Adding a independent Motor
Thanks for your reply,
I did a G92 U5, but that did not allow me to then perform a G1 U100 F1000 - do i need to do anything else?
I have not tried applying axis limits as I don't want the motor to be limited in any direction
Regards,
Mark
@mark said in Adding a independent Motor:
what the error?
No error, in the console the line goes green, but the motor does not move
@mark
i am afraid i have to insist on the m208see
https://forum.duet3d.com/topic/3604/homing-in-u-axis?_=1603377058168 -
I will try that later.
Maybe I am looking at this wrong and need to configure as an extra extruder as that does not have an endstop or axis limits. I wonder if I can setup a tool without any heater and run 2 tools at the same time
Mark
can you elaborate what that motor is doing?
Yes, it's simply feeding filament (down a ptfe tube to my hemera) in order to perform a load. There is a servo in order to disengage the filament from the motor once the load has completed. If I get this working then I can add another one for duel colour.
I am sure I am going to hit many road blocks and there might be easier/better ways but i want to try it anyway
a few weeks back there was a post about someone using 2 extruders for one filament.
i think it was done using the mixing ratio to drive 2 extruders at the same timehttp://blog.think3dprint3d.com/2016/12/using-diamond-hotend-with-duetwifi.html
@Veti very interesting, I will have a read.
Thanks
If you only want to use it as a loader but not during normal operation you could create it as an extruder and assign it to a tool to advance and retract the filament as needed and then reconfigure your tool as per normal printing when done.
