Triangular wave and print area
@Leblond
yes. we are looking for backlash in the assembly. movement could cause the assembly to rotate and cause the result you are seeing. -
25/10/2020, 19:57:24 G32 bed probe heights: 0.192 0.195 0.190 0.192 0.192 0.192 0.190 0.190 0.190 0.190, mean 0.191, deviation from mean 0.002
25/10/2020, 19:56:50 G32 bed probe heights: 0.183 0.185 0.180 0.185 0.185 0.183 0.183 0.183 0.185 0.183, mean 0.183, deviation from mean 0.002
25/10/2020, 19:56:17 G32 bed probe heights: 0.168 0.168 0.168 0.173 0.170 0.165 0.170 0.170 0.170 0.170, mean 0.169, deviation from mean 0.002
25/10/2020, 19:55:43 M98 P"0:/macros/Calibrazione a punto singolo/Calibrazione x 10"
G32 bed probe heights: 0.183 0.185 0.183 0.185 0.185 0.185 0.183 0.185 0.185 0.183, mean 0.184, deviation from mean 0.001 -
there are default values from the configurator.
a quick google shows the motors seem to be 1,68 A motors
so you are running way to little current. try 1300
The motors are Quimat Nema 17 Stepper Motor 1.7 A 0.59 Nm 84 oz.in 47mm
@Leblond said in Triangular wave and print area:
1.7 A
so running them at 75% rounding to nearest 100 is 1300.
ok I took them to 1.3 and I'm doing the test again later
25/10/2020, 20:56:11 G32 bed probe heights: 0.198 0.195 0.195 0.198 0.195 0.200 0.195 0.200 0.192 0.195, mean 0.196, deviation from mean 0.002
25/10/2020, 20:55:37 G32 bed probe heights: 0.183 0.180 0.180 0.183 0.183 0.183 0.183 0.180 0.180 0.183, mean 0.181, deviation from mean 0.001
25/10/2020, 20:55:04 G32 bed probe heights: 0.183 0.178 0.173 0.170 0.178 0.173 0.173 0.178 0.178 0.173, mean 0.175, deviation from mean 0.004
25/10/2020, 20:54:31 M98 P"0:/macros/Calibrazione a punto singolo/Calibrazione x 10"
G32 bed probe heights: 0.195 0.192 0.192 0.195 0.192 0.195 0.195 0.195 0.188 0.195, mean 0.194, deviation from mean 0.002 -
I'm retrying cold-meshing the plate to see if we've made any improvements
no improvement
it seems to be very consistent.
can you turn the glass 90 degrees?
Is the X carriage on wheels?
I'm not familiar with the printer and can't tell from the photos I've seen,
Almost looks like an eccentric wheel causing the nozzle to rise & fall with each rotation -
Yes, the trolley is on rails and has eccentrics
I've had the same problem once , it was the x axis wheels and stopped the ripple with linear rails , but I guess getting better would have fixed it too.
@Veti yes I have already tried to rotate it 90 degrees, but no improvement
@peter247 in practice they had?
I don't think he's talking about eccentric nuts to adjust wheel tension, I think he means the wheel itself may be out of round.
Is the spacing between the peaks equivalent to a full rotation of the wheel?
@Phaedrux ok, but I tried to move it manually without the belt to see if it was free and so it was, do you think the bearings need to be changed?
Well the real question is does mesh compensation work to produce a good first layer?
Do a test print once with mesh enabled and another with it disabled. You should be able to tell if the mesh is accurate or not.
