Help PID tuning Dyzend Pro
@chris974M said in Dyzend Pro:
Dyze donne sur son site
Thermistance 500 ° C Thermorétractable noir
#Modification du fichier config.g
Recherchez les paramètres suivants et remplacez les valeurs:The problem is the heater, not use 50w. Use 40w or 30w
Oui auto tuning ok apres autotun. M500 il enregistre bien dans config-override.g
@FBG comment changer cela
@Phaedrux
12/10/2020 à 22:00:22 Auto tune cancelled because starting temperature is not stable
12/10/2020 à 22:00:02 M303 H1 S220
Auto tuning heater 1 using target temperature 220.0°C and PWM 0.50 - do not leave printer unattended -
@Phaedrux
Auto tuning heater 1 using target temperature 220.0°C and PWM 0.50 - do not leave printer unattendedDoes it work, or does it not work?
now does it not work
I suspect that's because the high temp thermistor is less accurate at low temps. You could try preheating it a bit before starting the tuning process.
@Phaedrux OK i try
12/10/2020 à 22:41:21 Auto tune phase 1, heater on
12/10/2020 à 22:41:15 M303 H1 S220
12/10/2020 à 22:48:39 Auto tune heater 1 completed in 443 sec
Use M307 H1 to see the result, or M500 to save the result in config-override.g
12/10/2020 à 22:44:26 Auto tune phase 3, peak temperature was 229.7
12/10/2020 à 22:44:03 Auto tune phase 2, heater off -
Now i execut the command M500 and M501
Toujours des fluctuation de temp
Ok if that successfully worked you can do as DC42 said above and edit the resulting M307 command in config-overide to increase the D value.
If you have already run heater tuning and copied the resulting values into your M307 H1 command in config.g, increase the D parameter in that command until the temperature is stable when the print head is not moving. Try increasing it by 30% initially.
Ok je vais essayer sa
temp. régler a 220 for test
elle monte a 232 avant de descendre vraiment doucement jusqu'à 220 -
temp. set to 220 for test
it goes up to 232 before going down really slowly to 220If it overshoots the target, increase the A parameter. Try increasing/decreasing it by 5% or 10%.
et la température se stabilise pas
@Phaedrux
config.g or config-override.g -
Your tuned values are stored in config-override.g You can edit them there, but if you ever re-tune they will get over wrote, so you should probably cut and paste the M307 H1 command from config-override.g into config.g. so you can edit it there.
Also, have you seen this from Dyze?
https://docs.dyzedesign.com/hotends.html#reprap-firmware
