Cant get duet 2 in corexy to move correctly
If i send it a M669 it sends mem669
Kinematics is CoreXY, matrix:
1.00 1.00 0
1.00 -1.00 0
0 0 1.00and the motor outputs are not correct
if i move in X, X moves at a 45° and 1 Z motor moves
if i move in Y, Y moves at a 45° and other Z motor movesI have never got both x and y motors to move at the same time when i move the machine
could use someones help if you got time, there is something i'm not understanding
; generated by RepRapFirmware Configuration Tool v3.1.4 on Fri Oct 16 2020 22:33:42 GMT-0500 (Central Daylight Time); General preferences
M550 P"My Printer" ; set printer name
M669 K1 ; select CoreXY mode; Network
M552 S1 ; enable network
M586 P0 S1 ; enable HTTP
M586 P1 S0 ; disable FTP
M569 P4 S1 ; physical drive 3 goes forwardsM584 X0 Y1 Z2:4 E3 ; set drive mapping
M92 X80.00 Y80.00 Z4000.00 E420.00 ; set steps per mm
M906 X1000 Y1000 Z1000 E800 I30 ; set motor currents (mA) and motor idle factor in per cent
M208 X300 Y300 Z300 S0 ; set axis maxima; Endstops
M574 X1 S1 P"!xstop" ; configure active-high endstop for low end on X via pin xstop
M574 Y2 S1 P"!ystop" ; configure active-high endstop for high end on Y via pin ystop
M574 Z1 S2 ; configure Z-probe endstop for low end on Z; Z-Probe
M950 S0 C"exp.heater3" ; create servo pin 0 for BLTouch
M558 P9 C"^zprobe.in" H5 F120 T1500 ; set Z probe type to bltouch and the dive height + speeds
G31 P500 X2 Y-43 Z2.5 ; set Z probe trigger value, offset and trigger height
M557 X25:275 Y25:275 S75 ; define mesh grid; Heaters
M307 H1 B0 S1.00 ; disable bang-bang mode for heater and set PWM limit; Fans
M575 P1 S1 B57600 ; enable support for PanelDue -
please verify that you are on firmware version 3.1.1
using m115
@Szwalkiewicz said in Cant get duet 2 in corexy to move correctly:
M308 S1 P"e0temp" Y"thermistor" T100000 B4138 ; configure sensor 1 as thermistor on pin e0tempunrelated but your thermistor config is wrong. find your correct beta value in the technical documentation of your thermistor.
m115
FIRMWARE_NAME: RepRapFirmware for Duet 2 WiFi/Ethernet FIRMWARE_VERSION: 3.1.1 ELECTRONICS: Duet WiFi 1.02 or later FIRMWARE_DATE: 2020-05-19b2 -
what is the command you issued?
greetings
I see that in the M669 command of config.g you only define the kinematics type as corexy (K1) but you do not define the motion matrix.
i use the following command on my corexy printer and it works fine for me
M669 K1 X1: 1 Y1: -1the console output it gives me is as follows:
M669
1.00 1.00 0 0
1.00 -1.00 0 0
0 0 1.00 0
0 0 0 1.00I hope it serves
for the default corexy M669 K1 does not need parameters.
you seem to need it because you have 4 axis. -
how i moved it was:
the printer is a 300x300x300 so i moved it to the center on x,y and z and (by hand) and sent a g92 of 150 on all three and then used the paneldue jog screen on move around
The dzuki is always a good place to start, but movment on Z when i move the X or Y I think shows of a larger underlying problem
I tried it on two seperate duet2wifi's one on 2.xx and 3.xx firmware with the same outcome I must have missed a step some where
I'm going to hard reset one and reload the firmware -
change out of corexy mode and test each motor seperately
@Veti I like you idea so I erased a board reloaded firmware to start fresh on and rebuild the sd card files. On Cartesian Kinematics I set the motor output to M584 Z0 Y1 X2 E3 (to match board silkscreen) and placed to motor wires on the board to match and everything works as planed
then thats when i powered down the board and on reboot with no changes Z and X swaped places? now the motor output is not matching the M584?
M584
run the command in the console and see if it matches
M584 Z0 Y1 X2 E3
0 is not the Z driver. The default would be M584 X0 Y1 Z2 E3:4
So when you are seeing movement of the Z axis it's probably because you have the x or y motor connected to the z stepper or z axis motor to the x stepper.
@Phaedrux Thanks Phaedrux and Veti for your time and help. I incorrectly assumed the drive assignments
