turn in on and off via the web or display than.)
So the "controller" is called "Fan 3" on the Display. Is there a way to rename the object? Like I can rename a tool? (563 S"BlaBla")
Cheers, Chriss
@Chriss Yes, M106 C"LEDs" would give it the name LEDs.
Thanks! Workes as expected.
I expected that in the "M950" because that is the configuration of the object to me and "M106" the "on/off" only. So I did not looked into the docu of M106.
Anyway: Thank you very much for the fast answer.Cheers, Chriss
In config. g
;LED Strip
M950 P2 C"e1heat"
M42 P2 SxxxDone! When I boot the board the pin is setted "high" and the LED stripe is immediately turned on with the maximum pulse width. How can I set to let the pin low when the board starts?
Make sure the M42 code is in the slicer startup code and NOT in config.g
I put M32 in my slicer start code which calls beg.g and M0 in my slicer end code which runs stop.g
Then I have M42 P2 S255 in my bed.g and M42 P2 S0 in stop.g and cancel.g
already done but the stripe turns on when I boot the board even without m42
@the_dragonlord can you share your config.g file?
here it is:
; generated by RepRapFirmware Configuration Tool v3.1.4 on Mon Oct 26 2020 18:43:35 GMT+0100 (Ora standard dellโEuropa centrale); General preferences
M550 P"DragonCore" ; set printer name
M669 K1 ; select CoreXY mode; Network
M552 S1 ; enable network
M586 P0 S1 ; enable HTTP
M586 P1 S1 ; enable FTP
M586 P2 S1 ; enable Telnet; Drives
M569 P0 S0 ; physical drive 0 goes backwards
M569 P2 S0 ; physical drive 2 goes backwards
M92 X160.00 Y160.00 Z1200.00 E420.00 ; set steps per mm
M208 X330 Y330 Z400 S0 ; set axis maxima; Endstops
M574 Z1 S2 ; configure Z-probe endstop for low end on Z; Z-Probe
M950 S0 C"exp.heater3" ; create servo pin 0 for BLTouch
M558 P9 C"^zprobe.in" H5 F120 T6000 ; set Z probe type to bltouch and the dive height + speeds
G31 P500 X0 Y0 Z0.474 ; set Z probe trigger value, offset and trigger height
M557 X15:315 Y15:315 S20 ; define mesh grid; Heaters
M308 S0 P"bedtemp" Y"thermistor" T100000 B4092 ; configure sensor 0 as thermistor on pin bedtemp
M308 S1 P"e0temp" Y"thermistor" T100000 B4725 C7.06e-8 ; configure sensor 1 as thermistor on pin e0temp
M307 H1 B0 S1.00 ; disable bang-bang mode for heater and set PWM limit; Fans
M106 P1 S1 H1 T50 ; set fan 1 value. Thermostatic control is turned on
M950 F2 C"fan2" Q500 ; create fan 2 on pin fan2 and set its frequency
M106 P2 S1 H-1 ; set fan 2 value. Thermostatic control is turned off; Tools
M563 P0 S"E3DVolcano" D0 H1 F0 ; define tool 0
M575 P1 S1 B57600 ; enable support for PanelDueM501
uh, I forgot to say that I'm using a PWM fan not an heater.....sorry....
@the_dragonlord said in How to use a LED Strip with Duet 2 WiFI?:
Which fan header and where is the gcode defining the pin?
@the_dragonlord your problem is you have m106 P2 S1 H-1 and you should have m106 P2 S0 H-1
@the_dragonlord but I recommend you use a heater and not a fan
i can't use a heater because I have to trigger a mosfet to drive the stripe and overriding a heater pin it gives a level of tension not enough for the mosfet to switch. Ay niw I'm using the Fan 2
excellent, thanks!
@the_dragonlord I'm driving the LEDs directly from the board so that I can control the brightness. But if you are driving a MOSFET, then the fan is a better option I guess.
yes it is, thanks
