Warning High Temperature reported by driver(s) 2
We keep getting a warning over and over
But we are not showing any faults and temperatures are good
Is driver(s) 2, heater 2? or is this not the driver 2 but 2 drivers? and if so is there way to find out which drivers and how to fix the warning?
MCU is running at 36CDuet WiFi 1.02 or later + DueX5 Firmware Version: 2.05 (2019-12-13b1)
Thank You
https://d17kynu4zpq5hy.cloudfront.net/igi/duet3d/4k56ZjaaAHrTJI6Z.huge
drive 2 is the z stepper driver
Do you know at what temperature they will give the warning? and without a thermistor is this something the board is reading through the motor wires or is it the connection at the board that is getting hot?
the tmc driver has inbuild temperature sensing. i believe its around 100C
basically if you can touch the chip and its to hot to touch, its a problem.
