Duet 2 Ethernet and SBC
@wilriker I do. I have two PSUs, one 24v and one 5v. All the grounds are connected in star topology, and the red/black connector on the pi is connected to 5v and ground.
It seems like it must be something software related, since I can't see any reason why it shouldn't work.
Just so I'm not crazy:
@SAtech said in Duet 2 Ethernet and SBC:
that signal looks decent.
it is probably sw related but sw detects error in CRC (good that there is CRC checking for packets) and that is hardly sw related, in my, limited, experience that is usually transport line issue when hw spi is used on both sides (and I doubt anyone is bit banging the 8 MHz spi )
few questions
- did you try reducing the SPI speed ? dropping from 8 MHz to 1 MHz ?
- did you try the "drill" test ? (start a long running simulation, take a drill, one that connect to mains outlet, not those battery powered ones, turn on a drill and bring it close to the wires) do you see increase in errors?
- the utp cable you are using, its not shielded? did you maybe tried shielded cable?
I was playing bit more, since via's are free I stiched it up a bit, I moved the SBC connector 10mm up so now the front of the both pcb's (duet and rpi) are in line, sbc is not sticking up messing up with case) and also since the "extended" part of the connector is not used I made a via-cut so you can snap off that part of the pcb and solder on shorter connector.
signal pats are not crossed anywhere (that's why 3v is routed all the way around) so return current should flow easy trough the ground plain and this should work at super high speeds without any issues .. and 8 MHz should be a brieze ... when I order the boards I'll do the "electrical drill test" but I believe this is rather resilient like this
@arhi said in Duet 2 Ethernet and SBC:
lemme know if jlcpcb accepts that without insisting on a paneling fee for multiple designs?
@bearer I hope they do but even without those few via-s it is easy to cut off that part of the board ... I won't be ordering it yet, waiting for more testing with existing pcb (too slow for now, I'm still one-handed) ...
I was also thinking about making another change - to add 2 female pinheaders over the paneldue and probe connectors so one can just "cut the plastic" of the connector and press the board on to the duet hitting both ethernet port and the paneldue and mode ports, and then add those 2 connectors on this board so they are accessible from the top .. but will see .. maybe just a more comples cutout
Well it seems that by twisting MOSI, MISO, and SCK with ground has basically solved my issue. I am now getting NO errors, and I can print successfully. Seems there was significant crosstalk in the lines.
The only thing that is a little troublesome is sometimes the movement is quite jerky. Like in a long travel move it will just stop for a few ms and resume, as if the duet is choking on step generation. I don't think this is happening, but that's how I can best describe it.
Just as a benchmark: the maximum the Duet can achieve reliably is around 27MHz.
should show up in
M122
If that persists please open a new thread (since this one is getting very long and a bit hijacked ) and include your
config.g
as well as theM122
output that @bearer mentioned and a sample GCode file. -
@smoki3 After what felt like ages (sorry for that) I finally got to rig up a Duet 2 + DueX5 + SBC. It's just a bench setup but at least I attached steppers, a thermistor and a PT1000. I intentionally ran all stepper wires over the SPI wires but I cannot see a single checksum error or any problems at all.
Did you retest with latest RRF 3.2-beta2? If you still experience your problems please provide me with your full
0:/sys
directory contents as well as all possibly other required macros and a GCode file so I can try to reproduce it. -
@wilriker I have only tested with 3.2 beta 1.
Have you tried stall detection on a core xy? The tool changer has 6 axis and all are homed with stall detection.
If I find some time I will assemble my duet Ethernet again to check if its fixed on beta 2.
@smoki3 As you can see it's simply something cobbled together on my desk. It is configured as a simple 3 axis Cartesian and is only pseudo-homed using
G92 XYZ
. So maybe that is the problem already. If possible you could test if it works for you if you useG92
as well. Maybe it's just stallDetect that fails. -
@wilriker said in Duet 2 Ethernet and SBC:
G92 XYZ
as well. Maybe it's just stallDetect that fails.As far I remember homing was one of the main issue. But let me check again with beta 2. I will come back to you
Can anybody explain me advantages of sbc attached to duet?
@smoki3 said in Duet 2 Ethernet and SBC:
I tried stallGuard as endstop now (manually blocking the motor shafts) and still no problems. So maybe putting the LinuxInterface into its own FreeRTOS task solved it eventually. Looking forward to your feedback.
@seraser said in Duet 2 Ethernet and SBC:
for now not much more than being able to run DWC on a hdmi touch screen instead of paneldue (and more flexible networking as you'll have both wifi and ethernet).
but as plugins are added to DSF it will offer added functionality (and of course its easier to develop your own stuff on the pi rather than in the reprap firmware)
none attm
probbly "plugins" in future, plugins that will be capable of modifying g-code real time while printing (like octoprint for e.g.)
Thank you @bearer and @arhi so I will not play with my rasp4.
@seraser the wifi is much better using an SBC than the wifi onboard. That's about it
